Lost all gear oil today, 1991 Testarossa | FerrariChat
Discussion in 'Boxers/TR/M' started by PA32Pilot, May 9, 2020.
  1. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    Day 6 of Testarossa ownership and while at a stop light lots of smoke coming from the back of the car so I immediately pull into the parking lot. Never a good sign to see this.
    Looked under and saw oil pouring out just above the driverside pre-cat. If you zoom in you can see the oil dripping.
    Had it towed home and removed the rear cover and exhaust and I can’t find oil anywhere. The top of the header ad pre-cat are soaked.
    I’m assuming it has to be this seal that let go.
    Am I correct? Anyone changed this out?
    Shamile likes this.
  2. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    I know gear oil preferred is Mobile 1 75w-90 but I use Redline MT90 in my Lamborghini and it really helped smooth out the gearbox. It is GL4 oil.
    Anyone use this in the TR? I have quarts of it in my garage.
  3. dwhite
    dwhite F1 Rookie
    If you're talking about #12, I doubt it as it's an o-ring. When I put Newmans diff carrier in my Boxer, they (one one each side) were petrified and there was no drips.
    I would gently spin the wheels by hand to feel for any binding and prey the carrier has not failed. That is the heart stopping moment in TR ownership when gear oil is pouring out the bottom of the car.
    Are both oil filters tight or an oil return line loose?
    Hope it's something silly, but that is a huge amount of fluid.
  4. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    Wheels spin freely, gears shift freely. I drove it to the parking lot after seeing the smoke and noticed no binding.
    It’s definitely not motor oil, it’s gear fluid you ca smell the sulfur.
    Only reason it stopped dripping was due to their being no more oil.
    First thing I thought was well that’s $20k in the first 50 miles of ownership [emoji23]
  5. dwhite
    dwhite F1 Rookie
    Fingers crossed for you.
  6. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    Removed gearbox drain plugs and there wasn’t 9L of fluid.
    Removed bell housing drain plug and there was maybe an ounce or oil.
    The flange seems to have a gasket? The bolts around it are wet.
    There are no holes in the gearbox. No metal
    Pieces were in the street. No metal now.
    They only place anywhere near where the oil was dripping is that are where the axles go into the gearbox.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    Look for cracks between the flange that you are pointing to and the CV joint flange
    Sent from my moto g(7) using Tapatalk
  8. versamil
    versamil Formula 3
    1,226
    Gaston, Oregon
    Brian Healy
    A flood of oil is NOT an o-ring getting hard.Even if it failed, oil wouldn't pour out like your puddle. Hard to believe the source for that much oil coming out, isn't immediately apparent. Certainly in 70K miles, Shamille did the replacement carrier?? I stopped driving my 15,000 mile car until I get time to do the diff.
    Shamile likes this.
  9. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Are you sure it's not clutch fluid?
  10. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    I never did do the replacement carrier. When it went in for the major, Gabe mentioned how smooth the car was and there wasn't any noise from the diff or any leaks.
    We already had the engine out, so he would have definitely noticed if something was a miss.
    Shamile
    Freeze....Miami Vice!
    Sent from my SM-G950U using Tapatalk
  11. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    OP stated that there wasn't any oil in the gearbox.
    Because of the "safe at home" in Florida, I didn't drive the car for 3 weeks. Not a drop of oil on the ground.
    This is as much as a mystery to me.
    Shamile
  12. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    The oil looks a little light and thin for 70w, that's why I thought I'd ask.
    Sent from my Moto Z2 Play using Tapatalk
    Shamile likes this.
  13. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Maybe because it was hot when it dumped out?
    That's the only thing I can think of.
    Shamile
  14. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    I cannot see any cracks. Inspected with an LED light and mirror.
  15. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Maybe refill the gearbox and just run the engine while it's on your lift. See if it leaks. If not, put the engine in gear, let the axle rotate and see if it leaks and where.
    Shamile
  16. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    I know right. I thought for sure I’d get it home and be like BINGO! Tomorrow I am going to refill and see if I can find where it is leaking from.
    What is the replacement carrier?
  17. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    No oil on my garage either. This really happened out of nowhere, I’ve driven the car less than 50 miles. Just one of those things that happens with cars.
    Shamile likes this.
  18. versamil
    versamil Formula 3
    1,226
    Gaston, Oregon
    Brian Healy
    I was just rereading your ads to see if you had mentioned anything about the carrier. My car runs fine and sounds fine too, but I've detected just a couple of weird noises, in the last two drives and figure it's just NOT worth the risk. I worked on Ferraris and other cars for twenty years, and can really pick up anomalies.
    For a puddle that big, that quick, something BROKE! When the carrier breaks, it seems to take out the side cover. This probably has a crack that's not quite visible yet.A little more disassembly, get the axle shaft out of the way, so you can really examine the top of that side cover.
  19. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Some Testarossas came with a bad batch of differentials that had poor welds. The welds crack and takes out the box.
    It's very far and few between and seems to affect cars from 87-89...at least that's where I see them from. When they fail, it's at low miles as it's a bad weld. I've not seen any Testarossa with higher miles fail.
    Shamile
  20. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    Where would it come from? Everything is dry except that spot. Even on the axle flange the top half is bone dry. Bottom half wet.
    On the inside there is traces of oil. Makes me think it is part 42.
  21. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    Gotcha. I’ve looked all over this area and there are no cracks. And the oil is very concentrated in one area.
    From looking at part diagrams if it’s the seal ring I can do it without removing the engine.
    However if it’s the seal ring the engine has to come out.
    Shamile likes this.
  22. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    The bell housing isn't too far from that spot. In the absence of an obvious gear oil leak, and considering the clutch is under pressure while you're at a stop ( your pedal was down I'm assuming) maybe the seal behind your throw out bearing burst and ran down. A quick way to check that is to look at your master cylinder - the brakes and clutch share fluid.
  23. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    Good idea, checked the master cylinder and it’s full.
  24. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Damn. Ah well, worth a shot. Good luck.
    Shamile likes this.
  25. PA32Pilot
    PA32Pilot F1 Rookie
    2,519
    Glendora, CA
    Jamie Kirk
    Before I start removing the axle and doing surgery I’m going to was a few days to see if someone who had a similar issue sees this thread. I’d had to get it all taken apart to find out I need to pull the motor. My other car is still on my lift in pieces so I can’t use it.
