Looking for used window motor 308? | FerrariChat
Discussion in 'Technical Q&A' started by 308GTS, Apr 27, 2004.
  1. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    Does anyone have a used working 308 window motor, even if it is slow that they will sell or ?. Thanks.
  2. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    I have a new motor, If you need it I can certainly part with it.
    Wade
    www.fortunemotors.com
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,159
    Canada
    Newman
    You can also get them from ferrari UK at a reasonable price.
  4. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    Alfa spider motor..same unit and very much cheaper.
  5. BigTex
    79,218
    Houston, Texas
    Bubba
    LOL! And the closest US Alfa dealer is............??
    No, I know what you mean, just could not resist! :)
    Call Wade!
  6. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,687
    North shore, MA
    THE Birdman
    Tom,
    Do you have a source on the Alfa motors?
    Birdman
  7. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    Check George Evans (Evans Automotive) in Ohio for these new... Price is reasonable and he's a great guy to deal with.
  8. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    new ones are occasionally on EBAY--for a used one --try TRutlands
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    www.international-auto.com
    The most complete source for Alfa parts. Can practically build a car from their catalog.
    BTW, I've never heard of a slow window motor. Slow windows are almost always due to the grease in the drive gear ass'y turning to something approximating semi-cured epoxy. After you 've cleaned & re-lubed the gears, the windows are back to their original speed.
    Never hurts to put a couple of drops of fine machine oil on the bearings at each end of the motor tho.
    If cleaning/re-lubeing the window drive doesn't speed things up enough, Install Mike Tarrant's relay 308/328/Mondial Slow Window Fix in the Parts & Service section:
    http://www.ferrarichat.com/partsandservice/slowwindowfix.htm
    DO NOT just install this fix w/o 1st cleaning & lubeing the drive gears. The combination of the heavy load due to the gooey grease & the lowered circuit resistance can smoke your motors, blow fuses, cook fuse panel contacts...
  10. Wayne 962
    Wayne 962 Formula Junior
    502
  11. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    As Verell said, the first thing is to clean the drive gears. Dollars to donuts the motors will come back to life. It just seems that the motors are rarely the culprit of the slow windows.
    Another good test, is to connect the battery directly to the switch leads. If you notice a big improvement, than there is too much resistance in the circuit possibly due to oxidation.
    Regadless of what is done to the circuit, clean the drive gears first. Yes, it is a PITA, but you will be glad you did.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    Wayne,
    That's George Evans selling those motors. If you search the archives, you'll discover that Ed Gault bought them & discovered they weren't a lot different from his orig. motors after he'd done the clean & lube service:
    http://www.ferrarichat.com/discus/messages/256120/8376.html
    Not sure if Evan's motors would be more powerful if the resistance in the circuit were significantly reduced. Could be tho. Lots of times under marginal voltage conditions a higher power motor will actually deliver less torque than a ostensably lower powered one because the 'lesser' motor is still getting enough current to deliver full power.
    SLOW POWER WINDOW SERVICE PROCEDURE:
    BTW, Here's the link to Ed Shreyer's Slow Power Window Service Procedure in the 'Ole Tech Q&A Archives':
    http://www.ferrarichat.com/discus/messages/256120/114996.html
    I've got to get around to cleaning it up, adding a few pictures & getting Rob to post it under Parts&Service...
  13. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,416
    Toronto / SoCal
    Rob C.
    I agree with the cleaning route. For sure you can pick up tons of speed from cleaning and re-greasing all the movements as well as disassembling and cleaning all of the power window switches. They corrode with time and add huge resistance to the system.
  14. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    I think I've got an old pair of working 308 window motors laying around. Drop me an e-mail, and I'll send them to you, CHEAP.
    [email protected]
    Jeff
  15. Wasco
    Wasco Formula Junior
    Dec 9, 2003
    486
    Salem
    Randy
    I have one of Evan's brand new motors if you want I will sell!
  16. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    wasco, I'll take that one. PM me at [email protected]
