Loose hose (cooling system) | FerrariChat
Discussion in '348/355' started by 914, Jun 22, 2025.
  1. 914
    914 Formula Junior
    Aug 17, 2014
    301
    Belgium
    Maarten
    This morning upon inspection of my engine bay, i came across a loose piece of piping, running from the top of the inlet manifold to the big tubes against the firewall.
    Any idea what the function of this hose is? There is no leak as apparantly somebod tried to plug it ...
  2. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    I'm guessing that pipe is what stops your coolant system blowing up when the engine is heating up.... That's why the tank is called an "expansion tank".
    Might be a bad move to block it. That top pipe (9) is probably one of the hottest parts of the system before it is cooled down by the radiators.
  3. lanab
    lanab Formula Junior
    Feb 21, 2016
    510
    Stockholm, Sweden
    It's a return hose, don't block it
    Qavion likes this.
  4. 914
    914 Formula Junior
    Aug 17, 2014
    301
    Belgium
    Maarten
    Ok, so i guess that will mean a new upper pipe against the firewall because the connection for the hose is definitely broken off .
  5. Rifledriver
    37,072
    That hose allows air pockets to return to the header tank where the air belongs.
  6. m.stojanovic
    m.stojanovic F1 Rookie
    3,215
    Serbia - Niš
    Miroljub Stojanovic
    Does your heater work?
  7. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    286
    That's no uncommon. You can drill the hole, tap it and then screw in a brass barb fitting. Easy job with the engine out. More fiddly with it in (but not impossible)
    914 likes this.
  8. 914
    914 Formula Junior
    Aug 17, 2014
    301
    Belgium
    Maarten
    Engine has to come out anyway, because the car has been in storage since 2013 ;) Ok, it has been started every couple of months, has been moved around, etc... but hasn't been registered or went for a decent drive since...
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Damaged by a poor reinstall of engine likely
