Low lights don't come on | FerrariChat
Discussion in 'Mondial' started by bquan94545, Sep 12, 2012.
  1. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    I have a Mondial QV. When I turn on the switch for lights the headlamps
    swing up but the is no headlamp lit.
    I took the car to SF Ferrari for them to look at. They came to the
    conclusion I had a bad switch and wanted to order the switch
    from Ferrari. I took the car home and ordered the part from the Ferrari
    Exchange in Sacramento. They sent me the wrong item. I hooked it
    up anyway and everything seemed to work according to the book except
    no headlights. I sent the part back and told them it wasn't the correct
    part. They sent me a fresh one just taken off a Mondial of my model year.
    I hooked that on up and it still didn't fix the headlight problem.
    Anyone have any ideas???
    thx
    bruce
  2. porphy
    porphy Formula 3 Silver Subscribed
    Dec 9, 2009
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    Check grounds
  3. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,785
    This is actually how it should work (with the stalk in the uppermost position) ;)
    Do you mean:
    Case 1 = turn end knob with stalk in uppermost position = only parking lights come "on", headlight pods come up, all headlights "off"
    Case 2 = move stalk down one position = parking lights stay "on", but low beam headlights do not work
    Case 3 = move stalk to bottommost position = parking lights stay "on", but high beam headlights do not work
    Anyway, please describe what you get (or don't get) in all three cases.
  4. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
  5. Steve Magnusson
    26,785
    What version 1985 Mondial QV -- US or euro?
    I'm not hopeful that this will be an easy fix. Since the bulbs themselves (parking lights and headlights) are all doing the right thing = that's a good sign that the headlight switch assembly is OK and working correctly. However, since the pods (wrongly) come down in Case 2 and Case 3 = that hints that you have an internal short on your fuse-relay PCB (but I'll take a closer look at things on the schematic once I know if US or euro).
  6. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    MY OM says it's US. I've pulled the PCB to check for bad paths and burns but
    I found nothing.
    bruce
  7. Steve Magnusson
    26,785
    What is the 4th digit of your VIN -- "L" or "U" or ?
    I've done a little pre-looking and there may be hope for an easier fix -- one thing that I didn't know before is that on Euro Mondial QV the headlight pods don't come up with only the parking lights "on" (so there's more relay complexity added to the PCBA -- to both euro and US Mondial QV). As a first check, can you confirm that the relay in the bottom right corner ("relay for light lifting motors with low beams on") is a ...101 type relay?
  8. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    The fourth digit in my VIN is a "U"
    Relay "B" and "D" are 101 type relays. RH & LH lifting motor
    Relay"L" & "M" are 113 type relays. Low and high Beam headlights.
  9. Steve Magnusson
    26,785
    All good -- what about relay "U"?
  10. Steve Magnusson
    26,785
    Couple other questions:
    1. Did it: A) work OK and then went bad, or B) never worked right as long as you've owned the car?
    2. Have you checked ALL of the fuses? (The copy I have of the 1984-85 US Mondial QV wiring diagram is very poor quality, and I can't figure out how the headlight pods come up when only the parking lights are "on", but it does seem that there is a separate fuse for the headlight lifting motors when in the low beam mode or high beam mode.)
  11. fgcfire8
    fgcfire8 Formula Junior
    Jan 19, 2008
    459
    Montpelier Va
    Frank Castelvecchi
    There are separate fuses for low and high beams
    Check the bulbs too a voltage spike may have blown them--did that on an X1/9 years ago.
    And my middle child like to gave me a heart attack when she called me 15 min after prom let out before I found out she did not have headlights--had stalk in upper position--I trhought she had been hit lol.
  12. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    Relay "U" is a type 101
    The lighting system worked. I happened to check on it and that's when I found out
    nothing was working right.
    SF Ferrari found a bunch of bad grounds. They cleaned up what they could.
    Their tech found a short to ground through a relay. He removed the steering
    steering wheel and traced it back to the steering wheel column light switch.
    They wanted to order a new assembly. They are making them again in Italy for
    $1600. I refused service because I could get one from a salvage yard for much
    less. I plugged the one from the salvage yard in and I still have the same problem(better to be out $600 than $1600).
    Are you looking on Figure 10 of the wiring diagrams? My copy is a bit more legible.
    I'd be more than happy to copy my manual and mail it to you.
  13. Steve Magnusson
    26,785
    Yes, please do -- my email is:
    [email protected]
  14. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    Just a thought but maybe I can bypass this mess. I could
    wire a relay in parallel with the high beam and low beam relays.
    When they actuate I can have them feed the lift motor relays.
  15. Steve Magnusson
    26,785
    Can't comment unless I get a more readable copy of Fig 10 ;)
  16. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    fine, need an address of where you want it sent. I'll go and get it copied tomorrow and
    put it in the mail.
