Lost all gear oil today, 1991 Testarossa | Page 27 | FerrariChat
Discussion in 'Boxers/TR/M' started by PA32Pilot, May 9, 2020.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,159
    Canada
    Newman
    You’re not trying to duplicate space shuttle re-entry temperatures. 250 F should do the trick.
    348KYD and m5shiv like this.
  2. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    Just in time for Dragon launch
    flash32 likes this.
  3. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
  4. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    25 minutes at 450* and it didn’t go any further down.
    Letting everything cool and will freeze the plate and try a MAP torch on the bearing.
    Natkingcolebasket69 likes this.
  5. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Admire ur resilience! U got this!
    Have u considered any local shop at this stage to do it for you?
    Rose Red likes this.
  6. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    TestaDDS, m5shiv and Newman like this.
  7. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    A lot of FChat members have been very gracious with their time and all have said I can complete the job. Without them I wouldn’t be anywhere near where I’m at, Brian talked to me for almost an hour last night at 11pm explaining the measurements I need to get today.
    Yes if you look at it from start to finish it is very overwhelming and makes your head explode. But having such great people to walk you sage by stage makes it very manageable.
    I really have 2 parts left that are difficult. Preload and backlash.
    I am hoping to tackle preload this evening ad actually assemble the gearbox for measurements.
  8. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    turbo-joe likes this.
  9. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
  10. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
  11. Trahanm
    Trahanm Karting
    May 10, 2013
    73
    Rochester Hills MI
    Marc Trahan
    Sorry to say this, but a couple of observations:
    that much gear oil does not leak out that fast unless there has been a structural failure in the case. It is gear oil if you small sulfur
    next, that Is most likely the diff housing welds have failed, which results in side forces the transaxle case can not sustain, and it cracks. This course of events can occur without any noise it seems.
    I have a 91 and replaced the carrier at 8k miles as a prevantative measure Some years ago based on some part what I have learned on this forum.
    do not drive the car any further. Take a close look at the complete case.
    and last, When you get this sorted, only use a GL5 Level lubricant, preferably synthetic . GL4 Levels do not have the shear strength needed for a hypoid gear set
  12. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    New to the thread I see lol.
  13. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Only missed 26 pages !
    AtSomePoint likes this.
  14. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    I mean celsius, also have written C
    250 ° fahrenheit is about 120 °C and I think that this will be not enough. may be it will work but also may be the bearing will cool down fats before it is completly on. so better a little warmer.
    that would be then about 3.300 ° C ;)
    c4b4the04 likes this.
  15. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    m5shiv likes this.
  16. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    only the internals all all what is on the photos?
  17. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    All the internals for the limited slip. He bought a Ripper differential and didn’t need his old internals.
  18. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
  19. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    #669 turbo-joe, May 31, 2020
    when you have no play anymore and the diff is rotating easy you may go 1-2/100 mm less shim tickness. when you have a spring scale you may fasten this to a thin string what you put around at the diameter of the diff where the crown comes later and you may need then between 0.25 and 0,30 kg to turn the diff, so turning, not starting to turn because this needs more weight. 1/100 mm is about 0,15 kg. see that the diff will turn always the same, so not sometimes harder and sometimes less. also put oil on the bearings when testing.
    if you would have the special tool from ferrari then you need 0,18 - 0,20 kg.
    in the video it looks as if you already have some preload? when there is no preload and also no play then you kick the diff and it will turn alone a little.
    those feeler gauge shims are 1,65 mm? so positioned at 180°? then try first with 1,63 mm. but I think as you turn the diff that you have already some preload because it looks as if you use some force to turn?
    ripper differential? never heard about and also cannot find when I google
  20. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    #670 PA32Pilot, May 31, 2020
    Test #2.
    No gap LH
    1.47 mm gap RH
    My RH spacer is 1.55mm
  21. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    Ok so here is no preload and my gap is 1.7mm
  22. PA32Pilot
    PA32Pilot Formula 3
    1,816
    Glendora, CA
    Jamie Kirk
    So if I’m at 1.7mm no preload and use the .015 for roughly 22kg my spacer needs to be 1.68 spacer?
  23. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    there you have already preload
    this looks good, but sound not good. you put oil on? if yes and it sounds so then you also have some play? you have a possibility to measure the axial play? you see it is a fact of 1/100 mm
    you mean 0,22 kg I think and not 22 kg. and yes, 1,68 mm seems ok
  24. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,691
    Central NJ
    Dominick
    Coming in from left field here ..but would it be accurate to use one of those battery torque gauges from harbor freight and measure torque on axle nut .. 17 in pounds or so .. not sure if I got measurement correct ..but directionally I think you get where I am going ..maybe someone can give us some benchmark measures
    Sent from my moto g(7) using Tapatalk
  25. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,691
    Central NJ
    Dominick
