Lost all gear oil today, 1991 Testarossa | Page 5 | FerrariChat
Discussion in 'Boxers/TR/M' started by PA32Pilot, May 9, 2020.
  1. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Yes, those will remove the half shaft. Just bend flat the locking tabs first.
    I'm a little disappointed that I see Gabe put a tie wrap on the boot instead of the proper locking clamp. I had the proper ones in place. It must have come off when he did the wheel bearing.
    Shamile
    Freeze....Miami Vice!
    Sent from my SM-G950U using Tapatalk
  2. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    What's wrong with the clamps he used? Those are not what I consider tie wraps, maybe a miscommunication? Tie wraps to me are plastic.
  3. PA32Pilot
    PA32Pilot Formula 3
    1,795
    Glendora, CA
    Jamie Kirk
    How the hell do you remove those locking clamps lol. Never seen those
  4. PA32Pilot
    PA32Pilot Formula 3
    1,795
    Glendora, CA
    Jamie Kirk
    It’s a locking clamp
  5. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Look closely at the inner clamp...it's a plastic tiewrap!
    The outer one is the proper metal with the squeeze lock from the center of the clamp.
    Shamile
  6. ferralc
    ferralc Formula 3
    Sep 2, 2010
    1,971
    San Diego CA
    Fernando
    I thought they were zip ties too!!!
    I had to zoom in after reading Xplodee post
  7. PA32Pilot
    PA32Pilot Formula 3
    1,795
    Glendora, CA
    Jamie Kirk
    It’s the right clamp
    Shamile likes this.
  8. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    yeah, both inner and outer clamps are proper metal type. I'm on a huge screen right now so it's clear for me to see. Perhaps its less obvious if I were on my phone
    Shamile likes this.
  9. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    The plates that cover the the end of the bolts have to be bent flat. I used a large flat blade screwdriver with a dead blow hammer. Flatten the plate completely...then just unbolt the CV bolts.
    Shamile
  10. PA32Pilot
    PA32Pilot Formula 3
    1,795
    Glendora, CA
    Jamie Kirk
    Sorry, not those. The locking clamps
    Shamile likes this.
  11. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Ok...my bad...and apologies to Gabe lol
    The way the light caught it, it looked like a white plastic tie wrap. I was thinking....how did I not see that!
    Shamile
  12. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    And don't trust an install that uses lock washers instead of locking tabs like this! ask me how I know ;)
    Shamile likes this.
  13. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    You don't need to remove the boot to remove the half shaft. The halfshaft will unbolt from the gearbox as an assembly. The ends are are a rounded metal end that sits in a curved cup on the gearbox end.
    Shamile
  14. PA32Pilot
    PA32Pilot Formula 3
    1,795
    Glendora, CA
    Jamie Kirk
    Can’t get a correct grip with sock with the boot on. Interferes and I don’t want to strip the head.
  15. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,912
    romano schwabel
    #115 turbo-joe, May 10, 2020
    yes
    when the screws are away you can lift the drive shaft and fix it. then loosen the central screw and take away the flange. and then let yourself surprise ;)
    you not can use a socket.
    if you have a good open wrench you can loosen those srews. I wonder: all axle shaft screws until now I removed had allen heads ;)
  16. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Use a ring spanner. Don't mess with the boots if you don't have to. You'll have to go find the proper clamps all over again.
    If you do, you have to cut the clamp in the "loop" where it pinches. Use a metal snip for that.
    Shamile
  17. PA32Pilot
    PA32Pilot Formula 3
    1,795
    Glendora, CA
    Jamie Kirk
    K. Give me 45 minutes I’ll have it off
  18. turbo-joe
    Apr 6, 2008
    8,912
    romano schwabel
    will wait for the result :( :)
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,652
    Central NJ
    Dominick
    I step away for a little while and came back to alot of posts .
    Sent from my moto g(7) using Tapatalk
    Natkingcolebasket69 likes this.
  20. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    TR forum always great read;)
    turbo-joe likes this.
  21. PA32Pilot
    PA32Pilot Formula 3
    1,795
    Glendora, CA
    Jamie Kirk
    Got it off but I can’t get it out of the way. Do I need to remove it on the wheel side also?
  22. V4NG0
    V4NG0 Formula Junior
    694
    Charles Edward Cheese
    Mine is on diff #2—happened before 30k miles IIRC. It’s an early 1986.
  23. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    I can't remember but see if you can try elevating the suspension by placing a floor jack under the brake rotor hub and lift slowly. See of that creates some room. Of not, remove the other side.
    I redid the CV joints awhile ago but wasn't trying to remove one side only.
    Shamile
  24. tvu
    tvu Formula 3
    1,310
    Southern California
    Trieu
    For Orange County, you can have Larry from Ferrari Tech in Orange, CA, or Randy from RMT Motorsports in Yorba Linda work on it.
    I've had good experiences with both.
    Sorry to hear of the trouble.
  25. PA32Pilot
    PA32Pilot Formula 3
    1,795
    Glendora, CA
    Jamie Kirk
    Is there a way to disconnect the flange from the shaft?
