Looking for info on a diving/snorkle mask | FerrariChat
Discussion in 'Sports' started by badges2, Jul 22, 2012.
  1. badges2
    badges2 Formula 3
    Nov 6, 2008
    1,652
    Geneva, IL
    Neil
    I just back from my vacation to Florida and had a great time floating around checking out the fish. I ended up buying a retail type diving mask from a local tourist trap just to have something. Can anyone recommend a decent brand to look for in a mask? It would be used strictly on vacation and for putzing around the beach. I don't need anything professional, just something of good quality that will work well and last. Being from Chicago, I know nothing about them or where to start! Thanks for any help!
  2. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    My 02c;
    You don't need anything "fancy" - Certified down to 1000ft etc etc.
    Most important is fit - Standard procedure is to put it on without the strap. Breath in thru your nose and it should "stick" to your face. [Assuming you don't have the worlds biggest mustache ;)]
    Snorkel is even easier - Get one with a little doohickey so it can be mounted on the outside of the masks strap - Tucking it thru the inside will eventually hurt yer' head / give you a headache. [Ask me how I know! :(] I always liked the "flexible" ones as they give a little more, surprisingly, flexibility on mounting & fit.
    Get a pair of flippers too and you're good to go - Until the bug bites and you want to learn to scuba anyway.
    Cheers,
    Ian
    PS - I don't believe you can buy 'em anymore - At least here in the States - DO NOT get a snorkel with a caged ping-pong ball at the top - *Dangerous* as they can stick, you panic, and bad things happen....
  3. badges2
    badges2 Formula 3
    Nov 6, 2008
    1,652
    Geneva, IL
    Neil
    Thanks for the reply/help. Is there an entry level brand you would suggest?
  4. lil squid
    lil squid F1 Veteran
    Dec 3, 2007
    5,949
    Houston TX
    Yuliya
    US Divers. Any Academy/Sports Authority or similar sporting goods store would have one. I've had mine for for 12 years, from pool underwater hockey to 130ft rec diving. Hmm, now that I think abut it, maybe time for upgrade. :)
    http://www.usdivers.com/index.php/products/mask-snorkel
  5. Whisky
    Whisky Three Time F1 World Champ
    31,944
    In the flight path to Offutt
    The original Fernando
    I still have my ScubaPro mask, snorkel and Jet Fins I bought in 1974. Still in great shape, all I have had to do is replace the straps on the fins and the mask.
    Neil, it looks like you can get first-rate stuff for $65 total.
  6. badges2
    badges2 Formula 3
    Nov 6, 2008
    1,652
    Geneva, IL
    Neil
    Thanks for the help guys!
  7. Nativetroy
    Nativetroy F1 Veteran
    5,990
    central fl
    Troy
    Try a couple on at a shop. US divers are ok. I've got an oceanic, about $70. Biggest differmece is the rubber. It's much more comfortable. And look for a snorkel with a valve. They are nice.
