Lug bolt specs for 360's? | FerrariChat
Discussion in '360/430' started by GrandSportC3, Nov 11, 2005.
  1. GrandSportC3
    GrandSportC3 Karting
    Oct 8, 2005
    237
    Clearwater, FL
    Olivier
    I just bought some Ferrari 360 wheels for my '91 TR and I'll need some lug bolts.. I assume that I can't use the lug bolts from my Testarossa wheels, so I'd need the specs on those lug bolts.
    Following specs would be needed:
    Thread Size: i.e.: 14mm x 1.50 RH
    Lug Bolt Seat Style: i.e. Conical seat
    Lug Bolt Thread Length (in): i.e. 2.000
    Lug Bolt Overall Length (in): i.e. 3.000
    Any input would be appreciated!
  2. Rifledriver
    37,104
    Diameter and pitch are the same, as is the head size.
    Thread length 18mm 3/4in
    Shank length incl threaded portion 52mm 2.0 in
    OAL 80mm 3.0 in
  3. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    If those aren't the specs of the bolts you have now, you can buzz over to DexM and Jason will hook you up with some Hill Engineering bolts. www.dexmllc.com
    Check to see if there's anything funny with the bolt lengths on your TR first, for instance, a 308 uses 10mm longer bolts in front than rear to get through the very thick brake hat on the front, so a 308 owner would need to add 10mm to their bolt length on the front. (Actually, you have to go to "360+30mm" to get through the 20mm spacer needed on the front of a 308, but that's another story.)
  4. GrandSportC3
    Oct 8, 2005
    237
    Clearwater, FL
    Olivier
    That's the same as on my current lug bolts... I've read somewhere that I can't use them with the 360 wheels... Seems like I will be able to use them..
  5. GrandSportC3
    Oct 8, 2005
    237
    Clearwater, FL
    Olivier
    Thanks for the anwers! Seems like I'll be able to re-use my TR lug bolts!!
