Looking for used 63307100 Timing Actuator | FerrariChat
Discussion in '348/355' started by zstyle, Aug 19, 2019.
  1. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    532
    Fountain Hills
    Jon
    I am seeking a used (even broken) timing actuator (63307100) to fix my Ac distribution. The internal gear on my unit is stripped and would like to either: 1) replace with a working used unit 2) combine two broken units into one working unit.
    The specific gear stripped is the one which mates to the electric motor and has an integrated work gear.
    To date, no parts supplier has new units available.
  2. Qavion
    Qavion F1 World Champ
    11,534
    Ian Riddell
    Jon, did you see the relatively recent message thread about the internals being different from one timer actuator to another (with seemingly no reliable way of identifying which is which from the outside)? You might be wasting your money buying a broken one, either because the same part/s are broken or because the parts might be different.
    https://www.ferrarichat.com/forum/threads/evaporator-timing-actuator-63307100.600342/
    Mine sometimes seems to hunt a lot on startup, so I bought one just in case it failed completely. Probably your best bet is to set up an eBay search to notify you if one becomes available. I got lucky and found one a few months ago from a private seller which looks new and tests perfectly.
  3. Qavion
    11,534
    Ian Riddell
    #3 Qavion, Aug 19, 2019
    Translating this Japanese webpage...
    https://translate.google.com/translate?client=firefox-b-d&client=tw-ob&um=1&ie=UTF-8&hl=en&sl=ja&tl=en&u=http://www.rossoauto.com/productsindex2106.html
    I can't say I've had much luck with Japanese websites however. I don't know if it's language difficulties or that they don't export.
    Good luck with the order form:
    http://www.rossoauto.com/cgi-bin/enquete/form0015.reg
    I can't see a selection for a credit card. Seems they want a bank transfer or COD.
    3rd line is mail address
    4th line is name
    5th line is birthday (what??)
    6th line is shipping address
    7th line is emergency contact number
    The box is for order details.
    There is an enter and reset button below this.
  4. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    Good find! 340,000 yen so its either $3000 or $3? I can't work that out.
  5. Qavion
    11,534
    Ian Riddell
    #5 Qavion, Aug 19, 2019
  6. Ferrarium
    5,631
    Central NJ
    Eric
    Tough spot for a component, you get to it from under dash?
  7. Ferrarium
    5,631
    Central NJ
    Eric
  8. Tridentecavallino
    Mar 15, 2013
    92
    Germany
    Thomas
    Hi Qavion.
    I still have 3 new 63307100 actuators. Send me a PM if you still need one.
    Regards
    Ron Panna and Qavion like this.
  9. Tridentecavallino
    Mar 15, 2013
    92
    Germany
    Thomas
    Sorry, I meant zstyle and not qavion.
  10. Qavion
    11,534
    Ian Riddell
    Great to hear, Thomas. Hopefully cheaper than $4000 for a set of two? :D
  11. zstyle
    Jun 28, 2007
    532
    Fountain Hills
    Jon
    Thank you for the references to other threads. I noticed there was little follow up and suspect as time goes on these units will become their weight in gold.
    Sent a PM to Tridente.
  12. Tridentecavallino
    Mar 15, 2013
    92
    Germany
    Thomas
    No. I will not ask a crazy price.
    I must add, that I must keep 2 for myself (for my own F355) and hence I can only let 1 go.
    I should have written it at the beginning, now i am confronted with several request (this part seems to be as demanded as a 355 roof ecu or HVAC ecu).
    Sorry that I can only serve one request.
    Thomas
    Qavion likes this.
  13. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,711
    Atlanta, GA
    Steve D.
    106 to the dollar the other day.
  14. plugzit
    plugzit F1 Veteran
    7,673
    Redondo Beach, CA
    Bruce Bogart
    I've got one available. Just send me a pm. I need the space!
    Qavion likes this.
  15. cheungchoyui
    cheungchoyui Karting
    Oct 16, 2016
    81
    Hong Kong
    Joe Cheung
    Hi, Is there anyone has this part for sale ?
  16. Ferrarium
    5,631
    Central NJ
    Eric
    NLA you probably know search the web regularly as they come up often enough. I do see them. good luck!
    Sent using FerrariChat.com mobile app
