Looking to give my first Oil Change on my 328 | FerrariChat
Discussion in 'Texas' started by Inowownone, Apr 10, 2006.
  1. Inowownone
    Inowownone Formula Junior
    Jul 22, 2005
    377
    Plano, TX
    Tom W.
    I'll do another search... but, it appears that I will need to purchase a 12mm hex socket (male end, correct?). Others that have done this before... do you recommend ramps or two jacks? Can you get the car up enough with one jack? Safe?
    I got the brass washers (from NAPA) to put back on the drain plug. Oil and Oil Filter are purchased as well. JimE, are you still up for assisting...to make sure I don't drain the gear oil....?
    Sure would be nice to have a lift or a pit.
    Rob... reading your previous posts.... stating you change your oil every 1,000 miles... are you doing this yourself... or 100% taking it to Norwoods (James)? I read where it looked like you have done both. Also read that you are using 8 quarts.
    I change the oil in my other vehicals, but since this is my "first time" with my 328... just wanted to do a little extra homework. Thank you for your input.
  2. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,960
    Southlake, TX
    Rob Lay
    I think you have it down. I prefer using the ramps and just backing up on them. Plenty of clearance to keep from hitting body and plenty of room to get under there. Much easier than jacking up, placing two stands, and making sure secure.
    12 hex needed. Sears.com is good source. New filter and copper crush ring. Don't remember, but I guess start with 8 quarts and then check levels when warm.
    I will do myself unless car is already in Norwoods for something else.
    Big hint, you need a large (10 qt. +) open catch container. The entire 8+ quarts will dump in about 5-10 seconds. Even 2 inch holes of most catch containers will overflow quickly.
    I change more at 1,500 miles or 6 months now.
  3. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,901
    Dallas, TX
    Jim E
    I'll still assist, just to watch somebody else learn how! :)
    I have a low profile floor jack if you need it, bought it just for the Ferrari.
  4. Inowownone
    Jul 22, 2005
    377
    Plano, TX
    Tom W.
    Thanks Rob and Jim.
    Jim, I have a low profile jack as well. Maybe the use of yours and mine would work... since I don't own any ramps. Might need to get another oil pan..... mine will hold the 8 quarts... but, the fill hole is pretty small (less than 1").
  5. rob lay
    Dec 1, 2000
    63,960
    Southlake, TX
    Rob Lay
    You MUST have two floor jacks holding the car up for safety. Never just depend on the pump jack. $20 at Wal-Mart, but about same price you can get ramps.
  6. jimpo1
    Jul 30, 2001
    24,901
    Dallas, TX
    Jim E
    Yeah, if you use just both pump jacks, you'll be the one sliding under the car! :)
  7. TX907
    TX907 Formula Junior
    Sep 13, 2005
    924
    Keller, TX
    Garrick
    Don't wait until the last minute to try to find a large hex socket. I needed a large one for an oil change on the bike the day before a track day and almost didn't find one. I think Sears only stocks up to 10mm at the store. I did find a set of 3 larger ones (for auto drain plugs, I presume) at AutoZone but I can't remember the 3 sizes.
  8. Inowownone
    Jul 22, 2005
    377
    Plano, TX
    Tom W.
    Garrick, You were correct. Auto Zone has a set of 3 (12mm, 14mm and 17mm) for $7.99 (1/2 socket drive). I assume that the "hex patter" is a standard 6 sided / hexagon? Thanks.
  9. TX907
    Sep 13, 2005
    924
    Keller, TX
    Garrick
    Yes, the hex "key" or "bit" is the six-sided male tool. I thought when I was growing up my dad always called them an allen key or wrench, but I don't really hear anyone using that term any more.
