Looking for wiring diagram for Secondary air pump on an 88 Testarossa | FerrariChat
Discussion in 'Technical Q&A' started by Mattroot, Jun 5, 2023.
  1. Mattroot
    Mattroot Rookie
    Sep 20, 2022
    10
    CONNECTICUT, USA
    Matthew R
    In the past someone broke the plastic connector to the air pump and the wires were just dangling, would explain the odd idle too. lol
    I have a Violet (Z) and a Red (R) wire just want to attach them correctly while the Engine is currently out of the car on a table, thank you guys.
  2. Steve Magnusson
    26,826
    #2 Steve Magnusson, Jun 5, 2023
    Are you sure those aren't a ZN (purple-black) wire and a RN (red-black) wire? My guess would be that, functionally, the polarity doesn't matter as the coil of the electomagnetic clutch inside the air pump is isolated from everything else (and the direction of the magnetic flux that the coil generates won't matter either as it just attracts a steel component to engage), but just a guess (and I don't have a TR anymore to check ;)).
    You can download a pdf copy of the late US TR wiring diagram 509/88 here:
    https://www.dropbox.com/s/gne5xw608ba818b/509_88 US TR Wiring Diagram Book.PDF?dl=0
    Fig 3 has the air injection components (but it doesn't convey anything about the physical polarity of the air pump, 140, connections).
  3. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    Thanks Steve.
  4. Qavion
    Qavion F1 World Champ
    14,312
    Ian Riddell
    #4 Qavion, Jun 5, 2023
    In colour....
    https://www.dropbox.com/t/JG6CKbDXYgGWfQpP
    See item #140
    But it still doesn't specify which wire goes to which pin on the pump.
    Isn't the pump powered by a DC electric motor? Wouldn't that mean the pump would go backwards, perhaps sucking instead of blowing :p
    Were you thinking of the secondary air solenoid valve?
  5. Steve Magnusson
    26,826
    #5 Steve Magnusson, Jun 5, 2023
    No, on a TR (testarossa), the air injection pump is belt driven off of the crankshaft. The electrical signals only determine if the air pump EM clutch is engaged (which spins the air pump rotor) or not engaged (which does not).
    Qavion likes this.
  6. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,069
    Troy, Michigan
    James
    Air pump shouldn’t do anything to affect idle right? It just shoves air into your cats at start up. And doesn’t stay on very long either.
  7. Qavion
    14,312
    Ian Riddell
    Thanks, Steve. I'll update my diagram to show this.
  8. Steve Magnusson
    26,826
    Not warm idle, nor cold idle, if everything's working correctly.
    If the air injection system was wrongly "on" during warm idle (for some bizarre reason) = that would cause the O2 sensors to report a very lean value always to the KE-Jet injection ECUs.
  9. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,069
    Troy, Michigan
    James
    Oh yeah. That’s right. If it fails in the on position somehow. I wonder if that’s even possible.
  10. Steve Magnusson
    26,826
    Wouldn't disagree that that would be rare, but I was thinking more along mechanical lines (e.g. the clutch gets mechanically locked up) rather than an electrical flaw (but that's not impossible).
  11. Mattroot
    Mattroot Rookie
    Sep 20, 2022
    10
    CONNECTICUT, USA
    Matthew R
    Thank you guys, I love the community here, didnt get right back because I got put on a 599 for a bit, had to pull the dash for recovering, not to bad if you take you time and bag and tag everything, now im pulling the intakes to change the engine cover gaskets (Valve cover gaskets. good to know the polarity doesnt matter, i didnt think it would but i wanted to verify before putting the engine back in the car, engine is back in as of last night, thank you all so much,
    Qavion likes this.
