Loss power occasionally | FerrariChat
Discussion in '360/430' started by raywong, Apr 15, 2020.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Hi guys,
    My 360 occasionally goes into limp mode losses over 50% of power and makes loud muffled noise. It usually goes away when I restart the engine. Are there anything I should check?
    Thx!
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,016
    Isle of man- uk
    System voltage, battery condition, fan belt tension driving the alternator. Sounds like loss of volts
  3. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,129
    Calif
    Brett
    No slow down light?
  4. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    No warning at all. It starts normal, loud muffled exhaust tone and major power lost. It does not go away by keep driving. Engine must be restarted.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,016
    Isle of man- uk
    Connect a volt meter up to the power socket in the centre consol or buy one that plugs into the power socket. See what volts when it plays up
  6. redcaruser
    redcaruser Formula 3
    Apr 8, 2012
    2,428
    switzerland
    daniel
    Maybe the car is still in the cold start procedure and you are driving too early?
  7. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,129
    Calif
    Brett
    Engine ecu glitch?
  8. vrsurgeon
    vrsurgeon F1 World Champ
    16,619
    Charleston, SC
    Curt
    You know how hard it is to diagnose that with no video clip of it occurring or any other info? Could be any number of things affecting one bank or both. Maybe throttle failing and sticking shut..
  9. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I did checked the operation voltage is at 14v to rule out the alternator. It has not happened again for 2 days so lets hope it's just ECU glitch.
