Cleaning out my garage - priced to sell. Prices do not include shipping Please PM me for photos of any items 348 crankshaft - magnafluxed and micro-polished $350 348 short block - great condition, needs rebuild $1,500 348 engine block w/ timing cover, oil pan - excellent low miles $1,000 348 block w/no head studs, one bad liner - great $600 348 oil pump - complete assy w/windage tray $250 QV heads - bare cracked, good for mock-up $250 355 throttle bodies with 348 adapters $1,500 348 timing belt idlers $100 348 AC bracket $100 348 alternator brackets $100 348 cranshaft sensors - pair $100 308 differential cover - art $100 QV/348 valve cover gasket set $50 Snap-on stud removal collet 11mm $50 348 bottom pulley Ring nut tool - $50 15mm QV Head nut tool $50 QV/348 copper exhaust gaskets - new $35 365 Crancase vent valve $50 308 shifter assembly $500 308 GT4 gauges - tach, oil, fuel $350 308/328/348 valve spring retainers and locks $100 308/328/348 oversize intake valves 31.3mm - new $250 308QV intake valves - used $80 308/328 QV valve covers - pair $500 348 valve covers - pair $500 308/328 QV engine stay $100 348 upper cam pulleys - welded and plated $400 348 lower cam pulley - long - welded and plated $100 348 water manifolds $250 328 E-brake lever $150 348 cam set - excellent, all four $400 QV cam seal retainer - pair - updated per TSB $100 355 crank timing gear $100 348 alternator upgrade kit - alt, harness, belt, bracket/idler assy - NEW $1,000 348 pistons, rings, pins, clips - excellent $400 308/328/348 "L" rods - Qty 8 $200 308/328/348 "A" rods - Qty 4 $150 308/328/348 "B" rods - Qty 4 $150 QV head studs w/nuts, washers $300 308 head nuts and washers $50 348 crank pulley $150 348 head gaskets - new $150 348 lower runners w/fuel rails $350 348 water pump $100 348 water pump assy $250 348/355 engine stand mount - side $200 348/355 engine stand mount - rear $200 348 oil pump chain - new $35 308/328 breather cam cap $50 308/328/348 cam cap $25 308 2V cam cap $25 308 2V distrib mount plate $35 355 cam sensor holder $50 400 door handle seals - new $15 355 oil pressure sensor $50 308 speedo sensor $50 328 speedo sensor $50 308 transmission pins/springs/balls $25 308 fuel filter assembly $75 250 Carrello side marker lights $75 348 timing chain - new $35 348 oil filter - new $35
