Looking for “how to” on replacing rear wheel bearing | Page 3 | FerrariChat
Discussion in '348/355' started by vdettore, Sep 28, 2018.
  1. vdettore
    vdettore Formula Junior
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    I’m back on this now and close to removing the hub. How does the e-brake cable come off the back of the hub?
    Vince FerrariChat.com mobile app
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I think the answer was already posted in this thread
    ernie likes this.
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes it was. A clip or somthing then pull it through
    vdettore likes this.
  4. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Thanks, somehow missed it when going through the post. [emoji106]
  5. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Qavion and ernie like this.
  6. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Here is my handbrake assembly. The cable fits over the hook you can see. Back off the cable adjustment first, unhook and the you can pull the cable out of the sleeve in the back of the hub. May be tight.
    ernie and vdettore like this.
  7. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Great - thank you [emoji1317] and for the photo
  8. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    One other question. I am assuming to get the bearings out of the hub I have to remove the parking brake assembly “off” the hub. I looked and did not see a thread on the removal. Is there anything I need to be aware of when removing and reassembling the parking brake to the hub? I’ll get some pictures and post while doing it for future reference for F Chatters.
  9. Pangea
    Mar 27, 2011
    442
    Nick
    I would remove the parking brake assembly. Ive not changed the wheel bearings but had the hubs off. It will probably get in your way when you are working on it. Just note what goes where. There is nothing much to it apart from its a bit fiddly to refit. Its just a case of getting in there and doing it. I have a few more pictures of the set up if you need them so don't worry if you jumble the bits up. Tricky bit is the retaining springs and cups.
  10. Pangea
    Mar 27, 2011
    442
    Nick
  11. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Pangea likes this.
  12. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
  13. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Not as hard as I thought. Daniel at Ricambi was able to help me. Getting both the socket and ring nut.
    I see that Ricambi sells bearings that are listed on the exploded view.
    Pangea likes this.
  14. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
  15. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  16. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Thanks, I looked at it. My hub looks completely different than that one in the link you provided. I was trying to figure out where he was talking about putting a drift and tapping out the race or bearing. The one in the thread must be a later 348.
    I’ll get back on it in the morning.
    Also, (and I’ll post pictures and steps once I’m done) The 45 mm ring nut socket purchased from Ricambi had a outside diameter slightly too large to fit inside the flange to get to the ring nut. It took me a couple hours of grinding away on it to make it fit.
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes, yours is not the integrated bearing / hub. You have a typical bearing pressing into a housing.
  18. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    ernie and Pangea like this.
  19. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    I can’t figure this out. How do I get the wheel bearings out. I bought 3 different type kits and can’t seem to make any of them work.
    The toothed spacer inside the hub floats around between the two bearings so I can’t get a jaw puller to work.
    The bearing adapter kit from Harbor Freight includes a bolt but not near long enough because this is a rear hub. Would work on a front hub.
    The split bearing separator and puller won’t work.
    Even if my bearing adapter kit did have a long enough bolt I don’t see how to make it work with that toothed spacer.
    I’m at a loss. [emoji53]Any help would be greatly appreciated. I’m probably overlooking the obvious.
    Thanks in advance
    Photos below
    in View attachment 2646398
  20. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
  21. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    ernie, Dave rocks and Pangea like this.
  22. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Both bearings out. The inside bearing is the one making the noise although it wasn’t toast yet. I was actually relieved that one was going bad and all this for nothing. Also that It’s not a CV joint or something else. I’ll know for sure when I get it all back together and test drive. Will post again then. Again, I’ll summarize the entire process when all is complete for future reference for those with early 348’s.
  23. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Keep up the good work.
  24. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    So all back together and no grinding anymore when I turn left. I ended up replacing the CV boots on both sides of the car while I had the car up on the jack stands. A few minor “hiccups” along the way, but thanks to many of you on F-Chat I was able to do the work myself, learn something about my car and save some money.
    Photos and details too follow as soon as I have some time. Again a BIG thank you to those of you who replied with your suggestions and advice. [emoji106][emoji1317]
    jqpd99 and Pangea like this.
