Losing Spark | FerrariChat
Losing Spark
Discussion in '308/328' started by gt1nick, May 9, 2011.
  1. gt1nick
    gt1nick Karting
    Jan 25, 2010
    193
    DCA/PBI
    Nick
    So, after months of having the car in storage and knowing about my ignition problem it has come time to revist the issue. I have a 78 GTS with an electromotive set up and it's of the opinion of myself and my mechanic that without a doubt I'm losing spark. I've tried getting in touch with Electromotive directly, but no one seems to answer the phone. Any suggestions on how to diagnose? Or get in contact with electromotive themselves?
    Thanks,
    Nick
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    what do you mean specifically by losing spark. The electomotive set up is based/modeled on a GM style ignition system and I have seen one loose signal from the pickup sensors vibrating in their cradles too much which sometimes results in random spark loss. Next thing is to check for a good ground and loose wires. But without knowing more of the symptoms I don't know what else to tell you.
  3. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    most probably, your fault is not one of the electromotive ignition...
    the system is flawlessly working if set up right
    check all wiring
    check battery +/-, cut off switch, chassis ground etc.
    check TDC pick up (as said above)
    check current to the coils !
    check all grounds, especially those from the coils to the frame !
  4. gt1nick
    gt1nick Karting
    Jan 25, 2010
    193
    DCA/PBI
    Nick
    Trigger wheel is warped. Ordered a new one and plan to have it installed once it gets in. My next question is if its a pain to adjust to get the right clearance from the sensor. Or does it pretty much bolt straight up and very little adjustment is needed?
    The wheel was actually rubbing against the pickup sensor.
  5. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I had no problem with mine, just put it on. Use loc-tite on the set screws and try to get them equally tight, going around alternating tightening them a little at a time, like you would lug nuts. But Nick's trigger wheel was nice and snug, so I can't see how one set screw could push the whole thing off axis very easily.
    Birdman
  6. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    #6 ME308, May 13, 2011
    wow...never heard of that...should not happen...who installed that ?
    the alignment is pretty much straight forward
    see pic
  7. gt1nick
    gt1nick Karting
    Jan 25, 2010
    193
    DCA/PBI
    Nick
    #7 gt1nick, May 13, 2011
    It was on the car when I bough it from a fellow F-Chatter and worked fine (I gave the car a good 3000+ miles of Italian tune ups with no problem). However, performance started to degrade late last year. I googled the problem and the symptoms of having a warped wheel, almost to the "T", described my problems. Also, after talking with Electromotive, they agree that this is likely the issue. Everything else checked out.
  8. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Nick,
    The system came from Nick Forza. You can always contact him if you are having any problems. The timing wheel on your car was a special wheel that Nick provided because the "stock" timing wheel would not line up with the sensor and sit fully on the damper. If the replacement from Electromotive does not sit correctly, either contact Nick or use a spacer under the mount to get the two to line up.
    When you install the ring, be sure that you Lock-tite the screws, and do not overtighten them so as not to distort the ring. If you can, once the wheel is in position (and you've verified that the engine is running properly), drill a small indent in the damper at each hole to keep the ring from moving. Also, it sounds like the set screw on your sensor loosened up and the sensor moved. The sensor does sit close to the teeth, but there should be an air gap between them which should be set with a feeler gage to the recommended gap.
    Hope that helps. Also, you have a PM.
    Steve
