Lumpy running/ missing - very sluggish revs on 400 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by oofazi, Jun 22, 2013.
  1. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    Evening Gents,
    Just got hold of a lovely 400 and in my haste to get her home before the heavens have opened, couple of weeks ago I collected it... I am, well chuffed.....
    From moving at the vendors address to the nearest service station the car was both responsive and did not miss/ run lumpy till I stopped for 40 litres of petrol nr the M23....
    Since this point and as it has been sat in a garage for good husbandry and safe keeping, I am wondering if there has been some grit etc drawn through the fuel lines from the once was almost empty tank....and my adding 40 odd litres to it ensured it was churned up and at the end of the injectors, (assuming it has passed the fuel filter..(almost new)).
    I spoke the previous owner who had suffered this ill beforehand and after he has indicated that it could be the spark plugs, just sent me 12 NGKs to go into it... I have just replaced them....but not turned it over yet...
    The old set of NGKs has right hand bank are all blackened with soot and slightly oiled...clearly not the atmosphere to be firing correctly as they should.
    The left bank is the same BUT all on the left side look as if the spark plugs have tried to fire at least and are lightly brown.
    To all who saw this debarcle of me attempting to drive this car 115 miles home, M23, M25, M3, A303, I apologise as to the backfiring and flames coming from the exhausts, and my ridiculously slow speeds which the car would NOT reach 50mph for the majority of the journey, to be honest it was a mistake in getting it on sucha warm day...
    If anyone can shed any light as to whether it is the constant lack of use that has this problem occurring or if its something more sinister.
    The vehicle has been looked after meticulously by Foskers for over a decade, and had not mentioned anything to the previous owner and there are receipts galore as you would expect...
    Thank you for ant assistance!!
    David
  2. JPinna
    JPinna Karting
    Nov 9, 2012
    70
    Jeremy Pinna
    Off the subject , as a new owner , would you like to join the 400 club at the silverstone classic this year? Email me on [email protected]. Good luck with the lumpy running. I always use premium grade petrol. Also check petrol pump relays.
    Good luck
    Jerry
  3. JPinna
    JPinna Karting
    Nov 9, 2012
    70
    Jeremy Pinna
    Now I have read your post again , this sounds like the petrol pump relay. If the same as the 412 , there is one pump for each bank and subsequently one relay per pump. If one relay or pump is defective you will only be firing well on one bank of six. After running , feel the rocker cover of each bank , the cooler one is the problem. If the same as the 412 the relays are found in the passenger footwell under the carpet and a metal plate.
    Jerry
  4. JPinna
    JPinna Karting
    Nov 9, 2012
    70
    Jeremy Pinna
    For more insight into your problem call me on 01908263227.
    Jerry
  5. galbert
    galbert Formula Junior
    Mar 14, 2012
    374
    sud ouest france
    Galbert Christopher
    bonjour as tu vu les vis platine dans les deux allumeurs !!!!!!!!
    peut être qu'ils sont uses !!
    christopher
  6. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    Jerry,
    Got it, will ring when i get a sec.
    Galbert,
    No, not investigated fully the pumps or the non firing of the one bank as yet. It does however make sense that if the left bank is back firing, the collection of fuel and minute spark to ignite this amount of 'over fuelling', would send me straight to the pump relays in the first instance... Considering the build up of soot on the left bank....
    Thoughts..?
    David.
  7. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,670
    The problem is most likely a failed warm up regulator (WUR), my reasoning is this:
    Faulty fuel pump wiring will result in no fuel getting to one side of the motor = which means the spark plugs won't be sooty, they will be completely 'dry' as all the fuel will have been used up. Also won't cause backfiring ( no fuel to burn )
    Faulty (no) ignition will result in no spark, so the plugs will end up "clean" as a result of being washed in fuel. No backfiring either, as there's no spark.
    A failed warm up regulator will generally allow too much fuel in to one bank, resulting in the engine running rich ( sooty plugs ) and backfiring ( excess fuel in the exhaust )
    Someone with good K-jetronic skills should be able to diagnose a faulty WUR, you need some pressure gauges to do it The WUR's can be rebuilt, there is some good info here
    Ferrari 400 - Ferrari 400 parts Shop
    This is where I go to have WUR's rebuilt, he is "the man" globally, and also posts on F- Chat
    Contact Us - CIS Flowtech
    M
  8. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    Mike,
    Thank you for your explanation, clear and simple. It seems there is a bit of investigation to be done to ensure there isnt nugatory work, as my time is limited, pretty much and the WUR can be rebuilt as you say... Have you any idea where it is located exactly? (Photo?)
