Looking for motorized seat belt parts | FerrariChat
Discussion in 'Boxers/TR/M' started by blown daytona, Jul 16, 2021.
  1. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    My drivers side motorized seatbelt has been acting stupid since the recall was done 10 years ago. I finally took it apart and found the B position switch housing was cracked allowing it to flex. Of course all parts are discontinued. Does anyone have a lead on who may have a used assembly (61560400 superseded to 65779300) I can use to rebuild mine or a B position switch (61560700) Thanks in advance for the help !!!
  2. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Tried ferrparts?
  3. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Thanks, called them yesterday, They had a used one. Had them send me a pic and the B position switch was cracked in half :( Also waiting on Bill from GT Car Parts to get back to me.
  4. Gialllo uno
    Gialllo uno Formula Junior
    Jul 5, 2014
    342
    Reisterstown, Maryland
    Mark
    My drivers side motor always worked but the seat belt hook up did not move. My passenger side works. After removing a bit of trim to do a carpet install I looked at it closer and the long plastic rope (For lack of a better description) was broken in mine. I would assume it isn't available and would need the whole assembly to get it working properly? I also assume there is no way to bind it back together somehow, cutting a notch in each side so it fits together and then using plumbers PVC cement to glue it together.....probably wouldn't work....just reaching?
  5. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Sounds like you are talking about the plastic ribbon which moves the slider back and forth. I do not think that was ever available separately. So far the used ones I see have broken ribbons and B position switches. I think this is a result of careless handling :( Whatever bonding repair you attempt needs to fit inside the confines of the track (which is narrow). Also the ribbon needs to be a certain length so it will have a full range of motion.
  6. Gialllo uno
    Jul 5, 2014
    342
    Mark
    I knew it was probably something that may stay the way it is, but I don't think I can hurt it and yes it was the ribbon I was talking about. I doubt my fix would work but it got me thinking. The careless handling was prior to me!!!! Not that I don't have my own issues!!!!
  7. Natkingcolebasket69
    I was checking on eurospares the first part you mention- you can order from new but it’s like 1800usd
  8. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Thanks, I was hoping to find a decent used one with a good B position switch and a ribbon. New one is pricey, but may not have any other options.
  9. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    I took all of that equipment out of my car and have it stored. I installed Ferrari standard seat belts. What of this stuff do you want?
    Burnell
    turbo-joe likes this.
  10. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Thanks BP, I started a conversation with you
  11. JogDog78
    JogDog78 Rookie
    Feb 28, 2014
    7
    Cincinnati, OH
    Pete Zink
    Did you find the interior trim pieces that go with the manual seatbelts? I'm converting my 1992 TR back to European style seatbelts and am still tracking down the trim piece that goes along the A pillar and top of the door.
  12. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    No, I did not find the trim pieces and I tried the usual sources. I did not try the euro sources, so you might try them. I ended up buying a sheet of thin alunimum and forming my trim pieces. Looks ok but took a good bit of time to do it.
    bpcurtis
  13. EZORED
    EZORED Formula 3
    1,018
    Scottsdale, AZ
    Dennis
    Redbay cars just broke a Euro Tr a few months back. maybe they have the pieces
  14. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    a euro TR has no motorized seat belts
  15. EZORED
    EZORED Formula 3
    1,018
    Scottsdale, AZ
    Dennis
    JogDog, said he was converting back to euro spec!
  16. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    then he needs not the broken switch
    but it was "blown daytona" who ask for
