low idle after auto warmup | FerrariChat
Discussion in '308/328' started by mikemal7, Aug 16, 2020.
  1. mikemal7
    mikemal7 Rookie
    Nov 4, 2009
    49
    Hi Guys. Question for idle with a 1987 328 GTS (USA). Car runs well. Initial startup from cold up to 2000 rpm which settles down to 1000 rpm shortly thereafter. However, with subsequent driving, shutting off ignition and then restart , engine running stays at 500 to 1000 rpm and can stall out if I don't give it some gas. Once running and on the road, no problem and idles well. Any thoughts about what to check out?
  2. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,190
    Kingsport, TN
    Lawrence A. Coppari
    Take a look at your throttle position switch.
  3. Steve Magnusson
    26,739
    Easiest first diagnostic step would be to touch/"feel" the frequency valve (aka metering valve) during the bad running so you'll need an assistant (also "feel" it during the good running to calibrate yourself for how it should feel during engine running) -- it should always be vibrating/buzzing whenever the engine is running, so, if it isn't during the bad running that would indicate that the operation of the protection relay should be checked.
    If the bad running is very smooth, but weak, another relatively easy thing to do would be to confirm/deny spark on both banks.
    Good Hunting!
  4. Lawrence Coppari
    Apr 29, 2002
    2,190
    Kingsport, TN
    Lawrence A. Coppari
    My experience tells me that if it has tits or tires, it'll eventually cause problems.
  5. mikemal7
    mikemal7 Rookie
    Nov 4, 2009
    49
    Thanks for the input
  6. mikemal7
    mikemal7 Rookie
    Nov 4, 2009
    49
  7. moysiuan
    moysiuan F1 Rookie
    4,180
    Canada
    Might check the water temp sensor part number 125769 under the intake plenum. You can get at it with the oil filter off with a deep socket and extension and a bit of hand work to remove the wire connector. It provides input to the fuel injection system ecu. It is a simple resistance thermistor, but can get deposits on it that make its readings inaccurate.
  8. Steve Magnusson
    26,739
    That sensor is only present on your KE3-Jet with Lambda 328 (it's not present on a US version K-Jet with Lambda 328).
