Lug Nut Torque specs? | FerrariChat
Discussion in '360/430' started by Mighty Noid, Jun 7, 2007.
  1. Mighty Noid
    Mighty Noid Rookie
    Jun 7, 2007
    14
    I am in the need of the torque spec. on the lug nuts for a 2007 F430.
    Can anyone help me out?
    I tried using the advance search but could not find it.
    Point me in the right direction????
  2. m3mike
    m3mike Formula Junior
    Apr 18, 2006
    464
    Knoxville, TN
    Don't know it off hand but it will be in your owners manual under tire changing.
  3. Mighty Noid
    Mighty Noid Rookie
    Jun 7, 2007
    14
    Thank you so much for that info.
    I will take a look at that.
  4. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    75ft lbs. is the spec. but it seems a little light to me so I use 80ft lbs. A friend here in California got his car back from the dealer and we struggled to get the lugs loosened. My guess is we used 100 to 110 to get them off. Obviously some dealers put them on with Airguns. Vrooom Vrooom
  5. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    use anti-seize when you put them back on - that will help you get a more true reading. I have the titanium lug bolts on my 360 and I believe when I looked up the torque, it was 100 nm. Which is about 75 ft lbs.
    Doesn't hurt to re-check the torque after about 10 or 20 miles of driving.
    Ray