    I have no Haynes manual as it the norm for most cars in the UK, foreign cars inclusive, but, it looks so bloody fabulous, I have to get on with something other than just looking at it!!!
    Thank you for the links, that website on 400 parts, well, that is both very helpful and reasonable prices to keep these monsters on the road in the second instance...
    ANY further advice, pse do not hesitate to tell me!!
    Thank you.
    David.
  9. rustytractor
    rustytractor Formula 3
    Mar 25, 2012
    1,078
    London
    Russell Schacter
    David, where in the uk are you based ?
    I'm in Ilford, Essex (near East London) and if not too far may have some local contacts which could be of help.
    Feel free to PM me your details
  10. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Refer to part #7 in the Illustrated Parts Breakdown for the Warm Up Regulator (WUR) :D
    http://eurospares.co.uk/partTable.asp?M=1&Mo=652&A=1&B=37673&S=
  11. 180 Out
    180 Out Formula 3
    Jan 4, 2012
    1,282
    San Leandro, CA
    Bill Henley
    #11 180 Out, Jun 23, 2013
    In this thread -- http://www.ferrarichat.com/forum/365-gt4-2-2-400-412/373121-checking-system-control-pressure-k-jetronic.html -- I posted up some photos of my effort at checking system pressure and control pressure on my '83 400i. The photos show my testing of the right-hand cylinder bank (i.e., the driver side in the UK). My extreme closeups make it difficult to know what you're looking at. But in the third photo you can see the shiny chrome engine oil filler cap, and it's near this cap that the WUR is located. If you scroll down to the last photo in the second post you can see the global view of the system that's being tested.
    Although you're diving in at the deep end, a brief explanation of the K-Jetronic version of CIS (continuous injection system) will help. First take note that, when the ignition switch is in the "run" position and the engine is running, all 6 injectors on each side are spraying fuel continuously. The fuel-air mixture to each injector is controlled by a plunger located in the middle of the fuel distributor. The plunger moves up and down in a bore, in which there are six slits. As the plunger moves up in the bore, the slits are exposed to pressurized fuel. The fuel flows through the slits on its way to the injectors. Underneath that big J-shaped affair toward the rear of the cylinder bank -- it's made of soft black plastic and it connects to the throttle body -- is a large plate inside a conical opening. The plate pivots on an arm. Resting on that arm is a second pivoting arm. The plunger rides on this second arm. The system uses two pivoting arms, because they are separated by a set screw, and the rotation of this set screw is how you lean and richen the mixture. The flow of intake air causes the plate to rise. This causes the plunger to rise.
    Where the WUR comes into play is that the freedom of movement of the plunger is dampened with hydraulic "control pressure," applied to the top of the plunger. The higher the control pressure, the lower the plunger will ride in the bore, and the leaner the mixture. The hydraulic fluid that this system uses is the fuel itself! From an outlet located on the fuel distributor, fuel at *system* pressure flows to the WUR. From the WUR, the *control* pressure flows back to the top of the fuel distributor, where its hydraulic pressure is applied to the plunger, to limit its upward movement. The WUR has a valve inside, which is operated by a bi-metal strip. As the WUR warms up -- at first with electricity, but ultimately from engine heat as well -- it blocks the flow of fuel back to the fuel distributor. Thus, the mixture is leaned out as the engine warms up.
    This system probably seems very Rube Goldberg, but it actually works, furnishing a pretty good mixture "map" without using any electronics at all, not even an oxygen sensor.
  12. Steve Magnusson
    26,635
    David -- Can you please back up three steps, and give the year/model/condition of version/type of ignition?
    Bill -- Your 1983 400i does not have the fuel line connecting the control pressure ports of the two WURs?
  13. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    Hi Rustytractor,
    I am based in Salisbury, and although it is some distance, any advice is invaluable. Once I have worked out how to PM, I will be in touch.
    Thank you.
    David.
  14. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    Thank you blkprlz and 180 Out,
    I will look into this when I get time in a couple of weeks or so, I am now 300 miles from the car for work, in North Yorkshire.
    Seems there is a clear set of checks to complete, but when it's done, it'll be fabulous.
    The car is a 1984, 400i auto, ex Crown Prince of Qatar and Chris Rea owned vehicle. When I am with it, I can spin off the chassis number too, but do not at pres have level of detail for the inj system, although suspected to be K-jetronic like the greater majority.
