348 - Loss of power/misfire 1/4 | FerrariChat
348 Loss of power/misfire 1/4
Discussion in '348/355' started by RC2211, Nov 3, 2023.
  1. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    Can someone give some guidance.
    I was another day at the car meeting and ppl get around and start to ask me to accelerate.
    After some revs I shut off and walk around.
    When I come back to start, 1/4 light was on.
    Car was not running right. I drove home.
    Car doesn’t not go over 3k rpm. Complete dead. looks like a 4cc car.
    Someone have any ideas?
    Car has no cats.
    last code that I got was misfire cylinder 4
    I Check the ignition coil, removing the cable a put a little far from it. first time that I test had a big sparks, second time none, third time small sparks
    Now I order crank position sensor.
    Anyone had similar issues before
    thanks
  2. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    There are so many things it could be in these ageing cars, looks like you are starting in the right place. Sometimes its simple other times its symptoms of age.
    I had a faulty relay which would cause one bank shut down. Took me a while to work out what it was because it didn't happen with regularity, it was so random.
    RC2211 likes this.
  3. Qavion
    Qavion F1 World Champ
    14,268
    Ian Riddell
    At least with the 348, you can swap components between engine banks. Cylinder 4 seems very specific, but I'm not sure one cylinder would stop your engine going over 3k rpm.
    Are your SLOW DOWN lights working on engine startup? What year is your car (2.5 or 2.7 engine management?) Does your catless car have thermocouple ECUs?
    RC2211 likes this.
  4. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    Yes the slow down light works
    My car is 1991. Yes it has thermocouples on both pipes. I personally remove the cats and installed those pipes
  5. Qavion
    14,268
    Ian Riddell
    Interesting. I wonder if a faulty Cat ECU can cause bank shutdown, but not illuminate the light. You could try disconnecting the RH Cat ECU (large) connector. I hear it will generate a fault code, but not a CHECK ENGINE light.
    I suppose you could carry out basic checks and faultfinding. e.g.
    check fuel pressure
    check spark plug condition on the RH bank
    interchange coil packs and amplifiers
    interchange Motronic ECUs
    RC2211 and BONNEFOND like this.
  6. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    I check spark plugs… and swap 3 for 4 but same results.
    I’ll swap coil packs / fuel pressure and interchange ECU . I didn’t know I could change those….
    Where is the cat ECU connector.
    What I think is strange is that even if I disconnect the battery when I plug back the check engine 1/4 instantly light up. It’s been hard to fire up.
    I’m thinking is the crank sensor fault. ( I order both)
    That’s what I going to do next.
    I’ll keep you guys update. Thanks for the tips
  7. Qavion
    14,268
    Ian Riddell
    I don't know if you can tell from this photo.... (LHS ECU)
    I don't know if you have to remove the wheel liner to get to the plugs.
    Yes, they should be identical. On the 348 and early 355s you don't have to worry about immobiliser programming.
    RC2211 likes this.
  8. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
  9. Qavion
    14,268
    Ian Riddell
    Disconnect the big plug on the thermocouple ECU, not the thermocouple.
    I mean for the right hand side.
    RC2211 likes this.
  10. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    Qavion likes this.
  11. Qavion
    14,268
    Ian Riddell
    Definitely.
    I guess it's best to interchange the coil packs. If that doesn't work, it could be the power module/amplifier (below the coil pack). Hopefully it's a coil pack as they are relatively cheap. Bosch 0221503407.
    Look for 12 volts on the middle pin of the coil pack connector (with the ignition on, car not running)
    RC2211 likes this.
  12. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    I really appreciate your help!
    I’ll try to swap the coil pack! Hope solves the problem.
    Yes I saw at eBay for $100
    I notice that the slow down light is not light on when I switch the key on as well. I have some electrical issue. My brand new alternator is dropping power when I turn the a/c on.
    I wanna make right before start the preject.
    I’ll turbo charger her! ️
    I’ll keep you posted.
    If you want. Follow me @ferrari_348ts
    Qavion likes this.
  13. Qavion
    14,268
    Ian Riddell
    Did you reconnect the thermocouple ECU plug?
    RC2211 likes this.
  14. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
  15. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    RC2211 and Qavion like this.
  16. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    I appreciate
    I swap power module/coils left to the right.
    Still the same I have no power on the right side no spark. I unplugged the wire to the right side and engine is running the same. I placed everything back.
    Come to the module inside and unplugged and plug back. But still the same.
    There is any fuse or relay that power the module?
    Qavion likes this.
  17. johnk...
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Have you checked for 12 volts to the coil primary?
  18. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    You mean to the coil it self? if is it! Has not power coming . As I mention if I remove the wire it doesn’t make any difference. That’s why I ask if there is any fuse that send energy to the module.
  19. Qavion
    14,268
    Ian Riddell
    #19 Qavion, Nov 7, 2023
    So you checked it with a voltmeter with the ignition key ON? The coil pack gets power directly from the ignition key. If you have no power on the middle pin, you have a wiring issue. There are no fuses/relays for the coil packs
    Did you have a good earth (ground) for your DC voltmeter?
    You should have interchanged it with the other one.
    The ignition power module gets power from the Bosch Motronic ECU behind the passenger seat. The Bosch Motronic ECU gets live battery power from fuse 18 ("Ignition/injection System Right Bank 1~4") and ignition power directly from the ignition key. No fuses/relays for the latter one.
    At this point, it seems like an ignition wiring issue.
    I'm guessing that English is not your native language, so it's important that we understand each other before continuing with the diagnosis.
    308 GTB and RC2211 like this.
  20. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    Thanks for you’re help.
    I end up taking the car to eletricis but he has not find anything ‍
    I test the connector that you mention. And both sides it has power.
    swap ecu’s and nothing happen
    Check fuses and they are good
    I start swap everything again from the left to the right.
    To make sure maybe was the ignition coil.
    End up that is not.
    Left side Engine works fine. Right side is death.
    Very frustrated
    Qavion likes this.
  21. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,051
    Atlanta, GA
    Steve D.
    how old are your spark plug wires? any arcing?
    Did you remove the spark plugs and inspect?
    crank sensor?
    RC2211 and 308 GTB like this.
  22. RC2211
    RC2211 Rookie
    Dec 30, 2018
    39
    Rodolpho C
    They are barely new .
    I remove and inspect today.
    But when I remove the spark wires and leave close to the ignition coil, was suppose to have sparks and it don’t.
    Crank sensor a didn’t change those yet.
    steved033 and Qavion like this.
  23. Qavion
    14,268
    Ian Riddell
    Did you reconnect the CAT ECUs?
    Did the electrician see that you had no spark?
    I guess the next logical step is fitting a crank sensor.
    RC2211 likes this.
  24. steved033
    Apr 12, 2017
    10,051
    Atlanta, GA
    Steve D.
    or the one on the passenger bank cam? (can't remember its function, actually)
  25. m.stojanovic
    m.stojanovic F1 Rookie
    3,219
    Serbia - Niš
    Miroljub Stojanovic
    The sensor on the right bank is called the "Engine Timing Sensor", aka Camshaft Position Sensor. This sensor sends signal to both ECU-s so it would affect both banks, not just one.
    RC2211 likes this.
