Lusso battery change. How to | FerrariChat
Discussion in 'FF/Lusso' started by Il Co-Pilota, Nov 11, 2020.
  1. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Hey guys
    So got the battery changed, and it went even easier than thought I ended up not having to take much apart at all.
    It was a cold day, so I got it done as quickly as possible. The major challenge doing this way, is lifting the battery out. But other than that, easy.
    Step 1.
    Remove battery compartment cover
    Step 2.
    Disconnect quick connect pole from the bracket.
    Step 3.
    Remove battery ECU cover
    Step 4.
    Loosen the positive pole using a small 10 mm top.
    Step 5.
    Remove the battery ECU box using a Philips head
    Step 6.
    Loosen the clamp by removing the two 10 mm nuts. Make sure not to drop the washers. Also remove the negative lead using a T30.
    Step 7.
    Tie off and cover the ECU and tie off the loose leads to get them out of the way.
    Step 8.
    Lift up the battery as shown with the heat insulator. It is fiddly as hell and heavy, but doable.
    When this is done, it is all very easy. I forgot to shoot a pic of the blanket, but frankly, it is more than self explanatory at this stage how it is removed and taken off. There just a snap lock in the front. When that is done, you remove the negative lead from the battery.
    The install is just everything in reverse. Note that there are no provisions for non-OE batteries for the battery ECU Philips head screws. Just to support it, I stuck a bit a double sided tape on the back.
    Job done.
    About one hour. It does take strength to do it like this, as there's not a lot of room.
    Have fun:)
    LittleEnzo, otakki, Jaguar36 and 4 others like this.
  2. Caeruleus11
    Caeruleus11 F1 World Champ
    11,471
    Thank you for sharing this! Is there anything you need to do regarding startup procedure/ computers?
  3. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Prior to doing anything, I rolled down both windows a bit. This just so I could open the doors while the car was offline.
    I did the normal procedure as per the manual after the install.
    Step 1. Close both doors and the bonnet.
    Step 2. Lock and unlock the car.
    Step 3. Use the keyfob to open the bootlid.
    Step 4. Close the bootlid.
    Step 5. Get in the car and close the door
    Step 6. Switch on car without starting it.
    Step 7. Roll down and roll up both windows.
    Step 8. Start car and let it run the cold start
    Very simple:)
  4. kimwizzzuuu
    kimwizzzuuu Karting
    Aug 26, 2018
    240
    new york
    Kim
    Told ya, it’s straight forward, just don’t loose the washer for the drain tube bracket.
  5. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,746
    Weston, MA
    Paul
    Give yourself 1,000€ for labor! :D
    Il Co-Pilota likes this.
  6. SECRET
    SECRET Formula Junior
    990
    296 GTB
    Any photos of the finished product [without the battery cowling]?
  7. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    #7 Il Co-Pilota, Nov 12, 2020
    No sorry. Didn't think of that.
    But with the clamp, heat shield and ECU mounted, there's just another black battery. You can't really tell unless the clamp and ECU is off. If I can get some time Saturday, let me see if I can find a moment removing these things. No promises though.
  8. SECRET
    990
    296 GTB
    So the battery can come out without the lower windshield cover coming off? It looked like the battery was partially trapped under there.
  9. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    I get it, but it takes a lot of wiggling. Should I do it again, I'd remove that.
  10. kimwizzzuuu
    kimwizzzuuu Karting
    Aug 26, 2018
    240
    new york
    Kim
    wiggling have high risk of dropping it[emoji1787]
  11. SECRET
    990
    296 GTB
    @Il Co-Pilota, just another thought came to mind. How are you charging/trickle charging the AntiGravity battery now that it's lithium?
  12. kimwizzzuuu
    kimwizzzuuu Karting
    Aug 26, 2018
    240
    new york
    Kim
    there’s a Ctek lithium charger you need to use specific for LI battery.
  13. otakki
    otakki Formula 3
    1,634
    Is that lower windshield plastic cover easy to remove?
  14. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    It is held on with 8 bolts.
    4 T25 bolts
    2 8mm hex top
    1 10mm hex to
    1 Philips head with a spacer on the back.
    The tricky part is releasing it from the windshield. I did not do this. According to my dealer tech, some are glued to the windshield, and some are not. If yours is glued, it will be difficult.
    otakki likes this.
  15. Solid State
    Solid State F1 World Champ
    10,471
    Maximus Decimus Meridius
    As much as a pain it is to wriggle the battery out I would still not mess with the plastic windshield cover if glued in. Could snap the plastic or never get it to re-adhere properly or lay flat again. Would have the same concern if taken to the dealer.
    otakki likes this.
  16. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,210
    Santa Barbara County
    Sam
    Why was this needed? I have been having problems ever since car was at stereo store and battery ran down. Feels like battery doesn't hold full charge. I have to plug in over night to keep charged. Do you think this might do something. Battery was replaced 11 months ago by dealer.
    Sent from my SM-G975U using Tapatalk
  17. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    It was needed because my battery ran down during summer storage as the magnetic plug came loose. Your battery is dead.
  18. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Yep. Spoke to my dealer about it yesterday in fact. He said they don't remove it completely. They undo all the fasteners holding it on, but leave it attached. That apparently gives an additional 20mm or so which makes it pretty easy. I'll do that if there's a next time.
    otakki likes this.
  19. Nospinzone
    Jul 1, 2013
    7,746
    Weston, MA
    Paul
    That's good to know!
  20. sandman03456
    sandman03456 Formula Junior
    389
    Las Vegas, NV
    Any tips for the placement of the new battery? I thought removal was difficult, but the placement of the new battery has proven to be a greater challenge. I have exhausted the wiggle method.
  21. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Not really. I found putting the new in super easy. Might want to get someone to help you pulling the distributor block out of the way. Other than that, I cannot see what should make it difficult. Make sure the heat insulation is tight on the bottom of the battery. If that wrinkles it can make fitting difficult.
  22. otakki
    otakki Formula 3
    1,634
    An extra 20mm of wiggle room would it a lot easier!
    My experiene was the same as sandman. I was so tempted to spray some lubricant over the battery tray to help slid it in.
  23. sandman03456
    389
    Las Vegas, NV
    I tried to loosen the windshield cover as suggested, but I can't figure out how to get the large brace, near the back of the battery tray to move it seems to be one of the limiting factors
  24. sandman03456
    389
    Las Vegas, NV
    I've checked the insulation, and I have moved the distributor block, but it still gets hung up in the same spot at the same angle?
  25. sandman03456
    389
    Las Vegas, NV
    Well, I finally got it seated properly. I appreciate all the assistance. The left lower leading edge of the heat shield was getting stuck in the tray in the same spot. Once realized, I was able to wiggle the battery while primarily lifting the left side, which did the trick. On this day of Thanksgiving, I am thankful that this task is over. I will post multiple pictures when I have a chance. And on a more serious note, I want to thank all that have attempted and succeeded in this endeavour previously for their insight and wisdom. I may not have attempted it otherwise. All the best.
