Looking for help on location for ABS relay "codeC1276" | FerrariChat
Discussion in '360/430' started by Jose360Modena, Feb 8, 2020.
  1. Jose360Modena
    Jose360Modena Rookie
    Nov 30, 2018
    20
    Jose Flores
    Hello I have a 05 F430 coupe F1 . I have abs error code on cluster " c1276 " (valve relay) . Need advice of location or/and part number, I called Ferrari parts department and they don't know . Is the relay called abs motor relay or abs module relay ? Thank you in advance !!
  2. brogenville
    brogenville Formula 3
    2,268
    Robin
  3. brogenville
    2,268
    Robin
    For info, the abs ecu is integral to the abs module itself.
  4. brogenville
    2,268
    Robin
    Check fuses and relays, but failing that, it looks like you’ll need to replace the ABS module itself.
  5. Jose360Modena
    Nov 30, 2018
    20
    Jose Flores
    I don't have a fuse chart to tell me where is the ABS fuse and ABS relay on my F430 .
  6. Jose360Modena
    Nov 30, 2018
    20
    Jose Flores
    Do you know where is the Valve Relay located and the abs fuse ?
  7. brogenville
    2,268
    Robin
  8. Jose360Modena
    Nov 30, 2018
    20
    Jose Flores
    I did saw that ,and I check the fuses all good ! But again it does not show a Relay for ABS computer on that diagram or "valve relay" indicating on my F430 abs error code . I would like to know if it has one or not ? "ABS relay"
  9. brogenville
    2,268
    Robin
