Lost a wheel | FerrariChat
Lost a wheel
Discussion in 'Technical Q&A' started by mad dog, Sep 1, 2006.
  1. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    On a track day today, I was overtaken by my rear inside wheel. Felt as if it had jumped out fo gear first of all, then that I had lost all brakes, then that I had lost a wheel so pulled over to side of track at which point it stelled down and dragged alogn trakc for a bit before stopping, some 30 yards after fast corner this all happened on.
    It doesnt look as if too muchdamage done, quite a clean break of driver shaft.
    Now my questions are has anyone else had this? I have heard not uncommon experinece.
    What is expereince of mending, a quick look on ferrari parts web is mega expensive for the parts needed. Has anyone located any parts non ferrari?
    ta
  2. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    A mention of the year and model car would be helpful! :)
  3. BigTex
    79,379
    Houston, Texas
    Bubba
    And the car is a ............................???????
    Fill in Profile.......
    Glad you are OK......stock wheel/tire combos or did you have spacers?
  4. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    Andrew, we had a service client who had this happen a couple of months ago..........he'd swapped over to his track wheels and hadn't torqued the wheels up properly
    No drive shaft damage in this case but we did have to change the hub, lower wishbone and a few other bits...........on Mondials its the wishbone rather than the brake disc that hits the ground
    Can't remember what Ferrari you have but if its a Mondial I've got a big pile of used parts that should save you a few pounds :)
  5. zakeen
    zakeen Formula Junior
    Aug 29, 2004
    989
    Czech Republic
    What does that have to do with the question ;)
  6. Rifledriver
    37,089
    Again.... Don't have any idea what kind of car was involved but we have been seing that in the 308s for 2 reasons.
    1. They are all getting to be old cars.
    2. The rubber being used today is so superior to what was available when the car was built we are subjecting old cars to stresses they were never intended for.
    We as a club (in this area) have had so many wheel and suspension failures that it is the reason we do not allow racing tires in track events except on racing cars. We took a lot of flack for it in the 2004 National meet at Laguna Seca but we have a been doing a pretty good job of keeping cars in one piece.
  7. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    A prisoner escaped from a jail in the South some years ago and stole a car.
    In the course of attempting his getaway at speed, a wheel came off the vehicle causing him to ditch the car.
    The police reported when coming upon him, he was seated outside the vehicle singing:
    " You picked a fine time to leave me loose wheel"!
    Maybe a similar case here?
  8. BigTex
    79,379
    Houston, Texas
    Bubba
    Excellent point Bryan, I always think that when folks max out tire sizes to the "Biggest that will fit"!!!
    What was it Mike Hawthorn said: "Don't slip the clutch...slip the tires!!"
  9. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,594
    Gates Mills, Ohio
    Jon
    Is point #1 related to deterioration of bearings and suspension bits, or just that the design of a 308 hub isn't up to the stresses of superior new tires?
    I guess what I'm asking is whether I can do anything, from a maintenance standpoint, to prevent this from happening?
    Also I'm wondering if the OP may have been about a single-spline Testarossa - I've heard of those wheels coming loose if they're not checked. (I know of someone who had this happen here in San Diego.)
  10. Rifledriver
    37,089
    Both. If I was tracking a 308 I would be having them magnufluxed. Too many of them breaking. Same goes for front lower control arm mounting forks but I think pretty much everybody is inspecting those. Or at least they should be.
  11. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Did they make any changes from the 308 to the 328 suspension wishbones?
    I know there was some recall for something suspension arm related on early cars.
    For instance I know on my BB they are a multi piece I believe forged unit held together by bolts, on TRs they went to a stamped one piece wishbone.
  12. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    It's not clear what broke? The axle?
    Bill
  13. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    Sorry to miss out tipo. Still a bit pissed about this especially as I have been looking at spares prices! It is a Mondial qv 83, uses the same shaft as 308 but I have been told also happened with 328s I know.
    I was running it with 17” 348 rims and standard road Pirellis.
