Lowering my F430 | Page 2 | FerrariChat
Lowering my F430
Discussion in 'Technical Q&A' started by F430SilverArrow, Dec 26, 2005.
  1. RobHulme
    RobHulme Karting
    Mar 13, 2005
    53
  2. markb
    markb Rookie
    Dec 22, 2005
    12
    Las Vegas
    MFB
    Noitec makes springs that lower the car 31 mm. I installed them on my car. It takes about 4 hours including an alignment. The springs cost about $1,000.
  3. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    You have a PM.
    Gary
  4. thomas_b
    thomas_b Formula Junior
    Sep 15, 2003
    765
    #29 thomas_b, Jan 4, 2006
    I have looked at the Novitec springs but the did not have spring rate or a comparison to the stock springs
    Mark do you have this information? – any info how the car behaves after the change?
    I did have FoS lower my car 1” front and rear (plus skid plates) – it would have been possible to lower the car by another 0.5” and stay writhing F spec (see finger test below)
    I have seen several F430 bottom out on the track – sparks flying - so ground clearance may be severely compromised - biggest worry is that it’s going to tear the bottom of the car up on the track (or during spirited driving) – so 1” seems to be the best compromise
    I have a serious problem with the body roll of the F430 – don’t care so much about the aesthetics – after the CS this is simply a letdown – faster in the straight slower in turns – too bad
    Interestingly enough the much discussed F430 Supertest article of Horst Von Saurma’s Sportauto and the 7.55 min time reflects this. The article itself is the most positive I have read from the guy about a Ferrari – lots of praise – however each annotation of the different track measurements states that the car was slow on the track because of excessive body roll – measurements that are not impacted by the setup are excellent – this makes sense to me
    To cut a long story short – has someone taken the car to the track lowered? – I worry that the car still suffers from soft springs
  5. Jack(LA)
    Jack(LA) Formula Junior
    Nov 16, 2003
    758
    Los Angeles
