Loosened tensioner too much and broke it. | Page 2 | FerrariChat
Discussion in '348/355' started by Eric C, Aug 8, 2015.
  1. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    I removed the pulley nut, but the pulley didn't budge. I didn't put much muscle behind it. Did you use a pry bar?
  2. jssans
    jssans Formula Junior
    Jun 1, 2005
    839
    St. Louis
    Josh
    I used thin vice grips to remove the studs. This of course ruined the studs.
    Small quarter turns at a time. If there is a better way I would do it. But with the gas tank in I don't think there is enough room.
  3. plugzit
    plugzit F1 Veteran
    7,793
    Redondo Beach, CA
    Bruce Bogart
    Pry bar against the bolt thru pulley
  4. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    MaterMech wrote up a procedure on page 4 of my thread. He's the one that was able to remove the bracket. I don't think he removed the studs, but I could be wrong. He did have to remove the alternator and the pulley though
    - Tom
  5. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    If you remove the pulley you don't have to remove the studs.If your this far you should replace the pulley anyways so its o/k to pry it wont take to much for it to come off.
  6. Eric C
    11,136
    St. Louis, MO
    Eric
    Is the Pulley/Bearing one assembly?
  7. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    It depends on the year of your car.The later cars you cant just change the bearing.The bearing is part of the pulley.
  8. Eric C
    11,136
    St. Louis, MO
    Eric
    Hmm, mine is a 97.
  9. Eric C
    11,136
    St. Louis, MO
    Eric
    Not looking forward to crawling back under there. I need a lift bad.
  10. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    You wont know till you take it off.I've changed two on a 98 and a 99 and both the bearing was part of the pulley.The bearing alone is $30.00 and complete pulley is $120.00.
  11. Eric C
    11,136
    St. Louis, MO
    Eric
    Woohoo! Stuck a prybar up there and gave it a gentle wack and the pulley came off! The assembly pulled right off. Thank god!
    Just waiting on parts now.
  12. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    I would try having it welded, lucky I have a local shop that's very reasonable. They repaired my full titanium STi exhaust for $25 when a hanger tore off :)
  13. Eric C
    11,136
    St. Louis, MO
    Eric
    I already bought the part and my welder is a hour away.
  14. Eric C
    11,136
    St. Louis, MO
    Eric
    #39 Eric C, Aug 11, 2015
  15. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    You have the old style pulley were you can replace the bearing.notice the snap ring.bearing is easy to match up should be no more than $30.00
  16. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    you should of matched it up its like i told you its a nothing special bearing..$30.00 cdn is what i paid thats like $20.00 USD now..lol
  17. m.stojanovic
    m.stojanovic F1 Rookie
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    I wouldn't mind paying the higher price of a good quality bearing like SKF. The "MT33" suffix means that it has higher quality lubricant inside, good for up to 120C. Cheaper bearings would have standard lubricant good for up to some 90-100C.
  18. emac
    emac Formula Junior
    851
    upstate SC
    ernest
  19. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    That Is SKF .i don't use cheap bearings.
  20. Eric C
    11,136
    St. Louis, MO
    Eric
    So, when I install the tensioner. Can I install it without the pulley attached so that I can get to the bolts easier or will I need to install it completely assembled?
  21. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    Here is what I suggest. Now that you have all that space, double nut and remove the studs. Replace them with long bolts. Then you can assemble the whole unit.
  22. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    I have always put it in fully assembled. It's a PITA, but that's the way to do it. I pull the studs and then thread them in. If you replace the studs with ones that accepts an allen key you can get them in and out easy and yet retain the advantage of a stud.
  23. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    guy's you don't need to pull the studs.just push back the bolt that holds pulley there is enough room to get the pulley on.but if you want to pull the studs all the power to you.
  24. Eric C
    11,136
    St. Louis, MO
    Eric
    #50 Eric C, Aug 15, 2015
