News
360 Low speed suspension travel
Discussion in '360/430' started by albkid, Aug 5, 2019.
  1. albkid
    albkid Formula Junior
    Jul 1, 2016
    317
    Jim
    In reading about the low speed suspension adjustment on the new C8, the specs indicate a switch that will raise the nose to help clear parking lot speed bumps.
    Is there anything that can be done to a 360 to duplicate this feature?
    I have wondered whether using the "sport"setting might help, but I have yet to try this out... for an obvious reason.
  3. 24000rpm
    24000rpm F1 Rookie
    I guess you are talking bout the a feature that 458 has. and lambos have them as well. pretty standard after those generation of cars
    to add something like that to a 360/430 needs a lot of work including a replacement of the front shocks, i believe.
    I'm 360 Canuck likes this.
  4. albkid
    Jul 1, 2016
    317
    Jim
    Thanks. I was expecting as much.
  5. Skidkid
    Skidkid F1 Veteran
    Rossa Subscribed Owner
    Aug 25, 2005
    6,504
    Campbell, CA
    John Zornes
    There are a number of companies that make a lift kit. Some you only change the springs, some the shocks too. I have never used one but KW makes one.
  6. one4torque
    one4torque Formula 3
    May 20, 2018
    2,008
    Houston
    One4torque
    Just get the C8 ;)
    I'm sure you could retrofit some suspension parts.......
  8. Need4Spd
    Need4Spd F1 Veteran
    6,061
    Silicon Valley
  9. albkid
    Jul 1, 2016
    317
    Jim
