Lots of Engine Codes; Help wanted | FerrariChat
Discussion in '348/355' started by 355spider96, Aug 21, 2007.
  1. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    My CEL came on today and I pulled the codes and got:
    P0160----02 sensor ckt no activity (bank 2 sensor 2)
    P0154----02 sensor ckt no activity (bank 2 sensor 1)
    p1448--- manufacturer control auxiliary emission controls
    p0134--- 02 sensor ckt no activity bank1 sensor 1
    p1121 manufacturer control--- fuel air metering
    p1445-- manufacturer control auxiliar emission control
    p1115-- manufacturer control fuel air metering
    How could all of these come up at once, did something unplug or what kind of problem does this sound like? The only mod are/is aftermarket caps (I think hyperflows but not certain) Has anyone had experience with any of these codes? If so ANY help is greatly appreciated, thanks in advance.
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    When did this start? Imediately aftert the cat install??
  3. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    Not sure as I just purchased the vehicle (cats were already on there and im sure the prev owner knew about this but just cleared them long enough for it to be someone elses problem)
  4. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Don't fret my friend..... we are here for you :)...... I had five codes at one time, I troubleshot them, fixed them and have been code free ever since :D.
    Here is my chronicle from back in the day.... ;)!!
    gothspeed....cats,codes & CEL.... :D!
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Some 1996 and later 355 owners disconnect all of their O2 sensors (not recommended, by the way) because their systems have trouble with aftermarket cats.
    You've got to be careful that your previous owner didn't have a real problem with the O2 circuits such that they were overheating cats...or worse, that the timing belts weren't properly set after an engine service (prompting some cheapskate somewhere down the line to simply disconnect the O2 sensors).
    ...But yes, it looks like all 4 of your O2 sensors are unplugged.
    Plug them back in. Clear your error codes, and pay special attention to your cats for overheating. A cheap laser thermometer will help.
    Also, check to see if a prior owner disabled/disconnected your SLOW DOWN LIGHTS. This could become a very hazardous situation!
    To check, turn your ignition key to Position II (Run, not the Start position but the Run position). Do you see your CEL and SLOW DOWN LIGHTS come on briefly?
    Welcome to Ferrari ownership. Sadly, you may be learning firsthand that some prior Ferrari owners bought far more car than they could afford to keep up.
  6. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    Well I can see all 4 02 sensors plugged in(if you meant they werent physically plugged in) and it appears they are plugged in on those little green ECUs (thats the other thing, someone told me those little boxes look like they are out of a 95' and I have a 96' if that could be causing the problem) The slowdown light does work but does not come on or anything, its just a check engine light with the codes. So the timing belts not being properly set would cause the 02 circuit not to be working corrrectly???
  7. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    I noticed I have a lot of the same codes as you (1448, 1445, 1115) You mention something about a vescovini ecu? Is that the same as the catalyst ecu or where is that located? Also, I am getting 1448 so does that mean my bypass needs to be lubed like yours or was one thing causing ALL your codes?
  8. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Are your temperatures ok??
    water 190F
    oil 210F? I think :rolleyes: ;)
    Yes, because my car was not driven, the bypass valve soleniond was sticking. I used WD-40 and a 12v battery to "excersise" it.
    Next my thermal switch on top of the LH radiator was bad, causing a code.
    I replaced lots of vacuum lines.
    I also disconnected cleaned and used anti-corrosion "connector lube" on every connector I could reach.
    Make sure your radiator fluid reservoire cap are installed tight, along with your gas cap. These also cause codes.
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    OK. Good to know that all 4 O2 sensors are plugged in!
    Sorry, I'm probably not communicating very well. You should have TWO "slow down" lights and at least one (early 355's may have had two) separate Check Engine Light.
    I'm just going over some basics to be safe. When you first go to your 355 in the morning and turn the key to the Run position prior to starting the car, you should see a SLOW DOWN 5-8 light on the top left of your dash and a SLOW DOWN 1-4 on the top right of your dash.
    They should both flash on and turn off fairly quickly as the SLOW DOWN ecus do their self tests. Ditto for your Check Engine Light (CEL).
