Loose Outside Mirror..,, | FerrariChat
Discussion in '360/430' started by psb1013, Aug 15, 2018.
  1. psb1013
    psb1013 Karting
    Feb 4, 2017
    137
    The passenger side outside mirror on my 430 is a little loose. I noticed that it’s already screwed down very tight. My dealer told me that the whole mirror assembly needs to be replaced. ($$$). Is this correct?
  2. shifter
    shifter Formula Junior
    Apr 8, 2004
    625
    Danville, Ca
    Joe
    I had the same problem, I unscrewed the 3 exterior screws to separate the outer mirror assembly. Inside are a couple very small Phillips screws into a soft plastic doughnut shape boss. Those small ones were loose, so I tightened them up and put a small dab of silicone on them to help them from working loose again. This fixed the problem for me.
  3. Jonathan White
    Aug 9, 2018
    11
    Cotswolds, UK
    Jonathan White
    As above, its a 15 minute job to remove the three outer torx screws and tighten the x3 internal small phillips screws - rather than using silicone I removed each in turn & used some red threadlock before screwing back in & tightening.
  4. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    I had some broken plastic where the 3 inner screws attach. I epoxied the areas and re-screwed. All good but I don't fold my mirrors in any more as this stresses the those 3 tiny inner screws.
