Lost "heat" in testarossa? | FerrariChat
Discussion in 'Technical Q&A' started by bpu699, Nov 2, 2008.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,808
    wisconsin/chicago
    bo
    Ok, flushed replaced the coolant a couple months ago. Went to turn on the heat, and got room air... Air condition clearly works, and blows cold. But switching it to heat just blows room air... odd.
    Any ideas? I rarely if ever use the heat... who drives these things when its cold? ;) For all I know it may have never blown warm...
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,352
    Most likely you've got an air lock in the heater system so you need to find a way to shift it. I'm not familiar with the Testa but if its like a 308/328 you may find heater pipes and mabe heater matrix(es) in the front bonnet area. Disconnecting a pipe there (carefully!) can be a good way to evacuate air from the system. You should be able to do this with the engine off.
    You may not get it all, but you should get enough to start the water circulating. Once you have it going you'll need to bleed the system again (and maybe top up the coolant) because chances are you will shift more air out the heater system which will end up somewhere else (radiator etc) and need to be evacuated.
    Other possibility is a stuck heater valve of course. Switch the ignition on and see if you can hear it moving when you operate the control.
    I.
  3. bpu699
    Dec 9, 2003
    17,808
    wisconsin/chicago
    bo
    Thanks...
    I did do a search for heater problems, and the issues seem pretty involved. I am 99% sure it worked before the coolant flush, so it may be an air lock issue...
    Any one have specific ideas on clearing it???
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,352
    Well, if you are lucky it may clear itself if you open the heaters up and go for a high speed blast. If you do manage to shift it this way take it easy as soon as you feel heat coming through because the air will have moved to somewhere else in the system. If it won't shift then, as I suggested, you need to find a handy hose that you can disconnect to let some air out the system.
    I.
  5. oldcoin
    oldcoin Formula Junior
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    It happened with mine exactly as you describe. Here is wah fixed it.
    Warm the car up, turn the heater on, go for a drive involving a few runs up to high rpm. Recheck coolant level in th eexpanion tank the next day. This sequence fixed mine in short order.
    Tony
  6. TimeClix
    TimeClix Rookie
    Dec 1, 2008
    1
    A really quick way to check if it is a circulation problem is to start your engine and let it run for a little while to get up to temp. Feel the coolant hoses before and after they enter the engine.. Like the inlet and outlet hoses to see if they are close to the same temp. Also feel the stiffness of the hoses.. They should feel harder if the coolant is flowing properly but very soft if its not. Very noticeable.
  7. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #7 Napolis, Dec 2, 2008
    Coolant leak or air lock blocking flow to heater core. Coolant is below heater core or Air blocked. If AC goes in a TR it's a *****. AC line runs through gas tank and uses it for a heat sink.
  8. bpu699
    Dec 9, 2003
    17,808
    wisconsin/chicago
    bo
    Thanks guys... drive it 50 miles and the heat came back on... probably an airlock somewhere...
  9. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,352
    Great - now check the coolant level & re-bleed the system - the air from the airlock just went somewhere else (either a radiator or the expansion tank usually).
