Lower and Alignment Quote | FerrariChat
Discussion in '360/430' started by Drestless, Apr 13, 2015.
  1. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    Hello,
    I've been quoted of approximately $1,000 to lower and align the suspension of my 2001 Ferrari 360 to stock height. The previous owner raised it by an inch (not sure why).
    Around $400 for the alignment plus more if shims are needed and the rest is for lowering it.
    Does this look ok? Thanks!
  2. Alleykat
    Alleykat Karting
    Apr 2, 2009
    165
    Houston,Tx
    Alex
    That's insane! Is the 360 on stock coilovers? It's easy to lower it just turn the bottom seat with the spanner wrench. Firestone offers lifetime alignments for $150. You can go in for an alignment anytime you want for that flat fee. I've taken several high end cars there.
  3. Loz997S
    Loz997S Formula Junior
    Aug 26, 2007
    988
    Bay Area
    Laurence D
    I was quoted about the same to lower and align an F430 for what it's worth ($1000).
  4. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    That's the same reaction I had but it was explained to me that the coilovers needs to be removed to compress it then it can be adjusted to lower. I've seen this in a thread somewhere. I'm just not certain about the $600 labor for it is correct.
    Also, alignment. I did try to send it a known tire shop and their willing to do $100 but they had no idea when I asked them if they had the shims if it ends up being needed. They don't even know that shims are needed.
    This is why I called an indy Ferrari shop instead and they know shims is potentially needed without any researching.
  5. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    How much lower did you go from stock height? Mine's actually from a modified height lowering to stock height.
  6. tazandjan
    39,174
    They should be able to compress those springs without removing them. That sounds kind of high to me. I would have thought around $500 would have been about right. You definitely want it done by somebody who has done this before because of the shim adjustments for camber and you want them to have a supply of shims.
    Maybe one of the pros can chime in on compressing the springs.
  7. Rifledriver
    37,104
    I have done it quite a bit and I'd never consider doing it for $500. I wouldn't be terribly excited about $1000 either.
    To start with you have a car that very inadvisably got raised an inch. How am I supposed to know what kind of idiotic stuff he did to accomplish such stupidity? Next it needs corner weighting. That takes time and requires expensive equipment someone needs to pay for. Realignment? That's going to be a mess for the same reasons.
    A grand is starting to sound cheap.
    Firestone for an alignment? That a good one.
    These jobs are a lot harder to do correctly than most know.
    My other half has never worked on cars and she has a very appropo saying. "It's always easy for the person who does not have to do the job".
  8. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    Sounds very involved. Is the case because it's been raised so we need to lower TO stock height? How about for lowering FROM stock height, the same headaches?
    Thank you sir.
  9. tazandjan
    39,174
    Brian- Thanks for the insight. Guess the compressing and lowering are more involved than I thought. Come to think of it, there would be a lot of fiddling to get both ride height and camber correct, since changing one changes the other.
  10. Loz997S
    Aug 26, 2007
    988
    Bay Area
    Laurence D
    Didn't do it. Too darned expensive. But I can see why you've not really got a choice if the car has been raised. Strange thing to do.
  11. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Having adjusted my own ride height, camber and alignment several times I'd be inclined to say that to pay $1000 to have it done properly, by someone who knows what they are doing, is a fair price.
    As Rifle has described above, there is a lot of time and effort (and specialist equipment) required to do the job right.
  12. Rifledriver
    37,104
    You go back and forth a lot getting ride height and corner weight correct. A race car that weighs 1500 lbs and very accessible shocks is easy but this is a different story.
  13. Rifledriver
    37,104
    The bigger the changes the more time spent putting it all back.
  14. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,762
    US of A
    Michael
    Brian is right. He is the only one to reference corner balancing. I can assure you that corner-balancing is an art. $1000 is regular retail.
  15. London
    London Karting
    Aug 29, 2009
    189
    London
    A friend of mine and I spent two days raising the front of my 360 to stock height. I did this mainly because I enjoy working on my car rather than to save money - actually, the Ferrari indy I use would have done it for free as part of a follow-up on previous work done, but I chose to have a go myself.
    I am most definitely not an expert but it looked very hard to do this with the shocks still on the car, so I didn't even consider doing it that way. There was quite a bit of trial and error and each test involved removing the shocks, compressing the spring, adjusting the two nuts, reinstalling the shock, and going for a drive to let the suspension settle. Also adjusting the nut on one side will affect the height on both sides, which complicates attaining a level ride. There's probably a smarter way of doing it than the way we did it but I don't think it'd ever be a 1hr job. And of course we only adjusted the height - I've already booked a proper four-wheel alignment with a Hunter machine at a specialist for next weekend (he usually charges £165 iirc, he's done it several times before on my car, and yes he knows about & has a large selection of shims).
  16. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    #16 Drestless, Apr 13, 2015
    It actually makes sense on some extent. No rubbing around on speed bumps or going sideways going off a plaza to the streets. This might be the reason why it was raised by a bit.
