Low/uneven Idle vacuum - is this an "issue" ? | FerrariChat
Discussion in '348/355' started by Gottaloveit, Mar 15, 2018.
  1. Gottaloveit
    Gottaloveit Karting
    Jul 12, 2012
    52
    Hey guys,
    Had occasion to hook up a gauge to the throttle related vacuum lines at the back of the engine (1994 2.7). Results surprised me but are they an "issue" ?.
    Have read about the low idle vacuum on these cars due to the individual throttle bodies etc, but was a bit taken aback to see 8inHg on the left bank and 5inHg on the right bank !!. The central vacuum line down to the vacuum canister was showing 7inHg.
    Is this normal or is it something I need to look at and get sorted. ?. What do we think.
    Car runs fine tho !.
    Cheers all.
  2. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,014
    PA
    Kevin
    I'm no guru on the topic but 355's don't even pull enough vacuum to drive the brake booster. This is why it is driven off bank 2's cam shaft. Are you sure your gauge is accurate?
  3. salbrech
    salbrech Karting
    Dec 20, 2013
    107
    this pressure is normal on a ITB- motor, have the same readings on my F355, 5.2. On my car, with the vacuum cannistor charged on Idle only, its not even possible to open the secondary air injection valve.
    Ferrari on some ITB-V12 cars installed a cam driven vacuum pump, but I guess not on the F355. On the F355, the break booster runs with an electric motor driven oil pump. As far I know, the F355 is the only V8 with ITBs, all other V8 have common throttle bodies.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    First versions of 355 (and 328ABS/348) all have Teves brake master cylinder with electric pressure pump with no booster assist.
    Later (97+) have Bosch master cylinder, and vacuum assist via a vacuum pump running off one of the cam shafts on 5-8 bank, because the engine vacuum is not enough to drive the boostetr.
  5. salbrech
    salbrech Karting
    Dec 20, 2013
    107
