Lowering my Pista | Page 14 | FerrariChat
Lowering my Pista
Discussion in '458 Italia/488/F8' started by SoCal to az, Jan 11, 2021.
  1. SoCal to az
    SoCal to az F1 World Champ
    15,118
    Arizona
    The original shop is going to swap out my HRE with Novitecs. The owner is standing behind his work. It’s fine. A set back but hopefully will get this all squared away in a week or two.
    mdrums and SECRET like this.
  2. SoCal to az
    15,118
    Arizona
    Update: after dicking around for 2 weeks and still no springs- I got my money back for the job from the shop which they promptly refunded. Have new shop ordering novitecs (which original shop said was going to take several more weeks but I know they never even ordered them). Springs should be here in a few days and then we will do install.
    What a mess but luckily no major harm or foul. I’ll get pics posted in a few weeks of the progress.
  3. SoCal to az
    15,118
    Arizona
    Springs go in next week. Was thinking to add some spacers to the rear wheels as well to give a more aggressive stance. Go with Novitec or can I use a different brand? Figured it’s just a small piece of metal so don’t need to spend 2 grand abs pay the ferrari tax. Anyone know of any alternatives?
  4. AD211
    AD211 Formula 3
    Owner Rossa Subscribed Silver Subscribed
    Aug 19, 2017
    1,270
    South Carolina
    Andy
    Bruven and SoCal to az like this.
  5. SoCal to az
    15,118
    Arizona
    I’m gonna order these but they may not arrive till after my springs go in. Might have to just do a DYI job to install. Can’t be all that difficult.
    AD211 likes this.
  6. SoCal to az
    15,118
    Arizona
    Can someone from @VividRacing comment on spacers? Easy dyi? I’m in Scottsdale. Can I swing by next week and pick up? What size you recommend? 10/15 front rear??
  7. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    If you do spacers, do the Hill spacers. 11mm front and 15 rear. Yes they are just a piece of metal - that takes the weight of your car.
    If you have seen how a set of H&R spacers can get bent out of shape on powerful cars, that's enough proof to making sure they are made from a quality material. Hills are better and cheaper than both Capristo and Novi spacers, and the precision is killer. The "click" when they slide over the hub is just delicious:)
    Also, the 11mm spacers are much, much stronger than the normal 10 mm units. Both the 10 and 11 mm spacers are hubcentric, and with the 10 mm set there is next to no material between the inner bore that fits over the hub and the outer hub on the spacer that supports the car. There's a reason why Hill made the narrow spacers 11 mm and it was not cosmetics.
    SoCal to az likes this.
  8. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Here you go.
    https://www.ricambiamerica.com/cali-458-ws011-114-11mm-wheel-spacers-cal-458.html
    https://www.ricambiamerica.com/cali-458-ws015-114-15mm-wheel-spacers-cal-458.html
    And get a pair of these
    https://www.ricambiamerica.com/wmt-01-wheel-mounting-tool.html
    Mounting spacers without is just asking for trouble.
  9. SoCal to az
    15,118
    Arizona
    Awesome. The mounting tool is out of stock but ill get the spacers ordered asap. $250 sounds a lot more reasonable than 2 grand!
    So excited after 2+ years to get the Pista dialed in hopefully perfect.
  10. SoCal to az
    15,118
    Arizona
  11. PCJR
    PCJR Formula Junior
    273
    PA
    Anyone care to share their alignment specs for when they lowered their Pista using Novitec springs?
  12. SoCal to az
    15,118
    Arizona
    Ok called Ricambi and confirmed those were the right parts. Got 11 and 15mm wheel spacers on order. Delivery and install next week.
  13. Dicecal
    Dicecal Formula 3
    1,869
    Phoenix, AZ
    Rob
    Sam, the wheel tool is available just about anywhere….
    https://www.amazon.com/Black-Wheel-Hanger-Alignment-Guide/dp/B07RP35KJJ/ref=sr_1_2?crid=1G3VG0J3ADA6Z&keywords=M14+x+1.5+thread+Wheel+tool&qid=1647292255&sprefix=m14+x+1.5+thread+wheel+tool%2Caps%2C102&sr=8-2
    Just make sure it’s for M14x1.5 thread
  14. SoCal to az
    15,118
    Arizona
  15. Dicecal
    Dicecal Formula 3
    1,869
    Phoenix, AZ
    Rob
    Just makes it easier to install wheels and such onto the hub, while lowering the risk of banging into the ceramic rotors and possibly chip/damage them.
    Bruven likes this.
  16. SoCal to az
    15,118
    Arizona
    so slide the wheel right over and then unscrew? got it. makes sense.
    Ricambi America and AD211 like this.
  17. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Sure.
    Do you want toe in minutes or mm?
    Do you want camber in degrees and minutes or just degrees?
  18. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Yep. When running spacers they are a must. Trying to install spacers and then holding a wheel onto the hub, all while trying to align the wheel and spacer without it all crashing on to the brake rotor is a chore that gets old in minutes. Just don't even attempt it. For this reason ALWAYS keep the hangers in the car. If a shop needs to fix a flat or what not, they need to be there.
  19. PCJR
    PCJR Formula Junior
    273
    PA
  20. SoCal to az
    15,118
    Arizona
    Spacer and mounting tools have been ordered. Install scheduled for next week when I get back to town.
    mdrums likes this.
  21. PCJR
    PCJR Formula Junior
    273
    PA
    My tech prefers MM and Degrees.
    thx for sharing!!
  22. SoCal to az
    15,118
    Arizona
    Car is scheduled to get updated Monday. Spacers. Abs alignment tools are here. Will get Novitec and hill spacers installed and hopefully get you guys some
    Pics Tuesday.
  23. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Here are two settings. 1 is for track and serious road use, 2 is for road use on a car that rarely sees the track and generally is not driven hard. Numbers are per side. Don't worry about caster as it will remain largely unchanged and well within spec.
    Setup 1
    Front
    Toe. +1.0 mm
    Camber. -1.95 degrees
    Rear
    Toe. +2.07 mm
    Camber. -1.80 degrees
    Setup 2
    Front.
    Toe. -0.75 mm
    Camber. 1.45 degrees
    Rear.
    Toe. +1.75 mm
    Camber. -1.65 degrees
    Note that when your tech adjust the front camber, it is important that he not only adds shims to the lower A-arm, he should also remove the shims from the upper A-arm and install them on the lower A-arm before the added shims. This will serve to pull the top of the wheel in a bit, thus retaining optimal steering geometry. The upper shims are the ones labelled #10 in the attached drawing. Image Unavailable, Please Login
    Vertix and RoadRonin like this.
  24. PCJR
    PCJR Formula Junior
    273
    PA
    Thx for this info!