  17. Steve Magnusson
    26,785
    A good quality electronic scan (jpeg or pdf) would be OK, but, if you want to mail it (paper), send me an email, and I'll email back my mailing address.
  18. Steve Magnusson
    26,785
    The bad news is that I believe that they made a mistake on the US Fig 10 schematic as (the way the wiring is shown on Fig 10) the headlight pods should behave just like the euro version (i.e., stay down when only the parking lights are "on", and only rise when the low or high beams are selected). Consequently, this will be more guessing than certainty, but, IMO, the first thing to try is to put a different ...101 in the "relay U" position as described in your OM (on the schematic they call this same relay "relay v") -- I'd suggest using the ...101 relay presently in the relay R position (as this relay R is not used when the engine is not running). Please try that and report back if there is any difference, or not, in the three Cases.
  19. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    NO change.
    Case 1 pods up no light and parking lights on
    Case 2 pods down, low beam headlights on, parking lights are on
    Case 3 pods down, hi and low beam are on, parking lights are on
  20. Steve Magnusson
    26,785
    Why is it never the easy things ;) -- I'll need more information:
    Remove relay U (with all other relays in place). Measure the voltage between terminal 85 and terminal 86 in the relay U socket for the three cases (don't worry about what the lights or pods are doing):
    Relay U socket terminal 85 -to- 86
    Case 1 = ?V
    Case 2 = ?V
    Case 3 = ?V
    Replace relay U and remove relay D and make the same voltage measurement between terminal 85 and terminal 86 in the relay D socket for the three cases (again, don't worry about what the lights or pods are doing):
    Relay D socket terminal 85 -to- 86
    Case 1 = ?V
    Case 2 = ?V
    Case 3 = ?V
  21. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    Relay "U"
    c1= 0
    c2=0
    c3=0
    Relay D
    c1= 10.35
    c2= .05
    c3=.06
  22. Steve Magnusson
    26,785
    That's a bit of a baffling result for relay U so a little more there please:
    Remove relay U (with all other relays in place). Measure the voltage between terminal 87a and terminal 85 in the relay U socket and from terminal 87a to terminal 86 for the three cases (don't worry about what the lights or pods are doing):
    Relay U socket terminal 87a -to- 85
    Case 1 = ?V
    Case 2 = ?V
    Case 3 = ?V
    Relay U socket terminal 87a -to- 86
    Case 1 = ?V
    Case 2 = ?V
    Case 3 = ?V
    Also, can you please confirm/deny if there is a female metal terminal in the relay U socket at the terminal 87 position?
    (I apologize for groping a bit, but Fig 10 shows that Relay D should not change state unless Relay U changes state -- which does not match your result so that makes me doubt Fig 10 even more.)
  23. srephwed
    srephwed F1 Veteran Silver Subscribed
    Apr 29, 2012
    7,088
    street,md
    fred brown
    i know this is an old thread but this is my problem.mine is a euro version and is doing exactly the same thing as described.i never saw a solution.
  24. Steve Magnusson
    26,785
    For a euro, the relays have different names and different physical locations on the PCB, but the initial diagnostic strategy would be the same (the relay letters and names are from your 241/82 OM):
    Remove relay T "Relay for light lifting motors (with low beams on)" (with all other relays in place). Confirm relay T is of the ...101 type. Measure the voltage between terminal 85 and terminal 86 in the relay T socket for the three cases (don't worry about what the lights or pods are doing):
    Relay T socket terminal 85 -to- 86
    Case 1 = ?V
    Case 2 = ?V
    Case 3 = ?V
    Replace relay T and remove relay D "Relay for headlamps lifting motors". Confirm relay D is of the ...101 type. Make the same voltage measurement between terminal 85 and terminal 86 in the relay D socket for the three cases (again, don't worry about what the lights or pods are doing):
    Case 1 = ?V
    Case 2 = ?V
    Case 3 = ?V
    The good news is that the euro schematic makes sense for the three cases as described by the OM:
    Case 1 = turn end knob with stalk in uppermost position = only parking lights come "on", headlight pods stay down, all headlights "off"
    Case 2 = move stalk down one position = parking lights stay "on", headlight pods up, and low beam headlights "on"
    Case 3 = move stalk to bottommost position = parking lights stay "on", headlight pods up, and high beam headlights "on"
    If you can provide those 6 voltage measurements, it may yield a clue as to what is wrong.
  25. bquan94545
    bquan94545 Karting
    Aug 8, 2010
    111
    Pinole, ca
    bruce quan
    Relay "U"
    c1= 0
    c2=0
    c3=0
    Relay D
    c1= 10.35
    c2= .05
    c3=.06
