Lubricating Window Motor Gearbox | FerrariChat
Discussion in '308/328' started by vulcan300, Oct 9, 2012.
  1. vulcan300
    vulcan300 Karting
    Oct 30, 2011
    86
    43.652073,-79.382293
    Jeremy G
    Can the window motor gearbox be cleaned and lubricated without removing and replacing the window raising cable?
  2. John M
    John M Formula Junior
    Nov 18, 2004
    887
    Kentucky
    You will want to pull the cable and regulator. You will need to disassemble the regulator on a bench and clean. A dremel with wire brush came in handy for this.
  3. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
    I was able to remove the motor and re-grease it and the gears with out cutting the cable.
  4. BigTex
    79,331
    Houston, Texas
    Bubba
    I have always wondered the exact same thing, it seems a carefully drilled access hole at the worm gear, and a grease gun needle could get the thing 'freed up" again without the hassle of R & R the entire cable...
    I dunno.
    I just leave mine down....:D :D
  5. jcurry
    23,751
    In the past
    Jim
  6. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    The issue with the regulator is the old grease - it is, by this time, hard as a rock. You need to remove the old grease.
  7. BigTex
    79,331
    Houston, Texas
    Bubba
    Yea, wax by now, I suppose...
  8. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    I remember a post a while back from a guy who drilled through the door into the gearbox and spayed in WD-40 to loosen up the old grease. He said it worked. Wouldn't recommend though.
  9. i-velocita
    2,520
    Colorado
    James
    #9 i-velocita, Oct 9, 2012
  10. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    i agree with PAD. the grease in mine was rock hard. i never could have freed up the drive without totally disassembly. jon s.
  11. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
    What is the reason for cutting the old cable?
  12. BigTex
    79,331
    Houston, Texas
    Bubba
    IIRC, it dead heads at both ends, inside the spool.
  13. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,174
    CT
    John Kreskovsky
    No need to cut the cables if they are in good condition. Just make sure you count the wraps before you unwind as you will have to be sure to have the correct number of wraps around the spool when putting it back together. Use wire ties top hold the wraps when reassembling.
  14. BigTex
    79,331
    Houston, Texas
    Bubba
    #14 BigTex, Oct 9, 2012
  15. vulcan300
    vulcan300 Karting
    Oct 30, 2011
    86
    Jeremy G
    Thanks guys!! The info shared here is fantastic. My driver's side window takes about half a millennium to raise even when I'm giving it a push. I plan to add window accelerators and will re-lube the gear box but I'm not too keen on cutting the cable if I don't have to. It's good to know I can avoid it.
  16. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
    I just re-spooled the lines with out the window connected, ran it up and down a few times to get the lines set on the spool, then attached the window.
  17. vulcan300
    vulcan300 Karting
    Oct 30, 2011
    86
    Jeremy G
    Did you just hold the cables loose in your hand and run them in and out of the motor with the switch?
  18. johnk...
    Jun 11, 2004
    11,174
    CT
    John Kreskovsky
    Before you do that check your fuse blocks. If you see any signs of slight melting (deforming) take out the fuse block and either repair or replace with Birdman units. Even if there isn't melting, oxidation on the contacts can cause enough contact resistance to slow the windows (and, by the way, the radiator fans). I ended up soldering my original blocks because they were still in pretty good shape and then I replaced all the fuses with new ones. Between re greasing the motors and the fuses box fix I'm happy with the windows. They aren't lighting fast, but more that satisfactory for me.
    With regard to cooling I would add that while my car never over heated the gage would get to 210 or so on a really hot day when idling in traffic. After I repaired the fuse block it never gets above 195.
  19. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
    If you are just greasing the motor, here are the following steps;
    -I used a sharpie to draw the path of the cable on the door. You could also use some thin drafting line tape if you didn't want the permanent line.
    -Wrap the cable around the spool 3x and use a piece of tape to hold the ends together. This can be loose for now. You just don't want it to come unfurled.
    -Mount the motor back in the door leaving the excess hanging out the rectangular hole in the middle.
    -Following the lines on the door and run the cables around the pulleys.
    -Take up the slack by raising the adjustable pulley. At this point the tape should come undone. (remove said tape)
    -Run the motor up and down a few times. This should cause the cables to seat in the grooves of the spool. When you reach the end of the run, the adjustment pulley may move. Loosen the stress on the line and take up the slack again.
    -With the glass resting at the bottom of the track, run the motor till in reaches the bottom of its travel.
    -Attached the cable to the window bolts, and test raising and lowering the glass.
    Note: If you replaced the flocking, replaced the pulleys, greased the motor, and added the relays, the stress on the window cable bolt and washer will be a lot higher. I recommend grooving and bending the washer so it does not pop out. If it does pop out it will sound like a guitar string.
  20. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    If you cut the cables, BE SURE TO MEASURE THE ORIGINAL CABLE!!
    My cable length was significantly shorter/longer (can't remember now) than Birdman's tutorial.
    In no way is he to blame, as I have an early GT4 and his tutorial is not for my car, but you're better off knowing EXACTLY what needs to be replaced.
    Also--
    Be sure to cut it as close to the ferrule as possible.
    This way you can easily measure, rather than trying to measure shredded sections.
    I still haven't put my windows back together cause I can't get the cable wrapped round the spool correctly; tried 10 times and failed every time.
    Sent from my iPhone
    (which probably means I'm sitting at my car, confused)
  21. vulcan300
    vulcan300 Karting
    Oct 30, 2011
    86
    Jeremy G
    Mr Big,
    I'm sorry to hear that you're having a spot of trouble with your window motors. Whisper and the good Baron Samedi will be along to give you a hand shortly.
    Sincerely,
    Mr Bond :)
  22. John M
    Nov 18, 2004
    887
    Kentucky
    No need to cut any cables on this R & R. Just remove them off the pulleys and away you go. I really doubt any injection of wd40 will loosen up what I found when I opened mine. The grease was all solid as a rock. Amazing it turned at all. You'll have to chip it off the gears, regrease and reassemble. Cables only need replaced if they are broken.
  23. vulcan300
    vulcan300 Karting
    Oct 30, 2011
    86
    Jeremy G
    Fantastic. I shall dig into it this weekend while I'm rebuilding my CVs.. Old cars are the best excuse the get dirty and drink beer. They are like the hyper expensive sand boxes of adult life :)
  24. vulcan300
    vulcan300 Karting
    Oct 30, 2011
    86
    Jeremy G
    Is white lithium grease a must? I have the red Mobil 1 synthetic grease, will that do? Or is it incompatible with the components?
  25. designr
    designr Karting
    Dec 10, 2003
    114
    Wake Forest - NC
    Ron Smith
    I used white litium because it clings good. You don't want the grease to slide off after a few years. You can pick up a tub of it at any of the chain autoparts stores.
