Hi guys lost the top part of my antenna(see pic) having a hard time locating one any help would be great,thanks Image Unavailable, Please Login
I would remove the antenna from the trunk, to prevent damage to the hole. Then with the antenna in hand I would check automotive radio installers to see if I could find suitable fittings. It looks like the mast is still there? I had a Porsche 928 an the mast was broken off and the local dealer did not know how to repair just repalce with an $800 part, so I found a mast replacement for $25. I know I replaced the mast but I repaired the antenna. Stephen
Exact same thinghappened to me. I think someone took it off . . .alright, stole it when I was parked in Montauk, NY. Regardless it's a Hannmann antenna. Probably get one in junk yard. I took mine out and put a rubber piece in the hole to prevent any scratching or water from getting in. Keep forgetting to look for a replacement, as I never listen to the radio or any music when I'm driving the car.
You can have a new electric telescopic antenna for 45 at Conrad http://www.monsterup.com/upload/1356871459861.jpg http://www.conrad.fr/medias/global/ce/3000_3999/3100/3190/3192/319288_BB_02_FB.EPS_1000.jpg Technical data: http://www.produktinfo.conrad.com/datenblaetter/300000-324999/319288-da-01-ml-Hirschm_Motor_Versenkantenne_de_en.pdf
If you cannot locate a parts supplier that will ship to you in Canada you could always purchase one have it shipped to me in the US. I will turn around and ship it to you in Canada. If this option is needed send me a PM.
No, you are missing a plastic insert, a chrome dome cap, and THEN on the top you are missing "the nut"... I had the same thing happen.....vandals I suspect. Impossible to get....search on Harada antennas, I think that's the brand.(No, Constance nails it! Hirschmann. see all that top hardware??).buy a whole new one and you'll have a spare (as do I!!)
