Lost Forward Gear | FerrariChat
Lost Forward Gear
Discussion in 'California(Portofino)/Roma(Amalfi)' started by Richard Sam, Dec 13, 2021.
  1. Richard Sam
    Richard Sam Rookie
    May 7, 2019
    4
    Pittsfield Massachusetts
    Richard Samale
    2015 Cali T 5k miles, took it out today to top off gas and put away for winter ( Western Mass ). Able to find reverse and park, no neutral or forward, so cant even push car back into garage, stopped and started multiple times, used FOB, opened and closed gas cap, etc
    Any ideas. Thanks !!
  2. DrWex
    DrWex Rookie
    Aug 23, 2019
    6
    Saint Louis, Missouri
    Stephen Wexler
    I have a 2015 Cali T. I had the same thing. It turns out the right paddle shifter stopped working. So could never get it in gear but still could reverse. They flat bedded it to a Ferrari tech who confirmed it was the paddle shifter. Not covered under powertrain warranty. They replaced the paddle shifter and $4,000 later it was working fine and continues to be fine.
    Not sure if 2015 was prone to this problem but that could be it.
  3. SLViper1
    SLViper1 Formula Junior
    Mar 25, 2014
    767
    Nashville/Destin
    Steve
  4. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    What happens if you pull both paddles?
    There is a way to get it in neutral without using paddles. If the car will not go in anything but park and reverse, do the following.
    Start car and put it in reverse. Sit with the car in reverse and your foot on the brake. After 2 minutes or so, the car will automatically go into neutral to protect the clutch. Now switch off the car and within 3 seconds of switching it off, hit the start button WITHOUT starting the car. Car is now in carwash mode. You may need to release,the e-brake manually pu pulling the small handle down on the dash left to the steering column.
    By the way, if the car can go into park, the gearbox is fine. It's probably a faulty switch in the paddle.
    vjd3 likes this.
  5. DavidPutty
    DavidPutty Karting
    Jan 19, 2020
    121
    Del Boca Vista
    New spin on this problem.. My 2015 Cali T will not go into first from park when I pull the paddle. I get the attached message telling me to push the PS button. I push PS and it goes into first. Everything else is normal. Paddles seem to otherwise work fine (manual mode shifting, etc). Any ideas?
  6. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Go to your dealer. There's not much you can do yourself with odd problems like that.
    russellmcg likes this.
  7. Richard Sam
    Richard Sam Rookie
    May 7, 2019
    4
    Richard Samale
    Thank all for response, had no luck with car wash mode, but was able to limp the Cali onto a flatbed, battery replaced and dx with paddle shifter failure, broken relays i believe, cost of new paddles $ 5,500.00, the failure not a surprise given the feedback here, but 99% of the time i keep the tranny in auto !!!! No way the paddles abused or overused.
    David ill guess your Cali has early issues with the paddle shifters, heading to where mine ended. When i can ill post pics of the broken unit, and will keep all posted
    Thank all again.
  8. DavidPutty
    DavidPutty Karting
    Jan 19, 2020
    121
    Del Boca Vista
  9. miamiron
    miamiron Karting
    Sep 3, 2016
    82
