Loose steering column on Scuderia's? | Page 3 | FerrariChat
Discussion in '360/430' started by Bp's 08 Scud, Jun 16, 2011.
  1. MATEI GHELESEL
    Nov 26, 2017
    19
    vancouver
    MATEI GHELESEL
    I did yes. what a relief! I also had the outer spherical ball joints removed and inspected to be sure they don't have excessive wear. the rears were bad and needed replacing but the fronts were OK. my Ferrari dealer had me freaking out thinking I needed new shaft or possibly rack......just had to tighten the H nut ! boom!
  2. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,828
    SoCal
    Edward
    Subscribed
    Sent from my 16M
  3. MATEI GHELESEL
    Nov 26, 2017
    19
    vancouver
    MATEI GHELESEL
    sure did yes. got it off my lift last nite and took it for a burn. MINT condition!
  4. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    509
    New Jersey
    How much should you turn your nut and will you always get a dash light?
  5. MATEI GHELESEL
    Nov 26, 2017
    19
    vancouver
    MATEI GHELESEL
    pretty sure that's a yes on the dash light....as far as turning the nut, I've read that at least 2 turns.....but mine required 3. it's a bit of a feel game, so start with 1 turn try it out on the road and then iterate until it's good to go. be mindful that you should be able to tighten with one hand only, you don't need to reef on it ! some of the previous chats have the correct torque spec posted, so I recommend you go thru the old data.
  6. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    Reviving an old thread. I believe I have developed the same slight steering looseness. I tried to turn this H bolt and it wouldn't budge... I wonder what I'm missing. When I hear some getting 1/2 turn or even multiple turns, mine wouldn't give any :-(
  7. CoreyNJ
    CoreyNJ Formula 3
    2,385
    New Jersey Shore
    #57 CoreyNJ, Dec 7, 2020
    on my 2009, I thought I might get away with the tightening of the nut, but I had to order the shaft with the u joints, about $2000 USD. I'm told it's 15 minute install. My mechanic will do it Christmas week when hopefully my new exhaust get installed. In my case, I think it was the use of slicks by the previous owner for his track days that caused the wear. I only have about 2 or 3 degrees of play, but with steering (and brakes), I will never cheap out on having it perfectly correct.
  8. fotostars
    Feb 6, 2015
    345
    Bay Area
    I should have also specified, this is on a 360. I don't see a steering angle sensor there...
  9. replica469
    replica469 Rookie
    Jun 13, 2021
    4
    Kenneth Lim
    Hello everyone, I am a few months old owner of a California'12 from Singapore. I am quite intrigued by this thread.
    I used to own a 2 year old Maserati Ghibli. It had a funny play in the steering. Over the course of two years of ownership, the dealer changed the steering rack & I changed many of the control arms/anti roll bar, as well as numerous alignments. Never really sorted out the problem & sold it.
    Now driving the California, I find a similar play in the steering (towards the left always feels a bit more loose) - frustrating. Not sure if it is due to the crowning in the roads but my other german cars audi/macan don't seem to have this problem.
    I wonder if this wonderful fix to tighten the column will also apply to my model?
    https://www.scuderiacarparts.com/part-finder/ferrari/california/oe/345/2647/49652
    Picture above is a diagram of the steering column.
    I might consider changing the steering column as a last resort too.
    Thanks in advance and take care during this period.
    Warmest regards.
    Kenneth
  10. bzubi
    bzubi Karting
    May 7, 2007
    138
    NOVA
    Bashar Zubi
    Would the Launch x431 be able to do the above?
  11. MichaelMatic
    MichaelMatic Karting
    Dec 19, 2020
    165
    Raleigh, NC
    Michael D
    Bump from the dead!
    I’ve been working in the pedal box and have the lower steering column cover currently removed. I’m wondering exactly this. Can the x431 reset/calibrate this?
  12. vr4henry
    vr4henry Karting
    Jan 21, 2019
    116
    Henry
    I reset with a Foxwell NT630 - I think the x431 is generally more capable
    MichaelMatic likes this.
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,754
    England
    Mark
    Yes, it can.
  14. RedTaxi
    RedTaxi F1 Rookie
    3,312
    New Zealand
    Glen
    My 430 had the same problem. But steering wheel movement was the same as the movement at the shaft through the floor. I dug into the front trunk till I got to the rack which can be adjusted for freeplay. Be careful you don't over do it if this is your issue or the car will continue round a corner when you let the steering wheel go. This may not be every ones problem, but it solved mine.
