Lotus Help | FerrariChat
Lotus Help
Discussion in 'North Central - USA (MI, IN, OH, KY, WV)' started by indaville, Aug 2, 2006.
  1. indaville
    indaville Formula 3
    Oct 6, 2005
    2,309
    Louisville, KY
    I thought I would post this here because my question is a technical question about my Lotus and not a Ferrari. I thought maybe Doug, Adam, Steve, or Joey might be able to help.
    When the air conditioner is on and I am slowing the car down the engine is stalling. I can start it back up and it runs with no problems, no engine warning lights or anything. It seems to only happen when the air is on, but I suppose that could be a coincidence. I asked about this problem on the Lotus forum and several guys feel that my IAC (idle air control) valve needs to be cleaned or replaced. They say that the job is no big deal after you find and remove the IAC but it is a chore to get to that point.
    So should I attempt this job on my own or take it in to one of the guys on Bardstown Rd? I do not know that much about the mechanics of my cars, but I very much want to learn, my fear is I would do more damage on my own.
    Your thoughts???
    Matt
  2. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,426
    ky
    Adam
    I was thinking also it was you idle air control valve. It can get clogged up and the mechanism may get stuck close which would cause your engine to choke and stall. If it happens with your A/C on it might be due to the A/C putting a load on the engine and making the situation worse. If you want I bet I can fix it. I have done several in vipers. Typically the IAC valve is located around the throttle bodies.
    Also check plugs...they can tell you alot about what's going on inside the engine. But I bet you it has to do with the IAC valve. I would take good care of the car....people on bardstown...do ya trust them? LOL!
  3. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    oh, I forgot to also add to this....Matt...remember the strut incident? Hmm...Joey and Dougy touched it....LOL! ha! Just kidding...better watch out before these guys kick my ass.
  4. yasir
    yasir Formula Junior
    Nov 5, 2003
    352
    Matt,
    People on Bardstown road be fine ( been there and done it ) but they don't usually use the Petrolium jelly so it really hurts.....Adam seems like a knowledgeable person ( yes i know he doesn't like Ricers j/k ) but honestly if he can take on a Lambo heck he can fix this IAC issue..plus you can watch and learn more about your car if done by an enthusiasts esp 1:1 basis.
  5. indaville
    indaville Formula 3
    Oct 6, 2005
    2,309
    Louisville, KY
    Sounds like you are up to the challenge! I can try to help, I really want to learn as much as I can.
    Matt
  6. I would try fixing it myself first. Lotus uses a lot of GM parts. That sounds like what I would try first. Get a new one, let me know when you are getting together, I can supervise Adam and get him off to a good start showing him where your engine is located! You might look for a shop manual also, if it's available. It might tell how to pull up any codes that are in your computer.
  7. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    Ricer cars yasir? LOL! I like imports...just not "ricer kids" with lambo doors on their civics. LOL!
  8. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    Yes Joey can supervise...but don't let him touch anything....LOL! You can look but don't touch. ha!
    Well on a serious note Joey, I am getting a Gentry Crane with a 3 ton hoist! Yippie! Pulling my engine out of the diablo will be a sinch now!
  9. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    Wait until after Tuesday to do this. I am leaving for a little vacation tomorrow and I would love to sit back and watch you all screw up Matt's car some more:) I can then step in and help remedy the situation to get him home:)
    It actually sounds like an easy fix. 3 people and a 12 pack can probably fix it.
    Adam, if your garage is occupied with, we can use mine.
  10. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    just make sure you have A/C in there and food and drinks. I can't lower my standards when I work in a garage.
  11. That's great. If you need anything else let me know, I might have it. When your ready & need an extra hand, let me know.
  12. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    You can count on it bro!
  13. shmc930
    shmc930 Karting
    Jul 16, 2006
    76
    Louisville
    Steve Mc
    Sounds like a get together at Adam's house.
    When and what time?
  14. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Matt,
    My Esprit used to do that....I was told by an Lotus tech that the ECU needed to be reset....try unhooking the battery cables, wait a bit, and hook them back up...should reset the ECU. Worked for me !
  15. indaville
    indaville Formula 3
    Oct 6, 2005
    2,309
    Louisville, KY
    Thanks, I will try that. But because Doug, Joey, & Adam broke my strut on the boot I can't get to my battery until I get my new strut (sometime next week). Lotus put the battery in a tight spot!
    Matt
  16. SMWDave
    SMWDave Karting
    Nov 23, 2005
    169
    Panama City Fl
    David Smith
    What year is your Lotus?
    I have most all of the factory service manuals, and a 90 SE with a bunch of mods. If you need some info. I can fax you or whatever.
    I live in Florida but am orginally from ky. (Pewee Valley)
    I'll be there in a couple of weeks to take my nephews to the fair.
    I think i'm going to bring my 355 spider.
    I usually stay with my sister in Crestwood of hwy 22.
    The last time I was there I spotted a Esprit in a garage a couple doors down form her house. Is that anyone here?
    thanks
    Dave Smith
  17. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    Heck I live in Crestwood!
  18. SMWDave
    SMWDave Karting
    Nov 23, 2005
    169
    Panama City Fl
    David Smith
    Wow it can be a small world.
    Where in crestwood?
    Are you from there?
    I live in Panama City Beach now but grew up on Maple Ave in Pewee Valley.
    What kind of car do you have?
    Dave
  19. indaville
    indaville Formula 3
    Oct 6, 2005
    2,309
    Louisville, KY
    Thanks, I have a 2001.
    Matt
  20. silvergts1998
    Apr 10, 2005
    2,426
    ky
    Adam
    I am about 15 minutes from maple ave. Do you know the Hettingers?
    I have a Black Lamborghini Diablo.
  21. Are you talking about the red Espirt?
  22. SMWDave
    SMWDave Karting
    Nov 23, 2005
    169
    Panama City Fl
    David Smith
    Yes it's a red Esprit
  23. I see it driving downtown sometimes. That car has spent plenty of time at Harrods Creek Imports getting worked on. He's owned it for several years.
  24. SMWDave
    SMWDave Karting
    Nov 23, 2005
    169
    Panama City Fl
    David Smith
    Is Harrods Creek Imports " the " place for exotics in Louisville?
    Who else works on them?
    Is Bluegrass Motorsports the only exotic dealer?
    What about St Mathews Imports ?
    I went to High school with one of the owners sons (Doug)
  25. Harrod's Creek Imports is the same place that was Mooser's Garage. They work on some Jags, a Testarossa, but mainly Mercedes/Volvo.
    You went to High School with my brother, Mark. Doug had a 80 Z28 that he bought from a friend of mine. I drove that car all over your state back in the good old days.