    However, some unscrupulous prior owners have been known to remove the lights behind those SLOW DOWN panels to fool prospective buyers into thinking that there's not a problem.
    So I just wanted you to verify that all three lights illuminate before you start your car (just in case).
  10. F355Bvc
    F355Bvc Formula 3
    Dec 4, 2003
    1,724
    Lawrenceville. GA
    Vince Canipelli
    '96 355 only has 1 slow down light!
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Oooops. Sorry about that.
  12. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    ok here goes..... I did not take any pics because I was too lazy.... hopefully tomorrow.... but here are the code defs:
    P1448 = catalyst bypass flap circuit....... check wiring, check the valve, check vacuum leakage
    P0160 = o2 sensor downstream catalyst (bank 2, sensor 2).... check the wiring, check the signal (0.97-1.05), check injector and wiring, check engine co hc emmision base..... HC<250ppm CO <1.1%
    P0134 = o2 sensor upstream catalyst (bank , sensor 1)... check the wiring, check the signal (0.97-1.05), check injector and wiring, check engine co hc emmision base..... HC<250ppm CO <1.1%
    P1115 = o2 sensor heater circuit upstream catalyst (bank , sensor 1)... check the wiring, check o2 sensor impedance continuity and value, check in diagnosis mode heating o2 (I don't know how to do that last one).
    P1121 = o2 sensor heater circuit downstream catalyst (bank 2, sensor 2).... check the wiring, check o2 sensor impedance continuity and value, check in diagnosis mode heating o2 (I don't know how to do that last one).
    P1445 = catalyst temperature vescovini... Range/Performance (plaus???,min,max), check the wiring, check vescovini ECU functionality, check thermocouple functionality.
    Hope this helps..................:)
  13. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    Thanks a million goth!!! I managed to take some pics of my vescovinis/that plug I told you about so whenever you want me to email them let me know.
  14. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Cool can you post them here??
  15. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    I tried a few minutes ago but am having issues with my software and will probably have to wait until the weekend if thats ok. If you get around to taking pics of your cat ecus and plugs please post them up, thx.
  16. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    #16 355spider96, Aug 24, 2007
  17. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    From what I can tell..... the connectors "just hanging" are the thermocouple plugs that should be in the ECU. The reason I say that is... they have the metal braid on them. I don't know what the ones plugged into the ECU are from. For reference the thermocouple plugs have two wires, the ECU plugs have three
    How many of the metal braid connectors do you see hanging?
  18. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    I only have the one in the picture with the metal braids that is not hooked up, but there is nowhere in the ecu to connect it to. Does your ecu have 3 plugs then?
  19. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    No, my cat ECUs have two plugs. I meant the number of wires going to each of those two plugs. The thermocouples (braided) should be plugged into the cat ECUs. I dont know what those other ones are. Follow the wires and see where each of the the "two" wire connectors go.
  20. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Are we taking bets that his prior owner plugged the O2 sensors into the cat ecus?
  21. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    I could unplug the bottom plug and then plug that hanging one with the braided wire (the one that goes right by the bypass valve) in, but then where would the one that is plugged in the bottom go?
  22. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    LOL....... I think you may be onto something..... :p.... the connectors are way different but maybe someone spliced two wire o2s in there..... that would be awefull.... :(!!
  23. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Dont worry about the bypass right now..... just find the LH and RH thermocouples and plug them into the LH and RH cat ecus!! How many thermocouples do you have??
  24. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    Those are plugged into the cat ecus, on the bottom plugs, but then there is nowhere for that plug to go with the braided lines, is that one supposed to get plugged into the cat ecu instead?
  25. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    Ok I went home to check everything. The LH and RH thermocouples are plugged into the bottom of the cat ecus like they should be on each side. The 02 sensors are plugged into their correct plugs. The only problem I think I have is I cannot find where the thermocouple plug from the bypass valve gets plugged into, where does that plug get plugged into? Thats the one thats hanging, if I can find where that one gets plugged into I think itll alleviate my probs.