    Plus, it doesn't look really higher unless you take a good look at it.
    I could have lived with it (I almost did) because it's not too obvious and no need to really slow down or go side ways on bumps BUT seeing other stock 360 photos convinced me start searching around to bring it back to stock height. It will look meaner because of the lower stock stance.
    Since I'm getting this done, any ideas how lower I can go from stock height? I may want it to be lower than stock as well in the end. : )
  17. hangarsixco
    hangarsixco Formula Junior
    Oct 10, 2010
    396
    S. California
    Chris
    #17 hangarsixco, Apr 13, 2015
    I have lowered my 360 to CS specs 110mm Front 130mm Rear. It is a very time consuming job. I had made 110mm and 130mm spacers to use on the chassis locations Ferrari notes as ride height location marks. You will need to perform a handful of tasks before you start to even lower the spring perch. Crucial to remove the sway bar end links. Doing it right with scales had taken me 4 Saturdays (4-6 hours each day) to get it right. This is at a shop with everything needed to perform the job. It took me a bit longer because I used sand bags in the drivers seat to simulate my weight when in the car at 190lbs. you can drop the drivers side a 1/4" or more with just you in it. Everytime I drove the car after making an adjustment the cars height changed a few MM. Took a handful of minor 1/4 and 1/2 turns to get it right.
    Turning the spring perch is the easiest thing in my opinion it's everything else that's a time consuming pain in the ass.
    Kind of a waist because now i'm planning on changing wheels to the center lock F430 challenge wheels and changing out springs. So ill be at it again in the near future.
    A $1000.00 is cheap and if you can get it done right for that price don't hesitate go for it.
    Firestone for alignment? that's laughable. You need someone who understands suspension set up not just how to operate an alignment machine. Getting it right is crucial or the car is going to ride and handle like crap!.
    Also how do you know the car was raised an 1" if the old owner put on bigger wheels with low profile tires and did not match the factory diameter then you may be seeing the cars fender gap bigger then stock and throwing you off on the ride height.
    A member here Fatbillybob, recommended Westend Alignement I spoke to Chris, very nice guys out of Gardena.
    https://plus.google.com/105013652567737037073/about?gl=us&hl=en
  18. futureferraribuyer
    futureferraribuyer Formula Junior
    Jun 23, 2010
    296
    I had my 430 put back to original height and realigned afterwards for $500 through a shop in Orange. It was lowered about 1.5 inches by the previous owner.
  19. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    Did it involve removing the coilovers? Thank you
  20. hangarsixco
    Oct 10, 2010
    396
    S. California
    Chris
    #20 hangarsixco, Apr 14, 2015
    You do not need to remove the shocks to lower the car. You will need a proper spanner wrench and patience. Remember 1 full turn of the spring support is 1.5mm up or down. There is no way you will corner balance the car by removing the shock every time. Also removing the sway bar end links will remove the pre-load. You will have the wheels on and off quite frequently short drives will help settle the springs. Corner balancing requires small adjustments on each corner.
    Lowering a car is easy, lowering these cars properly is not.
    I can see you are eager to work on your own car but lowering these cars can be dangerous if not done correctly. Small adjustments go a long way. And going to low will have you scraping over every driveway and speed bump you come across.
    Also proper alignment caster/camber and toe are crucial to have you driving safely. Before I had my car aligned after lowering it the car felt all over the place kind of scary at HWY speed getting to the alignment shop. Once aligned car felt stable and responsive.
  21. Rifledriver
    37,104
    Removal of shocks is often required. The cars are getting old. Debris, corrosion and just plain old sticktion of the rubber to the adjustable perch often requires removal and compression of the spring and or cleaning of threads /corrosion etc to move the adjustable perches. A nice clean low mile car that has never seen anything but California weather is not representative of many cars out there. At the dealer on newer cars I never pulled shocks. That was 15 years ago on 360's.
  22. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    What do you guys think about lowering it challenge specs? It is unforgiving to drive and scrapes on speedbumps and plazas?
  23. Rifledriver
    37,104
    They are really good at stock ride height. Personally I think lowering is a really poor idea.
  24. hangarsixco
    Oct 10, 2010
    396
    S. California
    Chris
    Great point, I had removed my shocks (all 4) to replace the worn out lower bushings. In doing this I cleaned the shocks with a bristle brush and a lot of shop towels. Threads had a hand fulls of small rocks and full of road grime. I used the WD40 straw to lube up the rubber seats. Gave the shock body a nice spray and wipe down with WD40 then installed the shocks and started the lowering process.
    For those who have never worked on coil over suspension. The lock nut can be a knuckle buster if working on them on the car.
    I'm sure every car is going be different in its process. Working with clean parts always makes the job much easier.
  25. futureferraribuyer
    Jun 23, 2010
    296
    Agreed! Looked better lowered but I never have to worry about speed bumps or driveways at normal height. Looked kind of high at first but you get used to it...