    On starting it runs fine, never revving of course, but soon enough after a couple of minutes becomes lumpy and misses with popping and missing so much evident, you cannot miss it. It does not recover from this state once warmed though, but I can tell you with it's hesitancy, it still drove, sort of, with the resultant back firing on the left bank.... I assume it's the left bank at fault as my dutiful missus who followed me home saw the flames from the left exhausts.... unless there is an exhaust crossover, and I have it completely wrong... but the evident sooty but at least trying to operate spark plugs but with browned tinge on the electrodes gave me the idea... The right bank are just covered in soot and do not look like they have fired, in a very long time...
    Thank you..
    David
  15. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    Further, are we saying that plunger in the bore is stuck in the open position which clearly is allowing too rich a mixture into the injector lines and ultimately to the injectors? If so, what is the remedy, take apart and clean with alcohol based cleanser? With cotton buds or some such applicator....? I am assuming here, that the pivot links should all be free to move in their full mechanical action also...
    OR, they need to be sent away for repair usually..
    Does an element of outside grit get into these parts normally to prevent full retraction movement, or full range of movement to warrant this fault in the injection system...(WUR).
    David
  16. 180 Out
    180 Out Formula 3
    Jan 4, 2012
    1,282
    San Leandro, CA
    Bill Henley
    #16 180 Out, Jun 23, 2013
    It did not come with one. But Larry Fletcher sent me the banjo fittings, bolts, and fuel line to make one. So it has one now.
    Hi David. With my limited knowledge I hesitate to try to diagnose your problems from afar. But I know that you can adjust the mixture yourself quite easily, to see if this will smooth things out. You do this with a 3 mm Allen wrench, which you insert into a hole located between the fuel distributor and the black plastic J-shaped thing. I have attached a photo of the fuel distributor on the drive side of my car (passenger side in the UK). The hole where you insert the Allen wrench is at the 3:00 position on the fuel distributor. The hole is factory sealed, and in the unlikely event yours has never been messed with, you'll have to remove the seal.
    Here is the 3 mm key I have, which I bought off eBay for the same $10 price as the one in the link: 3mm Hex Tool Adjust Air Fuel Mixture on Bosch CIS Fuel Inj Item ZDM10152EC | eBay .
    A clockwise turn enrichens and a counterclockwise turn leans the mixture. (Righty-richy, lefty-leany.) Always make a note of each adjustment, to avoid confusion. (I know you are prone to confusion or you would never have bought this car.) If your car is close to the mark, a 1/8th turn (22.5 degrees) is a lot. But it doesn't hurt to start with more drastic adjustments with a car that's way off. This is why you want to keep notes, or you'll get completely lost.
    I'm suggesting this experimentation with the mixture control first, because what your car sounds like to me is a car that's way off. However, there are many other sources of problems. The K-Jetronic just does not like to sit for extended periods. One result can be a plunger that does not move freely, or gets stuck. Other similar things can happen, from sitting too long.
    Keep in mind that the system on each side is independent of the other. (There is no connection between the exhaust system on each side.) So if find the sweet spot on one side, you will need to find it on the other side as well.
    So here's my advice: (1) get a copy of a book called "Bosch Fuel Injection," by Charles Probst ( Amazon.com: Bosch Fuel Injection and Engine Management: How to Understand, Service and Modify (9780837603001): Charles O. Probst: Books ), (2) get a 3 mm Allen key and fiddle with the mixture screws, (3) contact Larry Fletcher CIS Flow Tech LLC (you can personal message him as fletch62 her on FChat), and (4) get a K-Jetronic fuel pressure gauge rig like the one I was using in the thread I linked to before. Actually, the "pm" to Larry Fletcher is probably the first thing to do. But the pressure test is also a base line for all K-Jetronic problems.
    And about your suggestion to dismantle the fuel distributor to clean it up, yes it can be done, but I would definitely try to eliminate everything else before I attempted that project.
  17. Steve Magnusson
    26,635
    That's probably best. It's not strictly needed, but it makes sense to have the control pressure the same on each bank at the "average" value. I thought all of the later 400i like yours would have it, but maybe its presence is more "variable" -- i.e., if the OP's 400i has it, a control pressure problem couldn't affect just one bank, but, without it, it could.
  18. Flinch
    Flinch Formula Junior
    Nov 15, 2009
    302
    Holland and Sweden
    Peter El Cheapo
    first things first: have you checked the sparkplug leads and distribution cap? Are they okay and are all of these in the correct order of firing? Sounds like you could have mixed up some wires there. Secondly: do a compression test. Maybe it just needs some new valve shims. Both these problems can cause the symptoms you discribed.
