Lucas Fuel Injection "Bomb" | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by XJ13, May 13, 2011.
  1. XJ13
    XJ13 Rookie
    May 13, 2011
    20
    Shropshire, UK
    Neville Swales
    Gentlemen - forgive me if I am posting in the wrong forum but I wondered if any of you could help me?
    I am looking for TWO Lucas 100psi+ Fuel Injection "Bombs" - as fitted to Ferraris and Maseratis around the mid-1960s. They are for my current project (non-Ferrari - details/pics may be seen at www.xj13.eu - the name of the website may give the game away .....)
    Condition is not important - even just outer casings would suffice - although restorable/working units would be preferable!
    Here is a link to a picture of such a "bomb" (also attached):
    www.xj13.eu/xj13/LucasBomb.jpg
  2. Ney
    Ney F1 Veteran Silver Subscribed
    Apr 20, 2004
    7,385
  3. Ferraripilot
    Ferraripilot F1 World Champ Owner Project Master
    May 10, 2006
    17,859
    Atlanta
    John!
    Brilliant project. One of my favs
  4. tomgt
    tomgt F1 Veteran Rossa Subscribed
    Feb 22, 2004
    7,181
    Netherlands
    Tom Wiggers
    http://www.powerprops.com/inhoud/Maserati/uk/index.htm
  5. Pass
    Pass F1 World Champ Silver Subscribed
    Feb 29, 2008
    13,156
    Salida Colorado
    Mark Passarelli
    Very cool; similar to my W194 project.
  6. swift53
    swift53 F1 Veteran Rossa Subscribed
    Nov 17, 2007
    8,336
    E.S.
    Alberto
    I would like one also, for my Alfa GTAm. That makes three...
    Regards, Alberto
  7. XJ13
    XJ13 Rookie
    May 13, 2011
    20
    Shropshire, UK
    Neville Swales
    Perhaps we should combine our efforts Alberto - there have to be some going spare somewhere in the world?
    I had already tried Kinsler and Powerprops but drew a blank - thanks Ney and TomGT for your suggestions anyway. I really don't want to use alternatives as the car has to be "right" - so the search goes on ....
  8. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    This is the first time I've seen such detail of the XJ13 engine. It's much different than the production engine in almost every way.
  9. swift53
    Nov 17, 2007
    8,336
    E.S.
    Alberto
    Neville, for my purpose, all I need is the bomb itself, no need to be working, as using modern, reliable components from....Kinsler.
    If you also only need the outside, and had engineering drawings, we can make the cans here without any problem. Even a beat up sample would work.
    I assure you there are quite a few lingering in some old forgotten box...
    Lovely project you have going!
    Regards, Alberto
  10. XJ13
    XJ13 Rookie
    May 13, 2011
    20
    Shropshire, UK
    Neville Swales
    Careful Tim - it is dangerous to start me off on the XJ13 project .... do you have a few days to spare and a supply of cold beers? ;)
    Yes - the engine is very different to the SOHC solution they eventually settled on. The SOHC was very much the brainchild of Walter Hassan who was absorbed into Jaguar when the company he worked for, Coventry Climax, was taken over by them in 1963. When he arrived Bill Heynes' DOHC (XJ13) engine was about to hit the test bed - designed with racing in mind. By the end of 1965 Jaguar's attentions were diverted by the BMC takeover, changes in Le Mans regulations, financial difficulties and the spectre of the GT40; so they decided to concentrate on a road engine instead. I believe even Ferrari were concerned about the Ford invasion and didn't attempt to meet it head on but scaled back the factory entry to only two P3s (neither of which finished)? Hassan employed Harry Mundy and set about designing a new V12 engine for the road.The resultant SOHC engine continued in production well into the 1990s.
  11. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    951
    Arizona
    Jim
    I would try Crosthwaite and Gardiner, they reproduce a lot of lightweight E-type Jaguar parts. The fuel pump you show was also used in them.
    Cheers Jim
  12. XJ13
    XJ13 Rookie
    May 13, 2011
    20
    Shropshire, UK
    Neville Swales
    I finally found a pair of "used but good" Lucas "Bombs" from Bill McGrath Classic Maseratis (www.classicmaseratis.co.uk). It was posting on this forum that resulted in this success - thank-you posters!
    I will shortly be the proud owner of them and wanted to pass on the fact that Bill McGrath turned out to be very knowledgeable, enthusiastic, friendly and helpful - certainly worth a call if you are looking for something similar. To make things even better - their prices ended up around one tenth of Kinsler!
    I have absolutely no affiliation with his company but pass this on as a satisfied customer and for the benefit of other posters looking for similar parts.
