Low noses next year!..... | FerrariChat
Discussion in 'F1' started by Fast_ian, Jul 9, 2013.
  1. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    #1 Fast_ian, Jul 9, 2013
    Hey,
    An updated version of the 2014 Technical regs has just been published. (PDF available at the FIA site.)
    Of significance;
    That's a huge change; from 550mm down to 185mm. That'll give the aero guys some sleepless nights.....
    Cheers,
    Ian
    Formula 1's updated 2014 technical regulations: analysis - F1 news - AUTOSPORT.com
  2. Gatorrari
    Gatorrari F1 World Champ
    16,481
    Georgia
    Jim Pernikoff
    Finally, the era of the "anteaters" will come to an end......
  3. stever
    stever F1 Rookie
    4,673
    West. Wisconsin
    Steve R
    That's close to 30 years, isn't it?
  4. Gatorrari
    16,481
    Georgia
    Jim Pernikoff
    It began with Tyrrell's inverted gull wings, I believe in 1990-1991. I think that it was Bennetton that took the next step by connecting the two wings to make it continuous under the nose.
    It is ironic that in 1971-1972, March had done just the opposite with its "tea tray" wing that ran continuously above the nose! Ferrari's wings from late 1973 to 1980 were somewhat similar.
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,737
    Indeed, the noses were raised in order to reduce drag--and they took about 100HP of drag out of the cars at top speed by so raising the nose and directing the airflow out the pods.
  6. TifosiUSA
    TifosiUSA F1 Veteran
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    The Ferrari F2001-2004 kicked ass with low noses...beautiful cars too.
  7. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,672
    @ the wheel
    Andreas
    Cool.
    I'm thinking the look of the early nineties is back. Nice.
  8. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Some of the best looking cars. My favorite F1 car all time is still the '95 Ferrari 412T2.
  9. tifosi12
    Oct 3, 2002
    49,672
    @ the wheel
    Andreas
    Technikmuseum in Sinsheim
  10. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,875
    Atlanta
    John!
    I'm expecting some interesting shapes on the top side of noses directing airflow.
  11. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,285
    Fresh off ScarbsF1:
    http://scarbsf1.com/blog1/wp-content/uploads/2013/07/2014_draft.jpg
    Brief summary:
    • Front wing reduced front 1800mm to 1650mm wide
    • Nose tip centered at 185mm high
    • Front Bulkhead maximum height 525
    • Chassis height maximum 625mm
    • Vanity panels still allowed
    • Engines now 1.6l V6 turbo, Direct injection, fuel flow limited, 15k max RPM
    • Energy Recovery systems to add +150hp from Kinetic and Turbo harvesting
    • Race Fuel limited to 100kg
    • Gearboxes to have 8 forward ratios, those ratios are fixed for the season
    • Single central exhaust pipe exiting 17-18.5cm behind rear axle line and 300-525mm high
    • Last 150mm of tail pipe must point 5 degrees upwards
    • No bodywork behind the tail pipe axis
    • No lower beam wing
    • Space still allowed for Y75 winglet (monkey seat)
    • Top rear wing a little shallower
    • Minimum weight 690Kg
  12. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    What about the ridiculously ugly/stupid snow plow front wings? Are they going away or are we forced to look at those monstrosities for another decade?
  13. Ferraripilot
    May 10, 2006
    17,875
    Atlanta
    John!
    Well, there's good news and bad news for this. The front wings will be 15cm more narrow.
    The good news is the front wings will not be quite so complicated looking with massive amounts of downforce right off the bat, and this could be the case for quite some time really. The reasoning is that the rear downforce is taking a considerable hit with the deletion of the beam wing and no more sealed diffusers. This in essence means the front wings will not be nearly as complicated simply because they cannot be that complicated due to the rear end downforce being insufficient to balance such a complicated front wing structure with tons of downforce.
    The bad news is that downforce in general is taking a huge hit next year.
    Engine torque control (because there will be much more torque with these engines) and clever ERS harvesting maps will be the 'trick' for 2014 is my guess.
