Loose Drip Tray | FerrariChat
Loose Drip Tray
Discussion in '206/246' started by Nemo4, Apr 13, 2009.
  1. Nemo4
    Nemo4 Rookie
    Sep 2, 2006
    34
    One of the drip trays on the engine cover of my 1971 Euro GT has come partially loose. I've been told that welding the tray back into position would damage the paint. Is there another means of reattaching the drip tray at the contact point?
    Thanks in advance to any F-chatters who have suggestions.
  2. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    Nemo4,
    I don't know the book answer, but I can share two observations with you.
    On my friend's Tipo M, the trays are riveted in. On my Tipo E (also a Euro car), they are held in with screws. I don't know if either method is proper, but either will do. Since both cars were repainted at some time in their lives, the trays were temporarily removed. My parts manual doesn't show any type of fastener. I don't mind that my trays are now easily removeable, as I've pulled 'em to hasten the exit of hot air from the engine compartment. And, I agree that intense heat would do a number on the finish.
    We've a couple of 'one-owner' owners on board; they will likely have the correct answer!
    Cheers,
    Coop
  3. daviekj
    daviekj Formula Junior
    486
    Nemo4
    not sure I understand where the drip tray is. I have a Tipo E and don't see any brackets, or mount points for a drip tray. There is a small approx 300x300mm steel guard plate screwed to the chassis below the clutch pulley. Any chance of some pictures?
    Kevin
  4. Jon Hansen
    Jon Hansen Formula Junior
    Feb 6, 2007
    509
    Grand Rapids, MI
    Jon Hansen
    I believe he is talking about the drip tray located below the engine lid hot air vents.
    They are usually just pop riveted on from what I have seen.
    To fix the loose drip tray, I would recommend nixing the welding option and going for the rivets instead.
  5. 2GT
    2GT Formula 3
    Aug 25, 2008
    1,842
    Western NY
    Fred
    I'm fairly certain that the drip trays on both my Dinos (04808 and 3964) are riveted on. As for heat escape, I've never worried about it while driving, but immediately upon returning from a drive, I open both the front hood and the engine lid to allow for cooling. I also use several cloths estended over the bottom of the rear window gasket to keep excessive heat off the rubber during the cooling process. Fred
  6. Scuderia P1
    Scuderia P1 Formula Junior
    521
    Monarch Bay, Calif
    Chris Conti
    There's one end of the tray that's not riveted but glued to the deck lid, I think that's what he's talking about. You need some really good adhesive, for some reason it's hard to get it to stay in place.
  7. daviekj
    486
    #7 daviekj, Apr 14, 2009
    Nemo4,
    having read the replies and re-read your question, I can now see the trays you are questioning.
    My late '73 car, had the trays riveted to the engine lid frame. I am fairly sure this is as original. The tab which Scuderia says is glued to the engine lid, is loose on mine. The trays are quite firm so I am not too worried. The tab is about 10mm clear of the engine lid, but can be pushed easily to make contact with the lid.
    I replaced the rivets with 4mm nuts and bolts as per photos. Makes it easier to remove and clean.
    Never had any worries about getting heat out, however, i run it in a UK climate, so not a real test.
    I would not weld them to the engine lid, there should be no need.
    Kevin.
  8. Dino Club Germany
    Dino Club Germany Formula Junior
    Nov 10, 2008
    549
    Germany
    N. Schumacher
    I know two options from other 246 here:
    1) leave the out. A friend measured a lot lower under the hood temperatures without and there is not really something they would protect.
    2) "Glue" them. After removing all sign of Oil etc. you can use we in Germany would say "body sealant" or Sicaflex.
  9. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    #9 nerodino, Apr 14, 2009
    Mine were originally pop riveted with a thin piece of rubber on each of the flat parts that touch the underside of the bonnet. I have had them powder coated and refixed as was.... and they are tight up against the underside but i guess with use they will gradually work loose and start flapping. Then i will just glue between the rubber and metal.
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Originally riveted, but a common reattach is to use sheet metal screws
  11. Nemo4
    Nemo4 Rookie
    Sep 2, 2006
    34
    You've all been generous with your time and suggestions (and even your conjectures as to what I meant in my post!). Thanks for your help. To be more precise, it is in fact the portion of the drip tray that was originally "glued" to the underside of the engine cover that has come loose. I'll try to find the proper fixative (Thanks to Mister Schumacher for his suggestion of Sicaflex) here in California, but if anyone else has a recommendation on that score, I'd appreciate the additional help.
    Again, thanks to all you lovers of these superb cars.
