Lost all gear oil today, 1991 Testarossa | Page 21 | FerrariChat
Discussion in 'Boxers/TR/M' started by PA32Pilot, May 9, 2020.
  1. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    As much as I love the TR for a long rod trip in 2020 that would not be my first choice. If you are going to do this there are other things I experienced that I would address too for your mum. I’d look in the fuse box to see if this is all up in good shape, alternator ,AC as well. Don’t get me wrong it was an amazing car to
    Do
    This in 1985, still likely possible in 2020 but with the heat going to Vegas etc. I’d check a few things. Still possible look:
  2. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    I’m replacing the AC system as it doesn’t work.
    Fuse box repair done with gold connectors.
    Vegas won’t be till winter for her she doesn’t go in the summer. This summer would be her beach trips.
    Natkingcolebasket69 likes this.
  3. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    Parts are starting to show up, they will be trickling in over the next week. Pauls new differential should be here today.
    I also have the lift being delivered tomorrow. I need to put the rear cover back on so I can reattach the motor mounts and move the car. I will then attempt to push the car on the lift tomorrow. I installed a new side lifting garage door opener last night for more clearance.
    Natkingcolebasket69 and flash32 like this.
  4. Natkingcolebasket69
    Happy birthday to your mum;)
    flash32 likes this.
  5. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    RifleDriver won’t sell me the parts needed to fix the limited slip since I won’t drop the engine.
    Anyone else help?
  6. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    Thanks. Going to dinner tonight.
  7. raysur
    raysur Formula Junior
    565
    So. Cal.
    Jeff
    Hi Jamie,
    What parts do you need from the stock differential?
  8. Natkingcolebasket69
    Eurospares or Ferparts - ferparts if they have what you need you could have tomorrow
  9. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    I’m not sure, going to disassemble the stock and reinstall parts into Paul’s this weekend.
    Someone commented parts we’re broke but I don’t know what. I’ll lay it all out here shortly.
  10. raysur
    565
    So. Cal.
    Jeff
    If you need stock internals you can have mine. I already timed my motor so I am moving onto the diff next.
    Zeff likes this.
  11. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
  12. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
  13. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
  14. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    why? take a strong rope, fix it to the upper frame, go under then engine and fix again on the other side at the upper frame
    yes
    with the worn out plates? or got somewhere good ones?
    he has new parts or used ones? if new parts then he knows why he not sell you. the parts are getting more rare and he not want to give parts away in the fact that they will get damaged soon again. but with used parts he could sell you. if you still need parts when I hopefully be back in my garage end of next month then let me know. otherwise still good luck and happy dinner tonight :)
  15. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    Took me 20 minutes to attach rear cover and motor mounts. It’s back on the ground and ready to be rolled out tomorrow AM so the lift can get installed.
    The worn out side plates are not attached. Hoping to source some and reassemble Paul’s differential. Are those spacers specific or different or all the same? I’ll take some detailed pictures tomorrow for you of the reassembly so you can tell me I did it correctly.
    Dunno, he just said he can’t support a repair being done incorrectly. Kinda insulting since I’m not half assing anything, if it can be done correctly without dropping the motor I am going to try. Others have successfully done it.
    flash32 likes this.
  16. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    Also I need to pull the bearing off and order new ones. I can’t find my bearing puller though.
  17. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    Moms birthday dinner, in a restaurant and no mask required. Big deal here in California. Everyone had to drive over an hour, we flew in.
  18. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    WOW
    your mom looks young :) when I compare with the guy with the glasses beside her ;)
  19. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    She does, found someone to put extensions in as she’s losing her hair. Turned 64 so she’s young, just unexpected health issues.
  20. versamil
    versamil Formula 3
    1,158
    Gaston, Oregon
    Brian Healy
    The bearing doesn't need a puller- there's holes to knock it out from the back side. Those TWO holes in your nice shiny new part are to put a drift through to remove the bearing. I suspect there's two holes in the removable side also.
  21. c4b4the04
    c4b4the04 Formula Junior
    384
    Northern Virginia
    Cassidy
    You don't need a puller. There are two holes in the carrier and you can tap them out from the inside. The races fall out of the covers once you apply oxy torch heat. Hope that helps. I bought my bearings and races online, not from a F car shop. Bearing numbers and races are common Off the shelf parts
  22. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    I thought those holes were a little too convenient.
  23. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    Awesome thanks. Going to disassemble the old one tomorrow.
    Plan on pulling the bearing tomorrow and getting the type so I can order them.
    A F Chat member was gracious enough to mail me a bearing press.
  24. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    xplodee likes this.
  25. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,903
    Troy, Michigan
    James
    Honestly, I’m impressed with all of this.
    don’t ever feel insulted by Brian btw. He’s an expert on these, but as with many experts, he never employs shortcuts and is entrenched in his methodology.
    Natkingcolebasket69 and GatorFL like this.
