Lost all gear oil today, 1991 Testarossa | Page 33 | FerrariChat
Discussion in 'Boxers/TR/M' started by PA32Pilot, May 9, 2020.
  1. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,932
    romano schwabel
    this normaly can never be possible. but may be you edged the flange from the shaft a little. happens to me also sometimes. so try to put in this 1 screw until nearly tighten. then you can turn the shaft a little around this screw and all the other holes then are matching.
    normaly it does not matter how you put them in. the holes are all 60 ° apart.
  2. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    I’m an idiot and spending 12 hours wrenching straight and not eating took its toll.
    Ready for it? Don’t laugh too hard....
    The wheel turned because no half shaft was installed. All my dumbass had to do was turn the wheel to asking them and BAM!
  3. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    Car is down on 4 wheels. I just need to do clutch tomorrow. I’m confused on assembly of the clutch so I’ll tackle it tomorrow.
  4. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Congrats !
  5. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
  6. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    I put in the white silicone.
    Also did a small coach of silicon on back cover.
    Couldn’t have done it without ya. You helped me from day one. If we ever meet dinner on me.
    turbo-joe likes this.
  7. turbo-joe
    Apr 6, 2008
    8,932
    romano schwabel
    #807 turbo-joe, Jun 7, 2020
    no 1 and 3 are changeable, they are the same, only pay attention what is front and what is rear- but when you see it things go logic
    don´t forget the spacers under the no 2. it needs 3 pieces
    discs alignment: put all togehter that you just could turn the discs. then put the clutch housing on. as long as the discs can rotate free you can do this, a little playing. when then the housing goes nearly complete in you may fasten the 6 nuts. not until fini9shed, only about 1 half turn, then the next , and so on by rotating the flywheel. an dthis so long until they are tight. remove the housing again, fasten again those 6 nuts, put some grease on the shaft and the front of the shaft what goes into the liopt bearing an dput the housing on again.
    in this community here also other would help - but just now I´m still stranded in thailand ( covid 19 ) and so have much time. happy to help you. ;) but you also have great knowledge an fknow how to use a tool ;) and know what you do. not everyone will be so good and sometime severy help is useless then.
    then I will stop eating before we will meet 7 days to be really hungry :) :)
    m5shiv and flash32 like this.
  8. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    No. 1 has writing that says Flywheel side, I’m assuming that side faces the flywheel.
    No. 3 will also point the same way?
    I’m hoping I can help others. You made it easy giving me step by steps!
  9. turbo-joe
    Apr 6, 2008
    8,932
    romano schwabel
    right
    also right
  10. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    When you wake up hopefully she’s running!!
    Got a long bike ride in the AM so I won’t be starting till 1pm pacific time.
  11. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
  12. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    turbo-joe and flash32 like this.
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    Put a little lockite 518 on that case ..that is a common place to leak
    Sent from my moto g(7) using Tapatalk
  14. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    Mother F ing gosh dangit dang nabit son of a wild turkey!!
    Appears the mechanic who put the drain plug in last cross threaded it! As I removed it out came threads with it.
    Why oh why didn’t I remove this plug when I had everything apart.......
  15. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    I used ThreeBond on all machined surfaces.
    flash32 likes this.
  16. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Sorry dude. @Shamile any comment !
  17. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    I’m cleaning the threads left and I bought new drain plugs.
    I’m gonna fill it and test for leaks.
    If it leaks I gotta year it all back apart.
  18. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Fingers and toes are crossed for you. Can you use a Tap Lok or other insert ?
  19. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    Hard because you don’t have a straight shot. I have to remove bell housing again
  20. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    Bell housing removed.
    Engine mounts removed.
    Engine jacked up and working on repairing threads. Doesn’t look good. I’m sourcing a new back cover.
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    #821 flash32, Jun 7, 2020
  22. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Comment? If you had done your research you would have seen on my "For sale" thread, that the gear oil change was part of the major service. The bill is listed right there. Perhaps you should mention this to Jamie...oh wait, he knows this...he has all the invoices.
    Shamile
    Freeze....Miami Vice!
    Sent from my SM-G950U using FerrariChat.com mobile app
  23. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Jamie, isn't there a sort of "time-cert" rethread application for this?
    All drain plugs, I put copper anti seize, so this doesn't happen.
    Shamile
  24. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    ugh this situation just keeps getting worse. Thank goodness the owner is as patient and talented as he is. If another fchat member bought this with less skills and required a tech to expose these issues it would be a blood bath.
    m5shiv and turbo-joe like this.
  25. PA32Pilot
    PA32Pilot Formula 3
    1,813
    Glendora, CA
    Jamie Kirk
    I don’t blame you for anything FYI lol. Crap happens. Things go south. Life moves on.
    Yes, I just don’t like that repair. To do it right I would remove cover and at that point I’d just replace it.
    I found a NOS one for a very reasonable price on eBay. It’ll be here next week.
    For now I should have the plug sorted enough to test drive. I plan on driving 50 miles and draining fluid and screening it. Then driving it another 100 and draining oil and screening it. If no metal flakes show up then I’ll be happy.
    Car is ready, need to bleed clutch just need a helping hand.
    Oh and I am 1 QUARTof redline short of starting her up. I did the 9l to gallon conversion wrong lol.
    For now she sits until my 10g order of redline shows up.
