Loose rubber Strip in Front Wheel Arch on 575M | FerrariChat
Discussion in '456/550/575' started by Akula, Mar 26, 2014.
  1. Akula
    Akula Rookie
    Dec 7, 2009
    28
    Hi guys, tried to look through forum but couldn't find anything on this. Both sides of my 575 have this problem, specifically it's the rubber strip closest to the front bumper, about 10" long. They both held on only by the bottom edges and the rubber strip is rubbing against the wheel when moving. Has anyone had the same problem? How did you fix it? Thanks in advance for any advice!
  2. Modificata
    Modificata F1 Rookie
    Apr 27, 2003
    2,654
    Hampton, England
    Andy Rasool
    I have exactly the same problem on my 456M on one side. I have not fixed it yet but will do over the next week or so. I'll update on what I find!
  3. Akula
    Akula Rookie
    Dec 7, 2009
    28
    Thanks! I have tried to "push" back into the front panel edge but keeps popping back out.
  4. 308 GTB
    308 GTB F1 World Champ
    11,722
    New Jersey
    Barry Wolinsky
    #4 308 GTB, Mar 26, 2014
  5. GTS Bruce
    GTS Bruce Formula Junior
    Oct 10, 2012
    804
    Orchard Park NY
    Bruce Roche
    I would skip the rivets and use 3M super weather strip adhesive. GTS Bruce
  6. 308 GTB
    11,722
    New Jersey
    Barry Wolinsky
    I used that adhesive alone the first time around. Two years later, at Pocono, they popped loose again.
    They should have been secured that way at the Factory.
  7. Akula
    Akula Rookie
    Dec 7, 2009
    28
    Thanks for the advice guys! Will give the adhesive a go as a start.
  8. tazandjan
    39,175
    Barry's 550 sees service at Daytona, so sees speeds a lot higher than most Maranellos. He needs the extra holding power of the rivets.
  9. 308 GTB
    11,722
    New Jersey
    Barry Wolinsky
    Terry, when that rubber gasket herniated out of the slot at Pocono Raceway, it started flapping against the fender. It sounded like my bicycle when I was a kid and I clipped baseball cards on the wheel forks to flap against the spokes.
    I pitted in and pulled the gasket out figuring it was a $175 part that I didn't want to lose on the track. Turns out it's a bargain. Only $4.50 at Ricambi!