    I expect the cars to look pretty simple to begin with really. We may see some clever sidepod interpretations but I'm not expecting anything overly ground breaking.
  14. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Need to poke deeper, but I'm not sure that's quite correct....
    5.1.4 says "Fuel mass flow must not exceed 100kg/h"
    Anyway, scanning the doco's released yesterday, a couple of other things kinda jumped out at me (Bold is new)
    5.1.2 now reads "engine cubic capacity must be 1600cc [+0/-10cc]"
    Previously, it said "engine cubic capacity must not exceed 1600cc"
    Maybe someone was going to do a *smaller* lump?......
    Further;
    5.1.7 All engines must have 6 cylinders arranged in a 90deg "V" configuration and the normal section of each cylinder must be circular.
    Just added;
    "All six cylinders must be of equal capacity"
    :eek:..... Again, wonder if someone was gonna play games here.....
    Cheers,
    Ian
  15. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    This seems to be quite a lot of changes at what is a rather late stage in the design process.
    I suspect that a lot of work has been wasted. Another example of F1 "cost cutting".
  16. bigodino
    bigodino F1 World Champ
    13,163
    The Netherlands
    Peter den Biggelaar
  17. Ferraripilot
    May 10, 2006
    17,875
    Atlanta
    John!
    cheaper. less cog swapping throughout the season.
  18. piolaxo
    piolaxo Formula Junior
    Feb 24, 2012
    644
    Bay Area
    Salvador
    So probably the solution will not suit Monaco, right? The ratios will try to fit most of the
    circuits, but the really fast ones and the really slow ones will be compromised, right?
    So Monza and Monaco will be among them, and maybe Silverstone and SPA.
  19. Ferraripilot
    May 10, 2006
    17,875
    Atlanta
    John!
    #19 Ferraripilot, Jul 9, 2013
    It's going to be interesting how teams deal with this. The 100kg/hour is further stipulated into measurements below certain rpm ranges too, so there are going to be detailed calculations showing how often a car is going to be below 'XXXX' rpm ata certain circuit vs above 'XXXX' rpm where 'Z' more fuel is allowed to flow, thus allowing engineers to better calculate fuel requirements for a race distance. 100kg/hour seems to not really be a problem so much as the question of how are they going to take advantage of that alloted fuel flow when they are below a certain rpm where flow is limited to the point where they couldn't burn 100kg/hour if they tried. Seems like a sliding scale to me. Fuel line reservoirs will probably be outlawed, I believe this was brought up before.......
    note:
    regulation 29.5
    No car is permitted to consume more than 100kg of fuel, from the time at which the signal to start the race is given to the time each car crosses the Line after the end-of-race signal has been given. Other than in cases of force majeure (accepted as such by the stewards of the meeting), any driver exceeding this limit will be excluded from the race results.
  20. Ferraripilot
    May 10, 2006
    17,875
    Atlanta
    John!
    I don't think it's going to be as much of an issue as the ERS system and its additional torque it will bring to the drivetrain at much lower rpms will be able to more than compensate for the previous gearboxes ability to swap gears. Clever ERS and engine mapping will replace gear swapping, the top teams will no doubt have a different map for every circuit.
  21. Gatorrari
    16,481
    Georgia
    Jim Pernikoff
    I doubt if they use all 8 gears at any given circuit. At some they'd use first thru seventh, at others, second thru eighth.
  22. teak360
    teak360 F1 World Champ
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    Except for Newey. He'll whip out his mechanical pencil and slide rule and have a new design in a couple of days...
  23. werewolf
    werewolf F1 World Champ
    11,022
    goodbye
    GREAT news :) some of my all-time favorites, from that era.
  24. tervuren
    tervuren Formula 3
    Apr 30, 2006
    2,469
    I'm glad to see front wing width reduced. I think the cars will look better with simpler smaller front wings.
  25. furoni
    furoni F1 World Champ
    Jun 6, 2011
    14,009
    Vila Verde
    Pedro Braga Soares
    These are great news, current f1 cars are butt ugly, and fron wings are plain stupid...i really hope cars will look a lot better next year....and less downforce will be good for driver skills