  14. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Brian,
    I am thinking about tracking my 308, big sticky Goodyear DS DGs, bars and springs; Should i be pulling the axle stubs for magnaflux?? (77 308 w/ 27k on the clock)
    Would a good shot peening of the stub help significantly. I have heard that the stub axle is a weak link, Do you have a rough service life guess for the part, how many track events or racing miles before replacement or magnaflux. I have no clue.
    Could you tell me a bit more about the front forks and what can be done to correct the situation. Darn, I had them off to do the bushings - wish i had known that they were a weak link and what to do about it.
    Mired in ignorance/inexperience, yet again,
    chris
  15. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    #15 mad dog, Sep 1, 2006
    I am left feeling thank F*** this didnt happen on the road. Although it stopped in a fairly straght line, it happened after the corner at about 70 mph. If it was 1/2 way through one without any run off could have been a different story. Will be checking those front mounts as well now!
  16. fatbillybob
    Aug 10, 2002
    28,982
    socal
    Well this has happened on just about every car ever tracked. People do not realize how much a properly torqued wheel can come loose from the pressures and heatcycling on a track. There is actually, often times warning but we ignor it. We think it is rubber pick-up or a thrown wheel weight. It is always wise to exit the track to check out any weird feelings. in the car. In this case we still do not know if the problem was: 1) loose wheel, 2) failed part. Mondial rear stub axle/hubs do have a history of problems and were recalled or upgraded at least once that I know of. So...if the tire passed the car my guess would be tire came off the hub. I have seen ferraris with broken hubs and usually the wheel hub is still bolted and the broken part allows the wheel to get shoved up on the bodywork and makes nice body damage too and is more likely to trap the wheel in the fenderwell rather than allow it to pass the driver.
  17. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Too much beer on a Friday night to get the calculator out, but I'm guessing more stress in the system than what it was designed for...
  18. fatbillybob
    Aug 10, 2002
    28,982
    socal
    Cool the picture came just as I posted. Looks like a clean break...no operator error. Amazing the wheel was flung out with almost no body damage.
  19. fatbillybob
    Aug 10, 2002
    28,982
    socal
    No I don't think so. The QV uses TRX of the day and was I think 16" 255 in rear but perhaps a bit less sticky than today but honestly the pirelli P zeros that are stock 348 tires are like marbles so I don't think extra grip is a significant force. FRom the look of mondials with 348 wheels vs mondial trx wheels I don't think the force by the modest change in offset does much either.
  20. Ricambi America
    Sponsor Owner
    Where did the caliper end up?
  21. judge4re
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Actually, it was a bit of a bad joke.
    Any part failure is because:
    actual stress > designed maximum stress
    I guess I was looking at too many failed parts today...
  22. Darkhorse575
    Darkhorse575 Formula Junior
    Mar 20, 2005
    634
    Pasadena, CA
    DJ
    Maybe its just my eyes but, could there be signs of rust along the leading edge of the wheel arch? The wheel well looks like it has see a few winters. If so, rust may be festering in other near by sensitive areas.
  23. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    The caliper sheered off the mounting on the hub, scattered pads and bits along the route but brake hose kept main body attached.
  24. DGS
    DGS Seven Time F1 World Champ
    71,815
    MidTN
    DGS
    It's been known to happen in various venues for various reasons.
    http://www.youtube.com/watch?v=MeI4R0ko7ns
    http://www.youtube.com/watch?v=7hwMwh8Am9o
    http://www.youtube.com/watch?v=iw2m2XJxUR4
    There have also been a rash of split rims in the ricer world -- wider rims with the drive points at the extreme outer edges may be the problem, there.
    It's amazing what you can find surfing youtube. Remember that joke about "my lug nuts take more torque than your honda produces"? : http://www.youtube.com/watch?v=wkS0our54YE
    (For some reason, I found this pretty funny.) :D
  25. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    So, what is the prudent course of action??
    Pull the axles every 10 track events and have them magnafluxed??
    Would shot peening significantly extend part life??
    Is there any other treatment, other than replacing with new, that would take care of this problem.
    The problem seems to have been mentioned often enough, that we should do something?
    curious,
    chris
    Daniel, is that the caliper, sitting on the lower controll arm??
