lousy radio reception | FerrariChat
Discussion in '308/328' started by yelcab, Feb 11, 2010.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    How come I get terrible radio reception (FM) with my stock antenna and a late model Alpine head unit? Is there a trick ?
  2. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    Yes, there is a trick. Bad reception can usually be cured by going into your trunk and following the thick lead (rather than the two power wires) from the antenna to the extension lead that runs into the car towards the stereo. Unplug the two cables in the rear and rub some steel wool to remove the corrosion on the male and in the female ends. Follow up with dielectric grease on both ends and reconnect.
    If the reception hasn't improved greatly, then you'll need to clean off the other end at the stereo. (The cord is essentially just a long extension from the stereo antenna lead to the antenna lead.) You can either slide the stereo out or try to get at the cable from behind.
    If reception hasn't improved at that point, the extension cord has probably come apart inside-- most likely in the engine bay from heat cycles and rubbing, and you'll need to buy another one (from a car parts store for about $6.) It's a bit of a pain to route it, because you need to remove some interior parts, but I just did this in a GT4 (which is harder than a GTB or GTS). It just takes a screwdriver, a wrench and an hour or so (depending on what is exactly in your route given the model and year.)
  3. sclja
    sclja Formula Junior
    392
    San Diego Ca
    Scott Cairncross
    #3 sclja, Feb 12, 2010
    If you dont find corrosion on the 328 antenna coax connection at the rear of the car you might find that it was never plugged all the way in. I used to install radios in 328's when they were new and I used to find them 1/2 way plugged in a lot. Is the antenna still the factory antenna? It should be a bosch autojet.... Let me know if I can help?
    Scott @ La Jolla Audio
  4. yelcab
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Thank you both. it worked !!!
  5. JV's89
    JV's89 F1 Veteran
    7,295
    Pittsburgh, PA
    You wouldn'nt happen to have any Bosch Autojets ( or any other semi-auto antenna) you would be willing to part with, would you?
