lowered | FerrariChat
lowered
Discussion in '348/355' started by cavallo95, Jan 17, 2014.
  1. cavallo95
    cavallo95 Formula Junior
    Jan 23, 2007
    272
    chicago
  2. PaulW_968
    PaulW_968 Karting
    Jan 12, 2014
    58
    Chicago Area
    HOT! When the weather breaks, I would love to come by and get a ride in it....
    Did you the lower the same front and rear? It almost looks as if the rear is lower than the front now.
  3. Dave rocks
    Dave rocks F1 World Champ BANNED
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Not disrespect but I think the wheel spacers are a bad idea for two reasons:
    1) subjective but I prefer the look with the wheels inset
    2) not subjective, you are going to get paint chips all over the body.
  4. cavallo95
    Jan 23, 2007
    272
    chicago
    I respect your opinion,thats what "you prefer" but for me it was the rite choice , and as far as rock chips I have venture shield behind the wheels so no problem there.
  5. cavallo95
    Jan 23, 2007
    272
    chicago
  6. cavallo95
    Jan 23, 2007
    272
    chicago
    I think I lowered it evenly , I think......?
  7. SoCal1
    SoCal1 F1 Veteran Owner
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Looks great now take that baby out and throw some rooster tails in the snow.
    I think I'm a scooch lower in the front and just as wide with no rubbing/ issues at all unless you include any speed bumps, thats another story LOL :)
  8. cavallo95
    Jan 23, 2007
    272
    chicago
    Did you have your fenders rolled?
  9. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    +1 on the chips.
    Don't space out the front wheels 15mm, maybe 5 or 10 max, I like the wide flush stance myself with 15mm spacers all around but you will chip the door vents, mirrors and front half of the rear quarter panels with 15mm front spacers. Ask me how I know, I learned that on the silver 348. I will not be spacing out the fronts on my black 355, that car is chipfree.
    Lowering for stance effect can also be achieved by sizing up tire diameter and lowering the chassis half as much. I went with 225/45 front and 275/40 rear, fills the wells perfectly w/o sacrifcing ride quality over Chicago roads.
    Yes, I used 4 corner scales to balance the chassis.
  10. SoCal1
    Jun 14, 2011
    8,636
    Tim Dee
    No, its close I run 1.75 camber which helps also
  11. cavallo95
    Jan 23, 2007
    272
    chicago
    I mite think about reducing front spacers after your comment, my car is also spotless , like new, as far as upping the diameter of tires, yes that makes sense , but I just hate the look of a fat sidewall , so pass on that.
  12. cavallo95
    Jan 23, 2007
    272
    chicago
    I dont know how camber mesurments work, do you think I really need to adjust camber after lowering?
    what are the consequences if I don't? I do not track the car btw.
  13. PaulW_968
    PaulW_968 Karting
    Jan 12, 2014
    58
    Chicago Area
    What did you do to the wheels to make them black? Send them out for powder coating? Or just use plasti-dip so you could run them in the winter?
  14. cavallo95
    Jan 23, 2007
    272
    chicago
    Plasti dip with glossifier;)
  15. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    All that matters is the smile on your face ...
  16. SoCal1
    Jun 14, 2011
    8,636
    Tim Dee
    Toe may change also
    You best bet is get her aligned and get a printout
    A shop that has scales to weigh each corner is best and record everything
    Have them check your thrust angle also, seen this off quite a bit on 4 wheel independent cars that are rear drive.
  17. 308 GTB
    308 GTB F1 World Champ Rossa Subscribed
    Feb 7, 2002
    11,758
    New Jersey
    Barry Wolinsky
    Right. As Tim mentioned, several things change when ride height is adjusted. Lowering the rear increases understeer too. Spring rates also matter, as does tires.
    The car might look good sitting in your garage, but when you drive it in the spring you might be in for a surprise even if you don't track your car.
    A lot of time was spent by my shop adjusting my F355 Challenge's ride height and alignment to Challenge specifications. The same thing applies to a street version F355.
  18. 308 GTB
    Feb 7, 2002
    11,758
    New Jersey
    Barry Wolinsky
    That expression might change if the car understeers or oversteers...
    radback likes this.
  19. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    The car looks nice lowered.
  20. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,757
    Boston, MA
    John E. Kenney
    Yeah looks great. So 15mm spacers up front will casue stone ships? Hmm, now I'm not so sure with my brand new paint. I have one chip in the bumper and the mirror pivots have chipped from grinding when folding. Maybe they weren't baked properly but this has me thinking...
  21. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    personally , i'd leave the spacers , i think the factory offset makes the cars look awful. i've driven mine 3500 miles with wider offset wheels and don't see a single chip.
  22. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    I second that. I have ran hills spacers front and rear on my cars for years also with 295 rears.
    There's nothing in the way of excess stone chips to write home about.
  23. cavallo95
    Jan 23, 2007
    272
    chicago
    Im leaving em on , I really like how it looks , but I will keep an eye for stone chips.
  24. cavallo95
    Jan 23, 2007
    272
    chicago
    I tried on a 430 tire on the rear i have a set from when I had a 360 , this is what it looks like if anyone is wondering , it sticks out way to much. I know there has been alot of questions here reather they fitted or not , the answer is No.
    Wheels are sold btw.
  25. cavallo95
    Jan 23, 2007
    272
    chicago
