Lowered FF with spacers | Page 2 | FerrariChat
Discussion in 'FF/Lusso' started by Brian L, Mar 7, 2017.
  1. veelangs
    veelangs Formula Junior
    Sep 27, 2021
    326
    Manhattan
    Vee
    Was getting ready to do this with my TE37s and the service tech called and told me I have leaky front struts :(
    So short of replacing those much quicker at the lower seat position, I'm keeping my strut height stock
    I'll likely get them done at an indy when I go for my annual in august
  2. johnff
    johnff Rookie
    Dec 15, 2022
    4
    Hey there guys sorry to bring an old disccusion back from the dead, what spacers did everyone use on their FF? Is there a difference if I go novitec vs Eibach or H&R?
  3. joeacc
    joeacc Rookie
    Feb 21, 2006
    21
    I lowered mine just using the stock coil overs, no need to buy aftermarket springs. I lowered it about a 1/2 inch front and rear; but you could far lower, I just wanted give it a slightly more aggressive stance. As far as spacers, I used hill engineering 11mm all the way around.
    -K1- likes this.
  4. IDKFA
    IDKFA Karting
    Mar 19, 2018
    71
    Essex, UK
    RUNDLL
    Not sure whereabouts in the world you are, but if UK, then I can recommend Hill Engineering. They'll ask you what wheels you have too in order to supply you with the correct length wheel bolts.
  5. -K1-
    -K1- Formula Junior
    Jul 10, 2008
    699
    Northern Italy
    Ken
    Pics please!
  6. IDKFA
    IDKFA Karting
    Mar 19, 2018
    71
    Essex, UK
    RUNDLL
    uberwag, -K1-, Elferink and 2 others like this.
  7. -K1-
    -K1- Formula Junior
    Jul 10, 2008
    699
    Northern Italy
    Ken
  8. johnff
    johnff Rookie
    Dec 15, 2022
    4
    How’s the ride quality with lowering stock coilovers with spacers?
  9. IDKFA
    IDKFA Karting
    Mar 19, 2018
    71
    Essex, UK
    RUNDLL
    I'll be honest, I haven't noticed any difference at all. Had it this way for about 18 months now.
    I'm sure the others who've done the same will be along soon to offer their view.
  10. carguy007
    carguy007 Formula Junior
    Apr 24, 2013
    898
    This is one of the best looking FFs I have seen to date. The wheels really set it off.
  11. sid12345678910
    sid12345678910 Karting
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    You should be able to build your own lowering kit with KW springs. I don't reccomend using the factory springs when your lower it, it will give you the wrong spring preload on the suspension. It will make the car feel soft a mushy. Here what I could come up with, it should be a copy of the novitec ones Image Unavailable, Please Login
    Endrig and andyrichter like this.
  12. andyrichter
    andyrichter Karting
    204
    Oahu
    Wow, very cool! I had no idea this was possible. I was considering looking into custom coilovers from companies like Alpine Scale, etc. Please update us on the results if you go the KW route.
  13. Sonicsound
    Sonicsound Karting
    May 14, 2017
    126
    I also love a badge-less FF. It looks so much sleeker IMO.
    FerRrari, NYC Fred and Altoria F like this.
  14. dilmorecg
    dilmorecg Rookie
    Jul 24, 2023
    28
    Did you go all the way down on the coilovers? 15mm on all 4 corners? Trying to achieve this look.
  15. IDKFA
    IDKFA Karting
    Mar 19, 2018
    71
    Essex, UK
    RUNDLL
    Yes that's correct. All the way down is only about 15mm. Any lower would require different springs.
  16. andyrichter
    andyrichter Karting
    204
    Oahu
    I’m guessing you lowered the height of the fenders in relation to the ground by 15mm? 15mm of lowering based on the coilover rings possibly be too low?
  17. FerRrari
    FerRrari Formula 3
    Jan 11, 2009
    1,250
    WA
    Fernando
    Agreed. Really want to de-badge mine in the future.
