Loosened tensioner too much and broke it. | FerrariChat
Discussion in '348/355' started by Eric C, Aug 8, 2015.
  1. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    #1 Eric C, Aug 8, 2015
    No idea how this happened. A simple alternator repair turned into a broken tensioner housing. Following a post on here, it said to turn the bolt counter clockwise. Well, I turned it about 5 turns and it blew its guts out.
    How difficult are these to swap out?
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Did you loosen the locking nut first?
  3. Eric C
    11,136
    St. Louis, MO
    Eric
    I loosened the nut on the pulley. Is that what you mean?
    The pulley never moved.
  4. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    #4 johnk..., Aug 8, 2015
    Yep. What I meant. Can't diagnose from a distance but my guess would be that some how the tensioner mechanism was frozen up, not allowing the idler to move. Take it all off. Get it welded or replace.
    WOW! Ricambi wants $400 for a new one. Euro spares has a used one for $115.
  5. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    When i did mine clockwise released the belt tension ( backed the pulley down ) and counterclockwise applied the tension
    1994 ferrari 348 spider , third owner purchased may 2013 w/ 27804 miles
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    GT Car Parts will hook you up.
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #7 Wade, Aug 8, 2015
  8. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    #9 SoCal1, Aug 8, 2015
    You beast !!!
    Sorry to here
    You need to really loosen the not in the center of the pulley quit a bit
    They do lock up a little with corrosion. Right tightly lefty loosey is backwards on that.
  10. Eric C
    11,136
    St. Louis, MO
    Eric
    Thanks fellas. I found one on ebay for $49 shipped.
    Anyone know the procedure for removing it?
  11. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Remove nuts and washers.
  12. Eric C
    11,136
    St. Louis, MO
    Eric
    Ha! That easy huh?
  13. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
  14. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Another option is to weld it.
  15. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    back out the 3 studs to remove it.
  16. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Be sure and save the old one, or offer it up here. That's an easy fix for a competent welder so no reason to toss the old part.
  17. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    `competent TIG welder. It is all aluminum.
  18. Eric C
    11,136
    St. Louis, MO
    Eric
    Uh yeah, I just removed the nuts and realized the studs need to be removed. Is there a right way to do this?
  19. jssans
    jssans Formula Junior
    Jun 1, 2005
    839
    St. Louis
    Josh
    Totally sucks to do with the gas tank not removed. I removed the studs & destroyed the threads while removing them. I bought new studs & used double nut method to put them back in. https://www.youtube.com/watch?v=8qYKMtb3Jpo
    Maybe the double nut method could work for taking them out. Just so little room to work with.
  20. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    The tensioner is revers to what you think i think you were tightening it and it broke as said above. When i changed mine i did the same thing but realized my mistake befoe that happened. Thats too bad.
  22. jssans
    Jun 1, 2005
    839
    St. Louis
    Josh
    I would replace the bearing while it's out too.
  23. Eric C
    11,136
    St. Louis, MO
    Eric
    Yeah, that top one was a sob. How did you remove your studs? I don't even think I could get vise grips on that top one.
  24. Eric C
    11,136
    St. Louis, MO
    Eric
  25. plugzit
    plugzit F1 Veteran
    7,794
    Redondo Beach, CA
    Bruce Bogart
    If you remove the pulley you may be able to get it out without removing studs
    I've been lucky enough to do it that way