  19. rustytractor
    Mar 25, 2012
    1,078
    London
    Russell Schacter
    #19 rustytractor, Jun 25, 2013
    I'm pretty sure you've worked it out by now but if not, touch my name at the top of this message and a drop down box appears.
    Select the option to "Send a private message to rustytractor" and bobs your uncle (or in my case he's my dad !!).
    You're getting good advice here although there's quite a lot to think about, especially for a person who's had no time to acquaint themselves with their car. Maybe it would be helpful for those "in the know" to list the areas they feel may require attention in an order of priority, that way David can easily see if there's an obvious 1st, 2nd, 3rd choice etc as to where to look.
    I can't help because I have no experience of the Bosch Injection system as my car has good old carbs (admittedly it has so many of them that I've lost count) but there's a wealth of information on this forum and we're a friendly and helpful bunch so someone will have the answer.
    Hopefully the car won't end up dismantled and in boxes before you find it !!
  20. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Good Check :D
    As wrxmike pointed out, Larry is the 'go to guy globally' & he also rebuilds the fuel distributors. If I'm not mistaken, the WUR's are on the control pressure side of things & if that's the case, that balance line is very necessary for 'smooth & even running operation' these injected cars are touted for. Control pressure is huge :p
    Larry Fletcher's site that Mike posted earlier.
  21. 180 Out
    180 Out Formula 3
    Jan 4, 2012
    1,282
    San Leandro, CA
    Bill Henley
    There's something that's been bothering me about my previous posts to this thread. I hesitated to correct or explain for fear of confusing the issue further. (The K-Jet system is pretty confusing for a beginner.) But here's my clarification: the function of the WUR is to bleed off system pressure from the top of the mixture control plunger. That is, the flow of fuel is away from the top of the plunger, to the WUR, and then back to the fuel tank. I frequently get this fact 180 degrees out in my own thinking. But the way it works is that there is a passage in the fuel distributor body, which exposes the top of the plunger to system pressure. The greater the pressure, the less the plunger can rise in the fuel distributor for any given level of air flow, and the leaner the mixture at the cylinder. At cold start, you want the richest mixture. Therefore the valve at the WUR is wide open, allowing the system pressure to escape to the fuel tank. The low control pressure which this allows -- the pressure at the top of the plunger is at its lowest -- allows the plunger to rise higher, which enrichens the mixture. As the WUR warms up, its valve closes. This holds in more of the pressure, and the control pressure increases, eventually reaching its maximum. This causes maximum leanness at the cylinder.
    Clear?
  22. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    #22 oofazi, Jun 29, 2013
    Gentlemen,
    I have just been out to do some investigation on the car and diagnose as far as feasibly possible the issue. It transpires that after a dig about in the fuse box, the fuse has blown in the LH fuel pump, and is thus replaced. The new plugs are fitted, at no time has the vehicle been started to identify any further ussues and after disclosing the issues to you all, it seems that a simple fix may be on the cards........the thing is, I have no idea why the fuse was blown in the first place and this would be the case since I collected it. The soot build up and absolutely no moisture on the plugs on the left bank would clearly be the result from nil fuel injected......
    We'll see......let me identify any more problems with it and get back to you all.
    Particular thanks to Larry Fletcher, thank you so much for your insight and advice.
    David
  23. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    I have had correspondence from the Insurance firm who I engaged on classic policy to do no more than 3000 miles a year, but are saying the current worth is a paltry 18k sterling in this condition.....?!!!
    Sound fair or not?
    What say you all?
    David
  24. rustytractor
    Mar 25, 2012
    1,078
    London
    Russell Schacter
    Speak to Ian Arthur at Hagery insurance 01327 810600
    They insured my 400 for far, far more than that and didn't bat an eyelid.
    They are the best and easiest insurance company I've ever dealt with bar none. I insure all of my classics with them and have nothing but praise for them.
    PM me if you need any more info.
    Russ
  25. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    Chaps,
    I have concluded all but I have ensured the F is run up regularly each week, that the longer the engine is run, warming up, the more reduction (to approx 1800-2000 rpm) that the engine will rev to before it will not rev further and fluffs, backfires etc.
    What is the choke system in the engine, is it electronic or mechanical? Is there any mileage in the thought it is stuck in the open position? And that it could be freed off to allow a full rev range when engine is fully warm.
    The odd part is that on release of the throttle the idle is perfectly strong, and no issues at all...
    But, there is a direct correlation between flexing the throttle with out issue after 2-3 mins after startup, to fully warm and little to no rev ability at all.
    To be honest, can't really drive the car in this state.. and is very disappointing this far.
    Any answers on the choke, if any of you clever boffins have any ideas?
    David
