Lube additive for TR trans...? | FerrariChat
Discussion in 'Boxers/TR/M' started by carguy, Jun 3, 2007.
  1. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,424
    Alabama (was Mich.)
    Jeff
    I recently changed the trans fluid, and put in Redline 75 W90 NS. After a long drive I'm noticing a slight shudder when moving from a dead stop around a curve, once moving straight everything is fine. The shudder is barely noticeable, but it didn't do this until I changed out the trans oil. Is there some type of friction modifier that I can, or should, add to alleviate this condition?
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,450
    Canada
    Newman
    GM limited slip additive, its the absolute best friction modifier and will correct your problem.
  3. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    I get it from the US rep, for about $75 for 5 gal. Will cure your problem, and meet manuf specs. Why mess with a good thing?
  4. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    ADD ford possi additive.
    It's your possi clutch plates, it stinks BAD but it works to fix your problem.
