458 - Lowering | FerrariChat
458 Lowering
Discussion in '458 Italia/488/F8' started by ZitroRasec, May 20, 2025.
  1. ZitroRasec
    ZitroRasec Rookie
    Sep 19, 2021
    15
    So Cal
    Cesar Ortiz
    Hello, I’m trying to shorten the wheel gap on the 458 a little bit nothing too aggressive. Probably about 0.5 to 0.75 but the driver side strut on my 458 seems to be seized and looking for a replacement.
    I added some picture of my new wheels in my driveway to show how I would like the car to sit with the drop.
    Any recommendations on a company who can send me a rebuilt in exchange for my core? Thanks in advance!
    488Julius likes this.
  2. jhunter18
    jhunter18 Rookie
    Feb 6, 2022
    5
    NJ, US
    Jason Hunter
    You might be able to cut the lock/and adjustment nut off the threaded shock body if you/your shop is very careful and take their time. That said, I am not sure you will be able to go much lower with stock coil overs. I have mine very low on the threading and it doesn't look any different than yours is now.
    dave360 likes this.
  3. ZitroRasec
    ZitroRasec Rookie
    Sep 19, 2021
    15
    So Cal
    Cesar Ortiz
    Thanks for info. These pics are in my drive way at inclince so it shows the lower position I would like to be at. These are the pictures that I have on me that show the real current height.
  4. TUTTSF
    TUTTSF Karting
    Sep 21, 2018
    167
    So. Cal
    Are you trying to move the collar or a shop?
    I would remove the shock and use a spring compressor and then rotate top collar up and see if that releases the bottom collar.
  5. 488Julius
    488Julius Formula Junior
    Feb 10, 2024
    566
    Julius Gergly
    Just get the novitecs. I protested in the beginning but I’m glad I did. They make the car so comfortable.
  6. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,452
    Tampa FL
    You need to get with @Eric C ...he's the King of Lowering ;-)
  7. Eric C
    Eric C F1 World Champ
    11,074
    St. Louis, MO
    Eric
    Just get a torch and heat them springs up homie
    Stethoscope likes this.
