Lower differential ratio? | FerrariChat
Discussion in '308/328' started by DWPC, Oct 24, 2011.
  1. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    I don't need to go 140. I would like to have the responsiveness from a little lower final drive ratio. Is any lower gear available for a 308 that I wouldn't have to sell a kidney to afford?
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,834
    no ;)
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,323
    The way to do this is probably with the drop gears rather than trying to change the actual final drive.
    But most of these things are straight cut/dog gears I think & so pretty noisy (because they are designed for track cars). Maybe enquire of some of the indis who also support some of the race series. Here in the UK the guys at QV London would definitly be able to tell you what was possible & also provide the parts I think.
    Your other issue might be that doing this might mean a lot more gear shifting and these gearboxes don't exactly lend themselves to that, they are not the fastest things in the world!
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,323
    Succinct as always :)
  5. Steve Magnusson
    26,834
    Had to move to another computer to get the pic -- here's an example of the straight-cut transfer gear system (where they add another gear on the center shaft to change the overall ratio) that Iain mentioned, but don't see how this would be much different $-wise than a custom differential gear set:
    This type of system would make changes easier (at the track) than having to go inside the gearbox (if you had multiple sets for the racetrack), but I think that you'd still be in the same $ ballpark for a single set like this as Newman's price for the TR ring/pinion set.
    How about a 355 or 360 ;)
  6. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    Oh well...I knew it was a long shot.
  7. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,812
    Cerritos, CA.
    if you want to improve low end torque, get a smaller wheels size :D
  8. GrayTA
    GrayTA F1 World Champ Owner Rossa Subscribed
    Jun 25, 2006
    15,130
    Deep South
    PDG
    I was wondering about this as well....guess this answers the question though.
    PDG
  9. Pero
    Pero Formula Junior Silver Subscribed
    Apr 22, 2011
    825
    Sweden
    Peter R
    I think they have another gear ratio then the 308 to compensate for the smaller engine (same as 308 in all respects apart from volume). I might be totally wrong in this....
    Pero
  10. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Wasn't there a 208 in the beginning? Did it have the same gearing?
    Don't forget a lower ratio will increase your RPM's at driving speed, I am doing nearly 4,000 at 70 now, not sure I want this little engine to turn much faster on highway trips
  11. MNExotics
    MNExotics F1 Rookie BANNED
    Dec 13, 2010
    2,631
    Good Thunder
    Ben Gruenzner
    I am trying to remember but didn't the 328 have a different gear set from the 308?
  12. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I read that also but I belive the 328 had the same gear ratios but one gear was changed. I will check my book tonight and report back which gear that was.
  13. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,386
    Houston, Texas
    Bubba
    The 208Turbo is an Italian Market only vehicle...although some were in other parts of Europe.
    The was also a 208GT4 for the same reason...(taxation values)
  14. stratos
    stratos Formula Junior
    Dec 9, 2003
    639
    Switzerland
    What you need is this. Stratos Group 4 and Michelotto 308 style.
    Many ratios available.
    You need the clutch shaft, cover and a set of drop gears to suit.
  15. Speedmade
    Speedmade Formula Junior Rossa Subscribed
    Jul 31, 2004
    387
    Minneapolis, MN
    Reed H
  16. Crallscars
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    There you go, put in a set of 4V stump puller gears
  17. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,323
    Thats great info but I wonder if all the drop gears are the same?
    ETA I found a pic of my 328's dropgears & the cogs are 27,28 & 30 teeth from top to bottom - I think calculates at 0.90:1 (or is that 1.11:1 ? )
  18. MNExotics
    Dec 13, 2010
    2,631
    Good Thunder
    Ben Gruenzner
    If I am am looking at this and the information is correct (there is no bad information on the internet) the 328 has a taller first gear and would hinder acceleration. Looking at the final drive ratios, the 308 4 valve has the best accelerating ratios and the 2V only has a minor advantage in first gear only over the 328.
  19. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,323
    On paper, yes, but 1st gear on all these cars is pretty much "blink & you'll miss it" anyway....
  20. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    Where is this kind of stuff available and at what $$$?
  21. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,468
    Canada
    Newman
    LOL
  22. BigTex
    Dec 6, 2002
    79,386
    Houston, Texas
    Bubba
    'Group 4' on these cars is like saying "light the money in the fireplace" man!!
    That was custom racing level equipment when new 40 years ago....you be starting from billet to replace it at this point...
    Doable, but not cheaply.
  23. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    That's what I have...'85 QV.
  24. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Okay, the book says "Within the transmission individual gear ratios remain, but there is a change in the overall ratios through the introduction of a 17/63 crown wheel and pinion in place of the 17/65 set used for the Qv cars" This is talking about the changes in the 328 made after the 308 QV. Hope this helps.
    Also to confirm:
    308 gt4 1st 3.418 2nd 2.353 3rd 1.693 4th 1.244 5th 0.952 rev 3.247 final 3.71:1
    308 GTB 5th becomes 0.918
    308 GTBi final is 4.06
    308 GTS,Si, Qv final is 3.82
    Mondial 8 5th becomes .919 final is 4.06
    328 final is 3.7:1
    very confusing in the book but I think it's right now
  25. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Interesting note:
    In 1986 Enzo himself stated "what the customer really wants now, is instant speed, in other words 0-60 and 0-100 by the fastest possible route." "So while Ferraris will always top out at 160mph, there will be a concerted effort to lower the 0-60 and 0-100 times to a minimum, all coupled with greater traction, better car control and better brakes. Look for 6 speed gearboxes, Torsen type differentials, four wheel drives with variable torque split, electronic suspensions, automatic ride hieghts and ABS brakes. All will be quite common by the end of the decade, and no doubt Ferrari will have high-tech versions of them all"
    The guy was really quite a visionary.
